E85 lnf
Old 01-10-2016 | 04:18 PM
Sl0wbaltSS's Avatar
So according to this thread, nobody on here is full E. I'm on Full E85 on my LDK SS sedan. For me to run FULL E85 I had to only get a zzp bigger fuel lobe cam. Just the 250 dollar one, not the actual upgraded cams for 600 you don't need that.
You can still use oem injectors on stock turbo and just the fuel lobe cam but you''re limited to 6500rpm rev limiter at close to sea level.
As of injector seals, only 1 needed to be replaced due to the seal being fucked and letting exhaust gasses past and the end of the rail being black. So I put e85 safe ones on and the color is black for the E85 safe ones.
So on to tuning, it's gonna take awhile. Dail in your MAF to 91 Stoich really well, Set your DAL's and WGDC to match your desired boost level and air. Figure out the % of Ethanol content in your jug/e85 station and have your tuner do some math and add that more % of fuel to make up for the e85. The tuning will take awhile and the Injector constant will need to be tinkered with alot. For me to achieve full E85 with 25PSI of boost and 33lb min of airflow was to bump up the fuel rail pressure but do it little at a time. I'm at a maximum of 2450psi
You should really get opels though. Makes tuning easier and you can set your rev limiter to 7k which does make a difference in some races lol.
Old 01-10-2016 | 04:46 PM
KMO43's Avatar
I bet your car drops so much fuel pressure on spool
Old 01-10-2016 | 05:05 PM
Sl0wbaltSS's Avatar
I'm on the upgraded fuel lobe cam from ZZP. It holds 2450 and sometimes will go up a tiny bit.
Old 01-10-2016 | 05:07 PM
KMO43's Avatar
I know. I bet you're over 10ms
Old 01-10-2016 | 05:26 PM
ae_xiong's Avatar
Wait, what? If you weren't tuned by Term I would say get a decent tuner. But that sounds wrong to me. I'm running e47 on the 6758 but I'm at 5,400 feet which helps. Still, I was running out of fuel on my dyno run where I made the numbers in my sig. Which is why I am upgrading my fuel system this winter. Opel injectors and Stage 3 cams. And custom 5th injector because I wanna run full e85 again lol
91 octane is also the highest you can get here.
But as KMO said, mixing is easy, you'll get used to it quick. Just guesstimate how much your car will take on the low side, and fill up 50/50. I also always carry a 5-gallon can of E85 with me so I never run out.
I'm at sea level and Term told me I was maxed out on my fuel. I'm not a tuner so I don't know. LOL all I know is he said I would need cams and injectors if I want to mess with e. Oh well, I'm not power hungry and the current power my car is making is enough to break v8 hearts and be reliable so I'm pretty content at this point.
Old 01-10-2016 | 05:33 PM
KMO43's Avatar
I dynoed at 1129ft on E25 but had the meth to help and I had to up the fuel pressure to keep the injector timing in range
Old 01-10-2016 | 05:36 PM
splash's Avatar
Just seems like a hassle to me lol... I guess I'm not "about that racecar life" lol
Old 01-10-2016 | 05:41 PM
KMO43's Avatar
I plan on driving 12 hours each way to pick up a couple barrels of E in the spring. You have to see the the power difference for yourself. Plus E keeps EGTs low so is better for the engine you just have to watch IDC and not a crazy spool to go easy on the trans
Old 01-10-2016 | 06:08 PM
Sl0wbaltSS's Avatar
Nope. only at 6ms.
Old 01-10-2016 | 06:15 PM
KMO43's Avatar
Nope. only at 6ms.
Sure. One of my customers bought a cam lobe from Mongo and I didn't even see it make a difference
Old 01-10-2016 | 06:25 PM
  #36
63 Nova SS's Avatar
I have a truck and just fill gas cans 1/2 and 1/2 after verifying e content, and fuel the car with cans. That way I don't even have to mess with guessing how much I have left. The cans are perfectly mixed. Just my 2 cents.
Snail_SS (01-10-2016)
Old 01-10-2016 | 06:30 PM
  #37
KMO43's Avatar
yes would work as well how big are the cans?
Old 01-10-2016 | 06:32 PM
  #38
63 Nova SS's Avatar
Hell I just use 5 gallon cans. Only have to drive 15 minutes. Oddly both the gas stations in my town who carry e, don't carry 93. So I would have to do it anyway.
Old 01-11-2016 | 03:26 AM
  #39
KMO43's Avatar
I was looking over my e25 dyno log and I was at 6.4ms so I still have more injector left but I'm looking to add power this spring going lobe plus injectors and from a 550cc meth nozzle to a 800cc nozzle. That should give me enough fuel to meet all my goals
Old 01-12-2016 | 01:27 AM
  #40
KMO43's Avatar
Ok, so having a boost ramp is not an issue for me because I want the tranny to last as long as possible. What the issue is for me is the fact that the highest octane available to me is only 91. So as u can imagine my timing is incredibly low. It also gets to 110+ degree F out here in CA during the summer time which doesn't help out at all. So even though I have a fully bolted 6758 zfr, my buddy with a fully bolted e47 ko4 turbo can put a car on me. now mind u my current tuner is Term2 so the guy knows what he is doing and my buddies ko4 balt on e47 is Trifecta tuned and has no back seats or spare tires plus I usually always have at least half a tank of gas n my girl riding with me cuz shes into racing too. Lol
I think somebody needs a rematch!
Old 01-12-2016 | 03:36 AM
  #41
Sl0wbaltSS's Avatar
You know it's bad when e47 stock turbo can beat a 91 octane zfr lol.
Old 01-12-2016 | 03:38 AM
  #42
KMO43's Avatar
This is the first time I've ever agreed with you! Mark this down it's history!!
Old 01-12-2016 | 07:52 AM
  #43
Canadia's Avatar
Ditto on this.
Term told me before a e47 k04 moves out like a 91 big turbo.
Good thing we only have 91 here
Old 01-12-2016 | 09:53 AM
  #44
KMO43's Avatar
Originally Posted by Canadia
Ditto on this.
Sorry but no
Old 01-31-2016 | 11:31 PM
  #45
Sl0wbaltSS's Avatar
e85 seals are black.
Old 02-11-2016 | 04:40 PM
  #46
Psykostevo's Avatar
No, he's actually around 6 ms around 6300 rpm and no fuel pressure drop. And that's moving 33.5lb of airflow.
The tune isn't easy to accomplish on full e85, and there's really no power difference over e47. So stick with e47 in my opinion. There aren't that many LNF tuners out there with as much experience as me, and it was a chore to tune SlowbaltSS's car on full e85 with stock injectors.
Old 02-11-2016 | 04:49 PM
  #47
Psykostevo's Avatar
Sorry but no
I would put one of my e47 K04 cars up against a ZFR on 91. It would be a close race for both cars.
Old 02-11-2016 | 05:04 PM
  #48
user 72239's Avatar
my full e85 k04 car had a much larger torque spike but my EFR 20 psi 91 had much more top end and more horsepower.
Now when I was on E30 and running 30 psi of boost on the EFR...that was just nuts.
Old 02-11-2016 | 05:06 PM
  #49
cranemaster's Avatar
a k04 doesn't hold 28psi to 7000 rpm, maybe corny highway pulls they might seem similar but in real life, totally different ball games lol
Old 02-11-2016 | 05:09 PM
  #50
user 72239's Avatar
yeah. I saw 28 psi for maybe 200 rpms then it fell flat on its face.
