E85 whp/tq
Old 09-12-2014 | 06:32 PM
Josh-SS's Avatar
E85 whp/tq
Just wondering what you all think I would make with the following mods on E85.
HAHN CAI
Hot side charge pipe
Catless DP
Muffler Delete
Forge BPV
With a tune on 21-23 PSI. What kind of power could I make?
Realistically I want to be around 340 WHP and 380 TQ
I want to basically be at the limit where I am not destine to blow the trans but I'm at the power level where I will of course have to be careful with it. Just wondering what you all think. Thanks in advance.
Old 09-12-2014 | 06:49 PM
tomj77's Avatar
Ull make 0whp and 0wtq because u have Hahn crap and it will rust through and ull loose all ur boost and ur incoming air will be full of broken pcs of rusty intake
Old 09-12-2014 | 08:01 PM
Sl0wbaltSS's Avatar
Ehhhh, you should really get gms1 sensors and the opel injectors so the e85 doesn't nom nom nom the seals. You can make that on 91 with a super good tune.
Old 09-12-2014 | 08:08 PM
colodude18's Avatar
I made 359/418 on full E85, fully bolted, stock turbo, and 26psi.
I was pretty close to maxing out my fuel at 5400 feet, so Opel injectors would probably not be a bad idea at sea level.
As for Hahn, I've ran their intake, charge pipes, hi flow DP and cat back since 2010 and there's not a speck of rust on any of them.
Don't worry about the trans. If you break that on the stock turbo you're an idiot.
Old 09-12-2014 | 08:27 PM
Well you are term 2 tuned lol that atleast gives you peace of mind
Old 09-12-2014 | 10:04 PM
ae_xiong's Avatar
Sorry OP, don't mean to jack your thread or anything but I was kind of wondering if anyone has ever dynoed while on e-85 and compared it to being on meth? Just wondering what the difference in numbers will be between the both of them. Thanks!
Old 09-13-2014 | 01:05 AM
Josh-SS's Avatar
I'm only about 700 feet above sea level. I just want to hit roughly 380 TQ and sit there for a while. Could I do that with the help of E? I am running on my LSJ and I love it. And yes I may get the MAP sensor upgrade. PS I can tune on 93 here as well. Thanks.
Old 09-13-2014 | 12:52 PM
Wert842's Avatar
Why do you want to hit a desired tq number?
Old 09-13-2014 | 12:59 PM
Because dyno-rice-racer
Old 09-13-2014 | 04:25 PM
Josh-SS's Avatar
There are two other LNF's around here that are making a little over 340whp/385tq that I would just like to hang with. I also don't want to have to worry about clutch and trans problem with winter coming up soon. At 390tq I've seen balt's put a car length on cts v's.
Old 09-13-2014 | 04:32 PM
Wert842's Avatar
That would be more horsepower than torque... Even at those torque numbers you still have to watch the clutch. It isn't going to last long at all.
Old 09-15-2014 | 09:18 AM
r3v07ut10n's Avatar
i too had a hahn cai, no rust in 4 years.
Old 09-15-2014 | 10:08 AM
tomj77's Avatar
Then u never drove in the rain
Old 09-15-2014 | 11:15 AM
user 72239's Avatar
I made 349 WHP 457 ft lbs on a 26 psi E85 tune with all those mods, except muffler delete.
Old 09-15-2014 | 12:51 PM
Wert842's Avatar
With E, its a different ballpark.
Old 09-15-2014 | 04:26 PM
Josh-SS's Avatar
Right. See the WHP is great. But the TQ is too high for right now. I want to stay around 380 TQ until I can get a clutch and maybe a spare trans. Is there anyway to lower the TQ a bit through tuning while still staying around the same WHP?
Old 09-15-2014 | 05:53 PM
Wert842's Avatar
Ya. Boost ramp...
Old 09-15-2014 | 06:13 PM
Sl0wbaltSS's Avatar
457tq wtf?!?!?!
Old 09-15-2014 | 07:10 PM
user 72239's Avatar
yeah that was with a terminator 2 29 psi spike, tapering to 26.
If you have him do a decent boost ramp, you can make less peak torque.
Old 09-15-2014 | 09:16 PM
09CobaltSS1's Avatar
The Hahn comment is a nonsense generalization. I've had a Hahn intake on my car since basically day 1, and it's fine.
Your power goals are more than achievable with e85. Running a lower peak boost range like 21psi will absolutely keep your torque numbers in check, however might kill your overall power band a bit. I'd say shoot for 23-24psi peak, slope the boost in nicely and you can easily keep torque under 400. I ran a 24psi tune making 355whp/383wtrq e47 tune on my stock turbo for quite a while which I was content with for quite some time. As far as your clutch goes, good luck. It's a complete crap shoot on how long it will last. Mine started slipping badly within a month or 2 of switching to e47.. lol.. I would at the very least start planning on saving some money to have a GMPP clutch upgrade in your future and an intake cam with a larger fuel lobe to keep up with the fuel demands that e85 will create. Opel injectors are 100% not necessary.
Old 09-15-2014 | 09:23 PM
I'm pretty sure he got at least one batch of bad stainless, leemanfor's hahn intake was rusted to all hell
Old 09-15-2014 | 09:33 PM
Oh I don't doubt that he had problems, and I'm sure I'd be annoyed as well. I just don't understand the need to always throw Hahn under the bus every chance he's given, even when the topic has nothing to do with crummy intake experiences.
Old 09-15-2014 | 11:00 PM
It's css, mess up once and they'll be driving the bus right over you
Old 09-18-2014 | 08:10 PM
LNFnoob's Avatar
To the OP,I have everything you have besides muffler delete,and on a 23psi, 93 octane tune using HP,my max hp/tq was 319/398 with stock clutch slipping in 4th on the pull,so the numbers your wanting are achievable without E
Old 09-18-2014 | 10:21 PM
Josh-SS's Avatar
Really? Wow. Would E still be worth the extra WHP? I currently run my LSJ on it and I have had 0 issues.
^ That was my 1000th post. Yay.
