Electronic Boost Controller (dyno tuning questions)
Old 01-25-2014 | 02:14 AM
EFoxwell's Avatar
News flash- Dyno numbers for the sake of dick measuring(like what seems to be going on here) are pointless.
Old 01-25-2014 | 01:11 PM
Waka Flocka Fluff's Avatar
funny part was the dyno number was completely irrelevant to the question in the beginning
Old 01-25-2014 | 01:30 PM
09CobaltSS1's Avatar
Haha.. no dick measuring was going on. My only point was the relevance of stating that this is "the most accurate dyno in new jersey", and subsequently that it's clearly not. Although implementing validity to inflated numbers with those claims of dyno accuracy can be taken as someone slapping their horse **** on the table looking for a high five in itself. Regardless, my first post responding to the OP pretty much answered the important bullet points.
Old 01-25-2014 | 10:15 PM
tomj77's Avatar
He should have put stock dyno run to see just how accurate it is, that would tell the story
Old 01-26-2014 | 12:08 AM
yellowss7590's Avatar
last time i checked isn't 25psi out of the k04's efficiency rage and also makes the turbos life span shorter lol?
Old 01-26-2014 | 02:34 AM
EFoxwell's Avatar
I wasn't directing that at you.
Old 01-26-2014 | 03:38 AM
tomj77's Avatar
yes, but there will be guys that say "its all in the tune"
run a car at redline all the time and see how long it lasts, no matter what tune u got. same thing with a turbo, u run it at its max ability like that, its gonna go eventually. that or all that heat will do some damage as well.
Old 01-31-2014 | 04:50 PM
Matt M's Avatar
Remember that a slipping clutch can add to the peak hp number as well. It's the same reason you can trap a higher mph on a pass when you spin off the line. On the drag strip, you are using hp to get the drivetrain spinning faster without using up much track. Then once you start to get traction, you have this working to your advantage. In the same way, if your clutch is slipping on the dyno, but you stay on the throttle, when the clutch finally grabs you put more power to the wheels because you do not lose hp accelerating the motor. It's simple inertia. Try tapping on a nail with a hammer vs. setting the hammer on the nail and pushing it. Already having the hammer in motion before it hits the nail gets the job done much better.
Old 01-31-2014 | 06:33 PM
armcclure's Avatar
Very good analogy.
Old 01-31-2014 | 10:52 PM
tomj77's Avatar
never quite heard it like that before. very good point
tomj77
10-02-2020 06:36 PM
Turbo Johnny
02-21-2019 10:41 AM
lendsley
09-22-2015 11:48 PM
medic710
09-06-2015 09:53 PM
