Fastest GMS1 cobalt
Definitely cant afford Drag radials at this time. Though when im working again its probably going to be my 1st purchase
Found my slips lol, please dont laugh:
60' 2.627
1/8th 9.49|
MPH 83.91
1/4 14.09
MPH 107.08
my best 60' of all my slips was 2.547 lolz.. though somehow my worst 60' was my highest trap
So basically if I had a magical 2.175 60ft launch, id have a solid 13.6 Run, perhaps even better...
60' 2.627
1/8th 9.49|
MPH 83.91
1/4 14.09
MPH 107.08
It wont even do that on the street if that says anything.
13.9 @ 103 bone stock from dealership(under 3k on car).It took me 20+ passes through the summer to get it in the 13's one time lol. I felt like I accomplished something
I only had 4 passes.. Never even got to try anything else but two runs using launch control (fail) and two runs just manually figuring out a good rpm to start at. I have my winters on right now... Wonder if I should go to the strip and see how they fair haha
I cut my best time with the aid of the aforementioned "sports equipment". Pretty inexpensive mod and effective imo. Good if you're on a budget or (like me) don't plan on frequenting the track. I'm getting the bug to go back and actually try some throttle/clutch modulation to better my 60' (2.24 iirc). I left somewhere around 22-2500 and just put it to the floor,lol. 1-2 @ 5500 ; nls 2-3 @ 6200.
Oh sorry I didn't know you had been driving 7 years. I saw someone mention highschool and assumed too much $127 is godly bro. I've never had it under $200, $250 atm with 3 minor convictions (speeding 14km over no points $52.50 fine) 2 of em should be coming off within the next year (god damn 3 year record ****) Worst thing was the once you turn 25 myth your insurance goes down, NOT.
Both of these passes were made with a DA of over 7000ft. The track is at 5800ft above sea level too.
This is with only GMS1 and a Hahn CAI:
2009 Cobalt SS Turbo GM Stage 1 1/4 Mile - YouTube
This is with GMS1, CAI, Catless DP, and a ZZP bolt-in budget FMIC:
2009 Cobalt SS/TC GM Stage 1 + Bolt Ons 1/4 Mile Bandimere - YouTube
I NLS the **** out of my car:
Cobalt SS/TC No Lift Shift ( NLS ) Demonstration - YouTube
If I could get closer to sea level and run some drag radials, I'm pretty confident I could get a 12.9 out of it.
My 2009 Cobalt SS Sedan 12.9@112MPH vs EVO X - YouTube
#36
I did my 12.9 on hankook V4's (All seasons) 3200 ft actual 5000+ Calc da / AB mod and tune w/ corn fuel
#40
*** and more like 13.7@104 https://www.cobaltss.net/forums/drag...turday-228820/
#43
im thinking my 1500FT elevation should be on my side, with my 2.6 launches i was trapping 106-107
Also that video is the ZZP stock airbox mod ONLY, e85 tuned cobalt.. effectively stock physically. NOT GMS1
#46
AN ideal run, with the best possible E/T is going to use optimised launch RPM & shift points ~ which will yeild lower MPH;
on the other hand, higher MPH trap speeds will be dumping the clutch off the line, and generating speed ~ instead of focusing on getting to the traps as quickly as possible...
using the MPH from your best E/T's, you can make a very good estimation of how much power a vehicle makes...
When I ran my car (stock, and in 2010) IIRC my highest trap speed was 105 ~ it was on my very first run, in which I got three gears of rubber...
my best ET was 6-7MPH slower than that run...
iirc for every 1/10th of a second you can shave off of your 60' - you're supposed to gain 2/10th's at hte top end;
plus I believe it's said that for evey 100lbs of weight you can shed, you can stand to gain 1/10th on the top end...
My personal bests might be seen as laughable by some here - but my track (which just closed down btw) generally had a Denistiy Altitude of roughly 6,000ft;
that being said, I generally would have 2.1xx-2.2xx 60 foot times.
it's very easy to on a website think you're faster than someone without taking into account conditions, and how they have a negative impact on E/T's...
I haven't a clue on how to do correction factors for my cobalt since it's turbo'ed - and supercharged & turbo'd cars have a much smaller correction fact or than naturally aspirated...
as an example, my other FWD car I've gotten a personal best of 15.2 at the local track - once I correct for density altitude this goes down to a 14.4...
moral of the story: for identical cars, and equal drivers, the run made closer to sea level will be faster...
#47
14.3 @ 98mph
my worst (iirc) was 14.5 @ 105mph
the track is at something like 5,500ft - and DA bumps it up to normally around 6,000ft
I need to stress, my car was 100% stock ~ even Edmonton's track is at a lower elevation, and cars generally are a couple tenth's quicker...
#49
go here FastCop search for Henry
its fast cop verified
ill let anyboody look at my car and tell me what ive done to it. GMS1, cattless DP, charge pipes and at the time a hahn CAI
http://www.youtube.com/watch?v=vEZuOsqNbH4
#50
So you are telling me with a straight face... with 277WHP/303Ftlbs you are running a 12.7@113 on a stock GMS1 tune. And fastcop verified doesn't mean much of anything. You are besting the fastest GMS1 here by more than a 1/2 second. And the tq management alone in the GMS1 tune will hold you back. Lets see the time slip.
