Fastest GMS1 cobalt
Old 02-14-2012, 03:56 PM
  #51
Shanedude's Avatar
Nice video. Can't wait to get on a dyno with GMS1 and K&N. Hopefully the numbers aren't too far behind yours.
Might be a silly question but will altitude affect numbers on the dyno?
Old 02-14-2012, 03:58 PM
  #52
drewbroo's Avatar
Altitude / temp about everything can affect dyno numbers. Also correction factor etc.
Old 02-14-2012, 04:08 PM
  #53
FRQ FLYR's Avatar
^ Pretty much this-that proves your car is black..
I won't start with accusations so hypothetically how could a Stage 1 car cut that time/trap ? All bolt ons (not "custom tuned" for mind you) , ported head/throttle body? (ditto) , traction aids (slicks/chains/bags/etc) , meth/water/nos , gutting the car/empty tank , turbo upgrade ,vac tank bypass, wikd awsome driver mod..Am I forgetting anything?
Old 02-14-2012, 04:11 PM
  #54
drewbroo's Avatar
"GMS1, cattless DP, charge pipes and at the time a hahn CAI" he says. And the dyno does not represent a 12.7 sec car.
Old 02-14-2012, 04:20 PM
  #55
FRQ FLYR's Avatar
Exactly-so do you think it's feasible at all with more mods,Andrew? (Short of gutting the car?)
Old 02-14-2012, 04:24 PM
  #56
drewbroo's Avatar
The trap isn't unless its a downhill track. Also you should know the tq management in the stock GMS1 tune kills your 60 ft. You only can get 50% of tq in first gear. With gutted and slicks, a few more mods it wouldn't be possible, because of the custom tuning needed for the new intake tract. (The maf would be skewed all to hell killing the numbers.)
  #57
soundjunky's Avatar
Originally Posted by drewbroo
Altitude / temp about everything DOES affect dyno numbers. Also correction factor etc.
fixed.
same said for E/T's.
This is why there are correction factors.
Really though as I heard in the video (which took FOREVER to load btw) usig any dyno numbers as a baseline - is really where a dyno becomes a tool;
you can't really compare different cars, on different dynos, in different vicinities ~ becasue they are all variables which attribute to difference...
car looked great though
Old 02-14-2012, 04:33 PM
  #58
Shanedude's Avatar
Must be your connection the video loads up instantly for me.
Old 02-14-2012, 04:53 PM
  #59
soundjunky's Avatar
I think on the sixth attempt to load it, it worked...
Old 02-14-2012, 07:18 PM
  #60
kretty's Avatar
I'd like to think I'm a good driver. Lol
Old 02-14-2012, 07:24 PM
  #61
kretty's Avatar
I'd like to think I'm a good driver. I just posted my times. The NHRA natls were held there the weekend before. It was perfect conditions IMHO. The car ran well. I dunno what else I can say. No wonder everybody left this forum. Yes my spare was removed, trunk was gutted, interior was still full.
Old 02-14-2012, 07:25 PM
  #62
kretty's Avatar
You also have to remember I have a weird wastegate. I spike and hold 26psi on the GMS1 as my Facebook shows. So does my dealership record. I made sure I made a record of it in case something happened.
Old 02-14-2012, 07:33 PM
  #63
drewbroo's Avatar
Spiking and holding 26 PSI on the GMS1 is very odd. Also you would be doing all this on stock timing. Seems a lil fishy holding 26 PSI on the GMS1 tune.
But if this is true, it would make sense, but it wouldn't mean you are running a stock GMS1 tune (The boost levels for that tune are leveling around 21PSI). 26 PSI makes the turbo a heat factory too. So even that this is all possible. 26 PSI makes this car no longer "stock GMS1 tune." You have a very nice dealer.
Old 02-14-2012, 08:44 PM
  #64
Sonicyeller's Avatar
Heh, I'm at 6000ft above sea level and my GMS1 only makes 23psi.
Old 02-14-2012, 09:17 PM
  #65
FRQ FLYR's Avatar
I think someone may be on "pills"(j/k-PUN INTENDED HERE). Helluva good run and so much the better if on GM tune.
Old 02-14-2012, 09:37 PM
  #66
yamaha288's Avatar
I ran a 12.4 @ 116 on GMS1
plus hpt
Old 02-14-2012, 10:01 PM
  #67
drewbroo's Avatar
plus hpt
This is true!
Old 02-14-2012, 10:02 PM
  #68
drewbroo's Avatar
At 26 PSI on GMS1 tune he is over a full second faster than you and has 10 MPH on ya.... I still think its odd.
Old 02-14-2012, 10:21 PM
  #69
Yeah, for sure. I know 23psi at this altitude isn't quite the same amount of air as a lower altitude as either. Probably more comparable to airflow you'd see at around 19-20psi at an altitude closer to sea level.
FRQ FLYR's GMS1 + bolt-on times seem much more believeable to me. He's only trapping 3mph faster and 5 tenths quicker E/T. It doesn't make much sense to me that a car only running GMS1 can match or out-trap most cars running HPT/Trifecta that are putting down well over 300whp. And trap is more based on power than driver skill, unlike E/T.
Old 02-14-2012, 10:24 PM
  #70
drewbroo's Avatar
Also with a dyno of ~277WHP....
Old 02-14-2012, 10:30 PM
  #71
zrated89's Avatar
dont bother with weight reduction right now, focus on other things like your 60'. Now me i went 12.1 in street trim so i will be doing all i can to hit 11's. so weight reduction will help me. but for you do the other things mentioned first then try wr
Old 02-14-2012, 10:31 PM
  #72
drewbroo's Avatar
Are you running slicks? 1.7 60 foot is beastly
Old 02-15-2012, 02:12 AM
  #73
cranemaster's Avatar
I want an aem intake...thread makes me want more power
Old 02-15-2012, 08:18 AM
  #74
Cobalt08tc's Avatar
I need to go to the track this year for sure.. I have never done it so I'm sure I would have like a 3.0 60' and run a 14.5 lol
Old 02-15-2012, 08:32 AM
  #75
zrated89's Avatar
yea. shaved calipers, 15 inch protocol rims, and a 24.5x8.5x15 slick. Stock axles too i might add
Quick Reply: Fastest GMS1 cobalt
