Figure I can tell you guys now...
#101
Yes built engine and WR-3...also with no E and no meth, on pump gas. Pretty good numbers for a Mustang dyno on a VERY conservative tune. Just cuz the engine is built doesn't mean it will add power. I don't have any head work done that would help with better flow or anything. We will prolly look to do e85/meth in the spring and see where it is at. This is a great turbo, and in all honesty gave me the numbers I wanted to see. I wasn't looking to break and records lol...I was looking for a safely tuned 400HP DD...and that's what I received.
#102
It's ok, if that's the build you planned, but I can tell you that just with my turbo kit and stock engine, I'm putting down 410whp on a conservative tune, that's great for a DD, it has been over a year that I have it and so far I didn't have any problem. I was thinking that to get a fully built bottom engine, you were looking at at least 500whp
#103
#105
Those are pretty solid numbers actually. Especially if its on a mustang dyno. Why is it going to take days to get a sheet scanned and posted? I can do it in less than 5 secs from my phone.
#106
This is probably old but yea It was chiller but if you watch the video he only hits 8 n first gear and somewhere round 7600 n secon and no more than 7k n all the other gears. My opinion is even though e doesn't make more power past 7400 since 1st gear is so short it helps to be that high and then hit second because he would be in a high hp range goin into second and his boost would be close to maxed out
#107
We gotta pull them off the comp and we are a 2 man shop. Sometimes we forget things lol so dave gave him lead way time encase we forget to get them off the comp
#108
#118
Mine lasted and I beat the hell out of it. Not saying it wouldn't of failed eventually but it lasted until the car was totaled. 30k of abuse with over a 100 dyno passes in 3rd and 4th gear. It just never saw slicks or retarded hard launches. I think half of the trans failures are from crappy driving.
Aryton senna....its hard to put a number on a setup. So many variables come into play. You could Max out either one of them turbos but it more then likely isn't going to happen on 93. Not saying it can't happen as I've had one of our evos make 516awhp on the break in pass on 93 with a 3576r but we are talking 2 totally different cars. To be safe e85 or race gas is ideal for high numbers
#119
#121
#123
#124
#125
all i use to do is that im my camaro. i told kyle the story of what happened.... needless to say after awhile of that even with a BUILT T-56 it took its toll sooner or later and nearly destroyed the car and me.
