Forge BPV Group Buy #2!!!
Old 03-14-2011, 10:52 PM
  #476
corn gas ftw....
ssblackstealth's Avatar
its green spring for me with my 23psi tune, have been seeing 25psi spikes now as well....
Old 03-14-2011, 10:58 PM
  #477
SilverSS_TNR's Avatar
Originally Posted by BPacak
not that it matters. but was pretty much all the paint scratched off the springs or was it just me?
yes they were, just enough paint to distinguish between green and yellow
Old 03-15-2011, 12:00 AM
  #478
08inBama's Avatar
yeah I went green and picked up boost as well, holds boost just fine... see no reason for the yellow
Old 03-15-2011, 02:55 PM
  #479
sponge14's Avatar
Originally Posted by Dart_SI
does anybody prefer the yellow spring or is everyone just saying green spring ftw?
Green Spring with Trifecta 21psi flash seems to hold boost just fine so it's green for me...
Old 03-15-2011, 08:57 PM
  #480
ttypecamaro's Avatar
Originally Posted by ttypecamaro
Installed it today. I HP tuned my car to 22psi, so I installed the yellow spring. However, I suspect it is leaking boost because I can hear a very loud and shrill whistle when in boost above 18 psi that didn't exist before. I need to try adding a washer to see if it makes a difference. I have a modified airbox snorkel, K&N drop-in filter, and all else is stock. It does seem a little louder when releasing part-throttle, mid-rpm, medium boost... Otherwise it sounds stock, which is fine by me.
switched to the green spring... the loud whistle went away and the 24psi boost spike came back. Success.
Old 03-16-2011, 12:17 AM
  #481
gdubs's Avatar
Canadain guys. Your valves went out today
Old 03-16-2011, 01:42 AM
  #482
kplaya186's Avatar
Installed mine today! Thanks for getting this done gdubs! Everybody remember to put your o-ring gasket on the BPV! I forgot mine today and re-installed everything and had to take EVERYTHING back out!
Old 03-16-2011, 12:29 PM
  #483
sponge14's Avatar
I don't remember having a separate O ring... Did I mess something up???
Old 03-16-2011, 12:32 PM
  #484
Grishbok's Avatar
no, the o-rings are preinstalled. I was wondering if his got knocked loose during shipping or something.
Old 03-16-2011, 12:35 PM
  #485
corn gas ftw....
yea mine was already on.....lol
Old 03-16-2011, 12:48 PM
  #486
kplaya186's Avatar
Yea mine was in the box. Must have come loose!
Old 03-16-2011, 02:42 PM
  #487
northvibe's Avatar
switched to the green spring... the loud whistle went away and the 24spi boost spike came back. Success.
Ya seems the green is pretty much what everyone should run.
Old 03-16-2011, 03:02 PM
  #488
G Speed's Avatar
dow e have tracking numbers?
Old 03-16-2011, 11:16 PM
  #489
DillySS's Avatar
I put it in today. AWESOME!!! The sound is great and cant believe that we had that peice of junk in there before.
Old 03-17-2011, 02:53 PM
  #490
ronn's Avatar
...and you think this is a good thing?
Old 03-17-2011, 03:13 PM
  #491
northvibe's Avatar
with your tune going that high on boost have you tried the yellow spring or adding in a washer or 2 to the green spring and seeing if the spikes go away?
Old 03-17-2011, 03:35 PM
  #492
drewbroo's Avatar
All tunes are going to spike higher than where they settle. Some even spike to 24 and settle on 18 at the end of the powerband.... its the turbo running out of breath. People are spiking higher and settling higher with this BPV because their wastegate tables were maxed on a leaky BPV. Now since they have a working BPV, its bolting the demanded air loads. A retune will be sufficient, but yes spiking and settling is normal through the midrange. And yea spiking at 25 and settling at 22 is a good thing.
Old 03-17-2011, 06:08 PM
  #493
ronn's Avatar
....uhhhh...yah know boost = BACK Pressure=HIGHER TEMPS... high boost not always a *good thing*. FLOW is a good thing. Spike to 25 is NOT a good thing.
Old 03-17-2011, 06:25 PM
  #494
drewbroo's Avatar
if it was holding 25 PSI, that is 1 PSI about its efficiency range. (that would be a bad thing) Heat does not come from back pressure.... Heat comes from the turbo doing work. If you have no cats back pressure isn't much of an issue. My coupe spikes to 26PSI and holds over 20. I also have IAT's 2 degrees above ambient at a 120MPH. So a lil PSI spike doesn't seem to bother my motor.
Old 03-18-2011, 03:17 AM
  #495
kasper_17's Avatar
dam... missed out.. hopefully another one comes up! and Ill be in!
Old 03-18-2011, 04:38 AM
  #496
Vtec Rep
BPacak's Avatar
if you wanna get one they are only 135 on modernperfomance
Old 03-18-2011, 06:52 AM
  #497
snoftall's Avatar
For some reason the picture that Modern Performance has posted doesn't look the same as what I've seen others post?
Picture from Modern Performance's Website:
Picture from Forge's Website:
Why the difference in the nipple/connector thingy?
Old 03-18-2011, 07:11 AM
  #498
mkulrey13's Avatar
they were redesigned for the roadster i believe as they were hitting something.
Old 03-18-2011, 09:27 AM
  #499
snoftall's Avatar
So this new design should still work for us? It won't cause the hose to have to bend too much to reach the new position and get pinched will it?
Old 03-18-2011, 02:45 PM
  #500
Vtec Rep
BPacak's Avatar
no its good to go. we all got the new version.
Quick Reply: Forge BPV Group Buy #2!!!
