Forge Motorsport BPV Group Buy
Old 12-22-2010 | 04:20 PM
  #251
FRQ FLYR's Avatar
Received
Just want to echo everyone's comments Geoff-way to take the bull by the horns
Old 12-22-2010 | 05:17 PM
  #252
reddevil's Avatar
recieved.. nice job..get well...
Old 12-22-2010 | 05:19 PM
  #253
CudaJoe's Avatar
installed
sounds neat. Sounds alittle bit louder than the stock one to be honest. It also holds boost longer??/ I think that explains its, It exhales for alonger period of time, lol.
I have a youtube video loading right now of me redlining in neutral (not really redlining but a single high rev.)
Old 12-22-2010 | 05:21 PM
  #254
CudaJoe's Avatar
when you take off the stock BPV the rubber diaphragm will be sealed in place.. as soon as you go to take the vacuum line off, it'll shoot the diaphragm and spring, lol. Just be careful. I twisted the diaphragm to break the vacuum seal and remove the spring and diaphragm first.
Old 12-22-2010 | 05:31 PM
  #255
CudaJoe's Avatar
YouTube - Forge motorsport bpv in 09 cobalt ss.
Old 12-22-2010 | 05:35 PM
  #256
murrant22's Avatar
How hard is the install? How long did it take you?
Old 12-22-2010 | 05:43 PM
  #257
DoMiStIc_RuSh_06's Avatar
Originally Posted by gdubs
1st batch of canadian guys. I receieved your valves today in the mail. I was in the hospital over night. I hope to ship them out tomorrow
Also Mike at Forge did a shout out to all CSS.net guys on their FB page
Welcome to Facebook
Check it out
This is great news.... Hope your feeling better soon!
Old 12-22-2010 | 05:49 PM
  #258
CudaJoe's Avatar
like 10 mins
Here it is in steps.
1.) Take off intake and intake snorkel. Make sure to disconnect the MAF sensor and leave it bolted into the intake/ airbox. If you have the stock air box, just remove enough of it to get to the BPV.
2.) Undo the three bolts surrounding the BPV in a triangle style bolt pattern with a 10mm rachet/ screw driving device. Its a difficult angle to work with but I managed to get them all undone with a flexible extension on a screw driver style 10mm rachet.
3.) Remove BPV and use plyers to pinch metal clip that holds the vacuum line on. slide metal clip off of plastic BPV nipple and twist the rubber vac line till it gives and decides to pop off. *WARNING* the diaphragm and spring are under vacuum right now, disconnecting the vac line will break its seal and send the thing shooting out of the stock BPV, lol. Its best to rotate or twist the diaphragm first to break the vac seal and remove them.
4.) put vacuum line on Forge Motorsport BPV and slide metal clip back on using the plyers. Install Forge BPV so that the opening faces downwards.. you'll know what I mean when you look at the thing. Make sure to push the piston in and out so that you know its gonna work and not get stuck before install.
5.) Reuse the stock bolts to mount the BPV back in place. Tighten down who knows how much, I just tightened it Good and tight. lol. Re install intake. connect the MAF.
6.) start up the car and try to notice any difference in the cold start start up I feel it got louder. then go for a gentle test drive getting in to boost lightly at first to make sure its really working.
7.) Done.
Old 12-22-2010 | 05:52 PM
  #259
CudaJoe's Avatar
I will be monitoring my fuel trims just to make sure this thing functions just like the stocker.
Old 12-22-2010 | 05:54 PM
  #260
mongorat427's Avatar
Got mine as well as my TWM shifter today. Ho Ho Ho
Old 12-22-2010 | 05:56 PM
  #261
CudaJoe's Avatar
enjoy the shifter its a nice piece but gets real cold in the mornings if its 30 degrees or colder outside, lol. suggest leaving a sock in the car.
Old 12-22-2010 | 06:40 PM
  #262
09turbo's Avatar
If you guys get any more of the BPV's in PM me a price man, Id love to have one.
Old 12-22-2010 | 06:59 PM
  #263
brainchasm's Avatar
Grrr. Got so many boxes in today, but my BPV wasn't one of them. n:
Ah well, maybe this week still.
Old 12-22-2010 | 07:16 PM
  #264
Yeah. It's either scalding hot in the summer or freezing cold in the winter.
Old 12-22-2010 | 07:29 PM
  #265
army_greywolf's Avatar
my diaphragm was torn, so this saved me some headaches. again, thanks alot gdubs.
Old 12-22-2010 | 07:33 PM
  #266
ronn's Avatar
Hey Joe..
How did the stocker look...how many miles on it? Maybe post a pic if it wasn't pristine looking?
thanks...
Old 12-22-2010 | 09:08 PM
  #267
bobbyhill31286's Avatar
my stocker looked perfect when I put the forge unit in today...then again my car isn't even 2 weeks old yet and only has 700 miles on the odometer
it sounds a lil louder than it did with just an intake
Old 12-22-2010 | 09:20 PM
  #268
efactor's Avatar
which sping is recommmend when pushing 24-26psi? Looking to buy a forge down the road.
Old 12-22-2010 | 10:44 PM
  #269
robk's Avatar
Was sitting on my front porch when i got home, LOOKS LIKE PURE SEX!!!! Only thing that sux is its going to sit around til spring Thanks again Gdubs
robk
Old 12-23-2010 | 01:07 AM
  #270
twiztedblkss's Avatar
any idea for us last 8 guys on shipping?
Old 12-23-2010 | 03:20 AM
  #271
northvibe's Avatar
cudajoe for the sex!
Old 12-23-2010 | 08:42 AM
  #272
CudaJoe's Avatar
Originally Posted by ronn
Hey Joe..
thanks...
My car has 40k miles on it and the stock bpv looked brand new! No need to post pics, mine looks just like bobbyhills
Old 12-23-2010 | 09:11 AM
  #273
Car is asleep for the next 3 months
Old 12-23-2010 | 09:48 AM
  #274
except mine literally is/was brand new lol
Old 12-23-2010 | 10:03 AM
  #275
BYT*SS*TURBO's Avatar
I left the spring it comes with in it. I noticed it did a quick surge once when I was on and off the gas in a weird way, so I won't be trying to the stiffer spring in mine.
Im really liking it so far, it seems to release the air quicker and more precise (if that makes sense). I noticed the car recovers much quicker between shifts. Nothing really performance wise (not that I expecting anything).
Thanks again
