Forge Motorsport BPV Group Buy
Old 12-30-2010 | 06:23 PM
  #326
Iam Broke's Avatar
Yellow spring, some oscillation of the BPV (surge) coming out of moderate boost slowly in higher gears. (12-15 psi)
Only 2-3 oscillations, but still.
I'll put the green spring in over the weekend and see if it does it next week. That is the only place I could make it surge, & I was trying today.
Old 12-30-2010 | 07:17 PM
  #327
Wangspeed's Avatar
You'll see. Green is the way to go. BTW - if anyone should disassemble theirs out of curiosity like I did, you better have some synthetic axle grease on hand. They use just enough, and if you disassemble, it might not have enough anymore. Mobil 1 grease. Oil will swell the o-ring, and stick.
Old 12-31-2010 | 09:46 AM
  #328
Turbalt2010's Avatar
what is exactly oscillation? surging? what makes it oscillate? pring being to stiff?
sorry for being a n00b lol
Old 12-31-2010 | 11:01 AM
  #329
Iam Broke's Avatar
Instead of hearing one dog bark when it opens, it'll yap 3 or 4 times as the BPV opens & closes. Many things can cause surging, too weak or stiff a spring, bad tune, crummy intake.
Old 12-31-2010 | 11:23 AM
  #330
Wangspeed's Avatar
If you hear any surge with the green spring, it probably needs lube.
Old 12-31-2010 | 12:18 PM
  #331
Iam Broke's Avatar
Looks like plenty still there on mine. Maybe they were stingy on yours? IDK.
Old 12-31-2010 | 12:19 PM
  #332
have you ran the green spring yet?
if so hows it compare to the yellow one?
Old 01-02-2011 | 02:31 AM
  #333
ninja44's Avatar
I wonder if brake caliper lube like the permatex synthetic stuff will work or if it is too thick? I only ask because I have a ton of it on hand in my garage.
Old 01-02-2011 | 09:18 AM
  #334
Iam Broke's Avatar
Monday, I've been off of work.
Old 01-02-2011 | 01:58 PM
  #335
Wangspeed's Avatar
I think that's teflon based. I would just use a good synthetic axle grease. Forge recommends Mobil synth axle grease, which is what I happened to use. I tried a number of things in my garage, but most caused the o ring to stick or swell. There was a dramatic difference in the smoothness and ease of use after I put a very light coating of the Mobil on.
Keep in mind though I had disassembled mine multiple times, and some of the grease it came with had been wiped off. I noticed that it was getting a little sticky, so I cleaned and lubed it.
These aren't maintenance free. If you hear surge starting after a few months, it's time to clean and lube. It's likely a once a year thing. Maybe never if you have a bunch of blow by
Old 01-02-2011 | 07:10 PM
  #336
gdubs's Avatar
The rest of the canadain guys. I have your valves and will ship them this week.
Old 01-02-2011 | 07:37 PM
  #337
D-mac's Avatar
Great news dude
Old 01-02-2011 | 08:47 PM
  #338
Originally Posted by CudaJoe
like 10 mins
Here it is in steps.
1.) Take off intake and intake snorkel. Make sure to disconnect the MAF sensor and leave it bolted into the intake/ airbox. If you have the stock air box, just remove enough of it to get to the BPV.
2.) Undo the three bolts surrounding the BPV in a triangle style bolt pattern with a 10mm rachet/ screw driving device. Its a difficult angle to work with but I managed to get them all undone with a flexible extension on a screw driver style 10mm rachet.
3.) Remove BPV and use plyers to pinch metal clip that holds the vacuum line on. slide metal clip off of plastic BPV nipple and twist the rubber vac line till it gives and decides to pop off. *WARNING* the diaphragm and spring are under vacuum right now, disconnecting the vac line will break its seal and send the thing shooting out of the stock BPV, lol. Its best to rotate or twist the diaphragm first to break the vac seal and remove them.
4.) put vacuum line on Forge Motorsport BPV and slide metal clip back on using the plyers. Install Forge BPV so that the opening faces downwards.. you'll know what I mean when you look at the thing. Make sure to push the piston in and out so that you know its gonna work and not get stuck before install.
5.) Reuse the stock bolts to mount the BPV back in place. Tighten down who knows how much, I just tightened it Good and tight. lol. Re install intake. connect the MAF.
6.) start up the car and try to notice any difference in the cold start start up I feel it got louder. then go for a gentle test drive getting in to boost lightly at first to make sure its really working.
7.) Done.
just curious, but why does it have to face down?
Old 01-02-2011 | 10:11 PM
  #339
army_greywolf's Avatar
Because thats where the port is on the turbo.
Old 01-02-2011 | 10:32 PM
  #340
oh ok, thanks
Old 01-03-2011 | 02:47 PM
  #341
Iam Broke's Avatar
Ran the green spring this morning 50 miles, no issues or flutter. I'lll try to flog it some tonight.
Old 01-03-2011 | 02:59 PM
  #342
allright man, im running the green spring right now and seems to be fine for me. i dont really know what to look for but it seems to be boosting nice. so seems fine to me haha
Old 01-03-2011 | 06:35 PM
  #343
Wangspeed's Avatar
This image explains why. Technically it could work facing another direction, but it would be far from optimal.
Old 01-04-2011 | 09:30 AM
  #344
gdubs's Avatar
My last 3 Canadain guys. Just an FYI. I went to the post office this morning and believe it or not their damn power was out. So i was unable to ship them off to you. I will send them out tomorrow morning. I work 00:00hrs to 08:00hrs. So i'm beat and i'm going to bed.
Old 01-04-2011 | 04:50 PM
  #345
D-mac's Avatar
I am one of these Lucky Canucks?
Old 01-04-2011 | 06:14 PM
  #346
r3v07ut10n's Avatar
hmmm... probably in same boat as me... saving the best for last
Old 01-04-2011 | 06:17 PM
  #347
JacBlackSS/TC's Avatar
i heard bobbyhills just wanted to post and say it sounds amazing i'm kinda bummed i missed the group deal
Old 01-04-2011 | 07:45 PM
  #348
bobbyhill31286's Avatar
^ya gotta remember I have an intake too...and that made a huge difference over stock
Old 01-06-2011 | 11:15 AM
  #349
gdubs's Avatar
all bpv's have been shipped! Dont forget!! If you bought one make sure you post on my itrader. Click the link on the left
thanks everyone!
Old 01-06-2011 | 11:36 AM
  #350
northvibe's Avatar
thanks for the return feedback what a smooth and fast GB
