Forge Motorsport BPV Group Buy
Old 03-08-2011 | 09:06 PM
  #401
DoMiStIc_RuSh_06's Avatar
Just out of curiosity, does anyone else notice that when the car sets over night, you start it up and let it warm up then when you start driving and the first time it blows of it had a deep flutter, then after that first initial blow off, its fine and sounds as per normal?
have notices that when it sets like 4 or 5 hrs atleast. Could this be a sign that mine needs to be lubed up? If so what would i use?
Old 03-08-2011 | 09:12 PM
  #402
ssblackstealth's Avatar
corn gas ftw....
im sure one of us from the recent group buy will have that answer in a few days
Old 03-08-2011 | 09:35 PM
  #403
ok cool. Like i say, it only does it the first time it blows off after a cold start then its fine.
Old 03-08-2011 | 09:37 PM
  #404
MastaShaKe_88's Avatar
hmm... anyone else have this happen???^^
Old 03-08-2011 | 09:42 PM
  #405
do you have this issue?
ill see if i can get a vid tomorrow
Last edited by DoMiStIc_RuSh_06; 03-08-2011 at 09:42 PM. Reason: Automerged Doublepost
Old 03-08-2011 | 09:45 PM
  #406
lol I didn't get mine yet...
Old 03-08-2011 | 09:51 PM
  #407
G Speed's Avatar
stock does that too when it's cold
Old 03-08-2011 | 10:35 PM
  #408
yeah, i know but this does it after i let it exit cat warmup mode.
Old 03-08-2011 | 10:55 PM
  #409
G Speed's Avatar
yea.. so does stock .. cat warm up does exactly that just warms up the cat.. you have to wait for the actual car to get warm
Old 03-08-2011 | 11:07 PM
  #410
Yeah, the car is just exiting cat warm up meaning I have been letting it warm up. Usually around 40 degrees Celsius.
Old 03-08-2011 | 11:16 PM
  #411
G Speed's Avatar
not enough... 60 or 70.. shouldn't be hitting boost till it at least get's up to 70
Old 03-08-2011 | 11:20 PM
  #412
I'm not even hitting boost, I'm in first gear taking off from my parking spot lol. Trust me, I let it warm up quite a bit. I'll get a video tomorrow.
Old 03-08-2011 | 11:21 PM
  #413
corn gas ftw....
vid!
Old 03-08-2011 | 11:22 PM
  #414
G Speed's Avatar
to heavy on the throttle.. the only way the car would "blow off" is if you have built boost
and warming it up in an idle state doesn't do anything for the car
Old 03-09-2011 | 12:20 AM
  #415
gdubs's Avatar
The npise your hearing is perfectly normal. Even when I was stock I got that tiny bit of flutter right when I first moved the veh down the road. It quickley diminishes. Its nothing wrong with the BPV as it did it to me with my stock valve all the time.
Also even if you arnt building boost u well hear "blow off" what actually happening is anytime ur car drops back into vaccume it opens the BPV. So all your hearing is air moving through the system. There will alway be air that blows out of the BPV and out of the system
Old 03-09-2011 | 12:22 AM
  #416
gdubs's Avatar
But anywhoo. If u want to lube it you need to use any type of full synthetic greese
Old 03-09-2011 | 12:26 AM
  #417
corn gas ftw....
i was gunn say , but gdubs already did, that mine blows off all the time on cold start up stock, espically during cat warm up.....
Old 03-09-2011 | 12:30 AM
  #418
gdubs's Avatar
Even when your driving. If u listen hard enough. When u let off that gas peddle u will here the valve open and air move. But that initial flutter he's talking about I always get in really cold weather after a long sit and cold start
Old 03-09-2011 | 12:41 AM
  #419
kplaya186's Avatar
How do you get off te vac hose without breaking the plastic BPV?
Old 03-09-2011 | 12:45 AM
  #420
D-mac's Avatar
What grease Forge suggest? or you ?
Old 03-09-2011 | 04:36 AM
  #421
Berto09ss's Avatar
mine comes inn next week so im excited!!
8=====D
Old 03-09-2011 | 09:37 AM
  #422
gdubs's Avatar
Take a set of needle nose pliers and back the clamp off. And they use Mobil 1 full synthetic greese
Old 03-09-2011 | 10:37 AM
  #423
CudaJoe's Avatar
mine blows off when Im slowing down, lol.
Anyone have that happen? slow down sorta quick from 4000rpms or so and when you let off the brake you hear a slight blow off?
Old 03-09-2011 | 10:45 AM
  #424
gdubs's Avatar
Well considering your brake booster operates of vaccume...... sound right.
Old 03-10-2011 | 12:34 PM
  #425
MTE's Avatar
MTE
So I got my Forge BPV installed yesterday, Right after the installation I turn the car on and I can hear boost leak coming from the sides of the valve so I took the car for a ride and correct, the car is only boosting 13 psi on normal tune and 20 psi down from 23 with the trifecta tune! I then let the car cool-down a bit and tighten the valve a bit more but it dint helped much. So I took the Valve off to do some inspections and wow wth, the yellow spring has eaten into valve and the valve itself seems to be bended in bit. So there goes $150, I'm going back to stock or re-tune for an aftermarket HKS Bov.
