Forge Motorsport BPV Group Buy
Old 03-10-2011 | 12:38 PM
  #426
Grishbok's Avatar
Originally Posted by MTE
So I got my Forge BPV installed yesterday, Right after the installation I turn the car on and I can hear boost leak coming from the sides of the valve so I took the car for a ride and correct, the car is only boosting 13 psi on normal tune and 20 psi down from 23 with the trifecta tune! I then let the car cool-down a bit and tighten the valve a bit more but it dint helped much. So I took the Valve off to do some inspections and wow wth, the yellow spring has eaten into valve and the valve itself seems to be bended in bit. So there goes $150, I'm going back to stock or re-tune for an aftermarket HKS Bov.
what in the ..... Ive never heard of that happening on a properly installed valve... ever. Can you take photos and display what is occuring? Did you make sure to install the valve with the oval slit facing down to the ground. and why did you not use the green spring? Yellow spring should only be used if green spring is unable to hold boost.
Old 03-10-2011 | 12:40 PM
  #427
ssblackstealth's Avatar
corn gas ftw....
pics of messed up valve??!!
Old 03-10-2011 | 12:44 PM
  #428
MTE's Avatar
MTE
I will take a pic, I dint get a green spring, it only came with the yellow spring and yes the oval slit was facing down. I guess I'm one of the unlucky ones, I'm not crying or blaming it on a faulty part, I most of gone wrong somewhere during the installation.
Old 03-10-2011 | 12:46 PM
  #429
corn gas ftw....
just contact forge and let em know whats up, they should be able to help in some fashion
Old 03-10-2011 | 12:49 PM
  #430
MTE's Avatar
MTE
Pics will have to wait till I get home tonight, I'm at work now.
Old 03-10-2011 | 12:53 PM
  #431
corn gas ftw....
lunch break.....lol jk jk
Old 03-10-2011 | 12:58 PM
  #432
Grishbok's Avatar
Ok, please do. It could be a faulty part in the sense that its not sitting flush for some reason, but it sounds to me like where the valve and the housing connect the surface is bowed. Overtorqued? If you didn't get a green spring, I would make sure to contact forge, and inform them of your problem. They should send you the green spring or replace the valve entirely.
Old 03-10-2011 | 03:42 PM
  #433
hunter19707's Avatar
I just opened mine up and checked, green spring is there and it is lubed already with a red grease.
Old 03-10-2011 | 05:07 PM
  #434
Are you sure you installed it correctly. If you open up the valve, there should be a green spring inside. No offense, I'm not trying to question your mechanicl skills. I'm just trying to help you troubleshoot.
Old 03-11-2011 | 10:02 AM
  #435
MTE's Avatar
MTE
None taken specially wen it was in fact my fault. There was nothing wrong with the pcs guys, everything was completely my fault. Let this server for reference to everyone else in the future so u don't fail like I did.
As you can see, the green spring was inside the valve, I just dint took my time to open the valve, I just place the yellow spring on the outside just like the stock one sits and put it in the hole and that's why I had the boost leak.
What strikes me the most is that even with the beating this valve took, I lubed it and installed it back on the car and it's working like a champ. Extremely high quality pcs here, I will buy another one for sure.
Lesson well learn. Don't try to install something without reading instructions first.
Old 03-11-2011 | 10:07 AM
  #436
Grishbok's Avatar
omg... Im glad you got it sorted out man. but omg!
Old 03-11-2011 | 10:10 AM
  #437
MTE's Avatar
MTE
I know :-(
Old 03-11-2011 | 10:51 AM
  #438
ctn2mb's Avatar
Lmao dude omg that's too funny
Old 03-11-2011 | 10:56 AM
  #439
I had a feeling that was what you did. Sorry it happened.
Old 03-11-2011 | 01:01 PM
  #440
bobbyhill31286's Avatar
i saw your post about this when i woke up this morning, but didnt wanna make any smartass comments about it....
atleast we all learned something here:
Green spring = good
Yellow spring = good
Both springs = FAIL
lol, jk man
Old 03-14-2011 | 09:29 PM
  #441
northvibe's Avatar
Originally Posted by CudaJoe
like 10 mins
Here it is in steps.
1.) Take off intake and intake snorkel. Make sure to disconnect the MAF sensor and leave it bolted into the intake/ airbox. If you have the stock air box, just remove enough of it to get to the BPV.
2.) Undo the three bolts surrounding the BPV in a triangle style bolt pattern with a 10mm rachet/ screw driving device. Its a difficult angle to work with but I managed to get them all undone with a flexible extension on a screw driver style 10mm rachet.
3.) Remove BPV and use plyers to pinch metal clip that holds the vacuum line on. slide metal clip off of plastic BPV nipple and twist the rubber vac line till it gives and decides to pop off. *WARNING* the diaphragm and spring are under vacuum right now, disconnecting the vac line will break its seal and send the thing shooting out of the stock BPV, lol. Its best to rotate or twist the diaphragm first to break the vac seal and remove them.
4.) put vacuum line on Forge Motorsport BPV and slide metal clip back on using the plyers. Install Forge BPV so that the opening faces downwards.. you'll know what I mean when you look at the thing. Make sure to push the piston in and out so that you know its gonna work and not get stuck before install.
5.) Reuse the stock bolts to mount the BPV back in place. Tighten down who knows how much, I just tightened it Good and tight. lol. Re install intake. connect the MAF.
6.) start up the car and try to notice any difference in the cold start start up I feel it got louder. then go for a gentle test drive getting in to boost lightly at first to make sure its really working.
7.) Done.
@#$@#$@# my sockets wont fit right over the bolts. I think I may have to sand down the plastic part some...did your sockets fit no problem?
Old 03-14-2011 | 09:54 PM
  #442
northvibe's Avatar
HA found that if you push the socket by itself onto the bolt it goes on. Then connect extension and ratchet and your good
Old 03-14-2011 | 10:07 PM
  #443
Omnigear's Avatar
this is a pain in a HHR >_<
Old 03-14-2011 | 10:09 PM
  #444
gdubs's Avatar
OMG DUDE.... Did u watch my video at all? you shoulda seen where the springs go
Old 03-14-2011 | 10:13 PM
  #445
northvibe's Avatar
ya...like when I bought it..haha my boss has my ipad or id have it streaming the video in the garage.
Old 03-15-2011 | 06:12 PM
  #446
Turbalt2010's Avatar
i dont think he was talking to you lol he was talking about the guy that put both springs in with his bpv
Old 03-17-2011 | 04:14 PM
  #447
northvibe's Avatar
oh hahha. Ya this bpv is just like the forge on my ms3...LOVE the quality of these. simple, solid, easy to service and upgrade.
turbochargedss2012
09-20-2023 01:17 PM
01-12-2016 01:01 AM
dennis69
10-20-2015 05:49 PM
OrangeCoba
10-01-2015 11:00 PM
09-27-2015 09:53 PM
