FTW-k04R vs ZFR In need of turbo swap!!
Old 01-16-2015, 05:34 PM
  #1051
KMO43's Avatar
I did some more testing today will post results. But have to talk to matt about adding the mod to the k04r package
Old 01-16-2015, 06:46 PM
  #1052
KMO43's Avatar
I've been talking with Taylor (Infraredline) lately and we came up with an idea to help the K04r hold more boost at redline. Last summer I was fully bolted with 10gph meth and I had a 28psi spike that dropped down to 22psi at 6500rpm. So I've had this idea I have wanted to test for a while but I had to wait for the weather to clear a bit so I could get a log it. I have been running a 15psi tune on 87oct so far through the winter no meth and stock intercooler.
So for my testing today I still had 1/4 tank of 87 and topped it off with 94 so I was around 92 octane. I was trying to see how much boost I could hold not spool or anything else but anyways for the results:
I was seeing an increase in what the turbo would hold up top of around 3psi! And I'm at altitude. It went from just under 22psi to 25psi at 6500rpm. Also I was seeing really good flow even tho I wasn't trying to tune for anything like that. There was slight knock up top but I'm blaming that on the 87oct I still have in the tank so I shut down the testing because I was able to get the results I wanted.
I'd like to put my 3rd brand new intercooler on, throw some E in the tank and up the rev limiter to 7k with more tuning to see how much more I can get out of it but I won't be putting on the intercooler until this spring.
Now I'm gonna talk to Matt about adding this to the K04r and also offer it for guys who already have the K04r on their cars so I'll keep you posted
Old 01-16-2015, 06:52 PM
  #1053
Nice finally some real numbers
Old 01-16-2015, 06:54 PM
  #1054
KMO43's Avatar
Not really, more like a great starting point or numbers for guys on 91oct. I'm kinda excited to push this thing more in the spring or maybe a bit more next weekend on a full tank of 94oct
Old 01-16-2015, 06:57 PM
  #1055
Yeah thats what i mean lol so its showing promise. And yeah all ill get is 91 so testing on that would be great
Old 01-16-2015, 07:01 PM
  #1056
KMO43's Avatar
Next step for me other than to plan to get this out with Matt is to test with some better fuel and the intercooler and see how much more I can get I was around 20* with meth on that 22psi in the summer and only 11* now
Old 01-16-2015, 07:05 PM
  #1057
Yeah im pretty sure you will get great results
Old 01-16-2015, 07:10 PM
  #1058
KMO43's Avatar
Hopefully! This was more than I thought I get today with what I have in my tank
Old 01-16-2015, 07:18 PM
  #1059
SR Tech's Avatar
Got one of these waiting for spring time to get here. Seems pointless to put it on now. I'll be doing a 110oct dyno to see full potential and then a 93 for daily use. Now if it can get above single digits here at some point I'll start getting excited
Old 01-16-2015, 07:24 PM
  #1060
KMO43's Avatar
Single digits of what?
Old 01-16-2015, 07:46 PM
  #1061
Devin86's Avatar
^^^ temperature im thinking
This is cool tho still think im gonna pick 1 up for summer. Good job man.
Old 01-16-2015, 10:14 PM
  #1062
SR Tech's Avatar
Yea dude, it's no Canada, but it's ******* cold
Old 01-16-2015, 10:36 PM
  #1063
nathan112i's Avatar
anyone else buy this turbo other then me and km043? it would be nice to have a few people getting data
Old 01-16-2015, 10:42 PM
  #1064
I really want to get it but things arent to nice atm. maybe by mids of the year ill be able to get it
Old 01-17-2015, 01:35 AM
  #1065
KMO43's Avatar
Yes I'm tuning another guy on one but hes says he has no boost leaks and he's dropping pressure pretty good we're working on it but I wanna get him this mod right away so that he can push it too cause he can get E85
Old 01-17-2015, 06:26 AM
  #1066
mongorat427's Avatar
I just received mine and was planning on installing it when I do my stage 2 ZZP head. Too cold now
Old 01-17-2015, 06:31 AM
  #1067
Im buying a drum of E 100 in the spring and was planning on mixing in 10 percent 93 so I can have a steady exact fuel to work with.
I have the fueling cam , 5th injector ,and Opel injectors right now
I also have a spare fueling cam I will let go for $150. Never used
Old 01-17-2015, 12:55 PM
  #1068
SR Tech's Avatar
It's sitting in my closet patiently waiting for warmer weather
Old 01-18-2015, 03:13 PM
  #1069
T-Man's Avatar
Simple waste gate rod adjustment, KM043?
Old 01-18-2015, 03:35 PM
  #1070
:ninja:'s Avatar
Any idea if running full e85 would work on the LNF using this turbo? I'm In Florida..
Ill also take open injectors, fuel cam & upgraded intank fuel pump will be needed, but not sure if that'll be enough to supply full e85.
Old 01-18-2015, 03:50 PM
  #1071
Terminator2's Avatar
Yes and yes all of those things will be needed.
Old 01-18-2015, 04:07 PM
  #1072
Devin86's Avatar
So what do you think is the max flow rate??
Old 01-18-2015, 05:09 PM
  #1073
KMO43's Avatar
That helps but it's not enough
This is my next step I now think there is more in the turbo Matt and I have been talking about bringing this to the public he's really excited to hear about it. I'll be installing my intercooler and run some E to see what I can get out of it
Old 01-18-2015, 05:18 PM
  #1074
:ninja:'s Avatar
Is the exhaust wheel upgraded in this turbo??
Btw swap out the wastegate for like a forge... Should help.
Old 01-18-2015, 07:08 PM
  #1075
nathan112i's Avatar
i believe its only the compressor side that gets upgraded.
Quick Reply: FTW-k04R vs ZFR In need of turbo swap!!
