FTW-k04R vs ZFR In need of turbo swap!!
Old 03-15-2015, 09:29 AM
  #1276
Terminator2's Avatar
Lets see 30* and 20gph already!
On 99.9% of all setups on LNFs even with E-85 or huge amounts of meth beyond 18-19* up top and 14* midrange is normally pointless. I have done up to 29* up top on cars with no change in 60-100 times or dyno numbers vs 18*. GDI cars are more efficient they do well with less fuel and less timing for maximum power.
Old 03-15-2015, 10:26 AM
  #1277
Im just giving him **** lol
Old 03-15-2015, 12:14 PM
  #1278
Originally Posted by vahdyx
Damn I miss my Cobalt lol. All this new information is great!
It's still doing well
Old 03-16-2015, 02:06 PM
  #1279
InfraRedline's Avatar
I wish 14* was our 91 octane timing here lol, our fuel is so shitty, on the k04 11-12* is about all you get out of the car up top on 24-25 psi. Even bumping to pump E30 took that same car on the same boost to 18* up top. Night and day difference. 30* would be great for the motor What do you think these are, stock turbo Subaru's and SRT4's?! lol
Old 03-16-2015, 02:08 PM
  #1280
r3v07ut10n's Avatar
is that 100% meth or mixed?
Old 03-16-2015, 08:59 PM
  #1281
KMO43's Avatar
60% meth
Old 03-18-2015, 09:50 AM
  #1282
r3v07ut10n's Avatar
wow, that is a lot of water is it not? i run 4x3gph at 100% at the moment. I have been thinking i may drop it down to 75/25
Old 03-18-2015, 12:03 PM
  #1283
T-Man's Avatar
Still waiting patiently...
Old 03-18-2015, 12:13 PM
  #1284
KMO43's Avatar
Waiting for what
My car likes it one day last year I was running 75% and was getting low so I threw some water in and it loved it ever since I've ran the 60%
Old 03-18-2015, 02:54 PM
  #1285
Future SS Owner's Avatar
I'm aiming for 400whp+ this year and I just need to buy a clutch and flywheel before buying the turbo upgrade. I was originally going to get the S20G but I'm having second doubts, what's the best bang for your buck that won't destroy my tranny? I was thinking about the S256 extended tip but I didn't know if I would need to buy a new downpipe/if I would need to run a wastegate with it.
Old 03-18-2015, 03:20 PM
  #1286
KMO43's Avatar
If you go with the 256et you need hot and cold pipes, bov, exhaust manifold and a downpipe. I'd buy the 6758 or 7163 ZFR over the 256et
Old 03-18-2015, 03:32 PM
  #1287
The hell with that, my biggest worry about both the 6758 and 7163 ZFR is them being known for eating trans. I'm assuming I would need to get 4.45 gears from Mongo asap after install
Old 03-18-2015, 03:42 PM
  #1288
T-Man's Avatar
Originally Posted by KMO43
Waiting for what
My turbo(s)
Old 03-18-2015, 03:49 PM
  #1289
soundjunky's Avatar
umm, Kevin, correct me if I'm wrong here;
But iirc the tune and clutch would be more responsible for destroying an F35 than the turbo...
Some guys are starting to come around and advocate using the GMPP clutch simply because it will slip and "save" your transmission over a clutch with too much bite grenading it...
@ "Future" (wow talk about a user name that's dated!) a local has a ZFR, K&N SRI, and the other common mods, and dynoed at over 400whp...
His car is pretty sedate, it was also tuned by a guy in our state who I have heard some concerning (to me) info on...
Considering what Kevin has been posting about this turbo, is almost reads like the ZFR has been made obsolete...
Old 03-18-2015, 03:54 PM
  #1290
Yeah I know haha made the username when I had a Cobalt LT hahaha
I know with the ZFR I would make over 400whp but I just wasn't sure if the s256et was a better bang for your buck or not since it's $800 cheaper than the 6758
Old 03-18-2015, 07:27 PM
  #1291
KMO43's Avatar
My turbo(s)
Nice are you gonna run them on E?
No the ZFR is still way more turbo than the K04r but it's a really good bang for the buck that's for sure
Either put one of those boost ramp things on and you should be OK if you get the 7163 it'll spool a bit slower so that and a boost ramp should be OK
Old 03-18-2015, 10:21 PM
  #1292
I'm taking it to PSI Proformance for the dyno tuning whenever I do decide which turbo I want
Old 03-19-2015, 12:03 PM
  #1293
T-Man's Avatar
Yep, I run E30 and the other car runs 1:1
Aside from convenience, there is literally no difference between my car and the other in terms of what the car will safely take with these ethanol percentages. My car is running 21* up top and is fed in rather quickly while running 21lbs (really small spike to 22 briefly).
I'm hoping that I won't need to push the K04R much past 24-25lbs for what I'm after.
Old 03-19-2015, 12:20 PM
  #1294
What did you multiply your injector constant by for E30? I'm planning on switching E30 or E47 in the next month or so
Old 03-19-2015, 01:26 PM
  #1295
T-Man's Avatar
9.5% and the rest is corrected through the MAF correction table. I don't touch the MAF frequency.
Old 03-19-2015, 01:34 PM
  #1296
KMO43's Avatar
If you can tune it to hold 25psi at redline like I did with E you'll be able to run more timing than I do have lower EGTs and make more HP. With it holding like it does now for me it's a huge difference than what I was running before on the stock K04
Old 03-19-2015, 02:13 PM
  #1297
I've read through the ethanol threads on hptuners, just couldnt remember the E30 injector adjustment. Just about threw some E85 in last night to get to E30, but I think I have a boost leak I need to fix...
Old 03-19-2015, 05:44 PM
  #1298
breds2k's Avatar
Wanted to jump off a cliff after page 20.....Not ready through any more whining, did this ever get dynode? I saw one that was like 18 hp increase but help 50whp more towards redline
Old 03-19-2015, 11:54 PM
  #1299
Wert842's Avatar
nope
Old 03-20-2015, 08:32 AM
  #1300
breds2k's Avatar
damn I got so excited. Wanted to run a 30psi tune just to kill my stock turbo for fun and get this.....(that's like 20% serious)
Quick Reply: FTW-k04R vs ZFR In need of turbo swap!!
