FTW-k04R vs ZFR In need of turbo swap!!
Old 05-03-2015, 07:33 PM
  #1426
09CobaltSS1's Avatar
Screenshot of logs?
Old 05-03-2015, 11:24 PM
  #1427
Omiotek's Avatar
Originally Posted by nathan112i
i could see up to 380 but 400 is probably out of the question with how small the turbine/housing is
we stuffed a 5431 into a k04 housing... made 415- 420whp on a solstice....i cqnnot remember the exact numbers but it had full bolt ons and methonal injection but no cams. downside is it wouldnt hold the power passed 6200-6500 due to the smaller compressor housing. anyhting is do able but like other turbos out there what good is it if you cant hold the power very long.
Old 05-04-2015, 10:32 AM
  #1428
Terminator2's Avatar
Originally Posted by 09CobaltSS1
Screenshot of logs?
Not anymore lol. It was Forty's sky actually. Thing ran 1.7 60-80 and 2.1 80-100. He had to rev to almost 7400 in 3rd to get to 100 on the sky which was not helping the 80-100 time lol.
Old 05-04-2015, 12:25 PM
  #1429
KMO43's Avatar
Ya I can hold the boost past 6500 but it just doesn't have the flow so there's no power up there so I shift at 6500rpm
Old 05-08-2015, 01:17 PM
  #1430
T-Man's Avatar
Received one of my turbos from Matthew yesterday. Will be installed within the next week or so. Still rounding up the necessary gaskets and have new widebands coming too. Turbo is literally brand new... No crack in the divider etc. Upgraded WG canister looks slightly larger too.
Results on the old man's ride (runs an ethanol blend) soon!
Old 05-08-2015, 06:52 PM
  #1431
SR Tech's Avatar
I've been super lazy, mine is still sitting in my basement. Maybe one day...
Old 05-09-2015, 11:05 AM
  #1432
nathan112i's Avatar
^do it!
Old 05-09-2015, 02:32 PM
  #1433
SR Tech's Avatar
When I switched to E I picked up a decent boost in power, just enjoying that for now lol.
It worries me that you've had yours on for a couple months and you already are switching the new ZFR.
Old 05-09-2015, 03:02 PM
  #1434
KMO43's Avatar
Nathan wants 400hp but with the fuel he has on the island he has to run 4° timing on the k04r because it is e0. So he swapped to the 7163 so he can run it very mild on that shitty fuel and make 400hp. If he could get e85 like you Americans I bet he would have stayed
Old 05-09-2015, 03:04 PM
  #1435
KMO43's Avatar
And it's a $1700 difference. You can not compare the 2 turbos
Old 05-09-2015, 09:29 PM
  #1436
SS4speed's Avatar
Got my k04r final tune today and you will not be disappointed in it. Pulls great all the way to 7k
Old 05-10-2015, 12:29 AM
  #1437
Jn2
Jn2's Avatar
do you have a log? how much air? 38,39, 40lbs/min?
Old 05-10-2015, 12:33 AM
  #1438
KMO43's Avatar
Originally Posted by Jn2
do you have a log? how much air? 38,39, 40?
Wow why r u so cheap?? Just buy one it's only $600!
Old 05-10-2015, 12:46 AM
  #1439
Jn2
Jn2's Avatar
Nohing to do with money. It a pretty cheap upgrade. My intercooler cost more than that turbo does hahaha...
Old 05-10-2015, 12:52 AM
  #1440
KMO43's Avatar
Then just buy it. I'll tell u I'm in the numbers u asked on pump
Old 05-10-2015, 11:32 PM
  #1441
nathan112i's Avatar
I never felt ripped off with the k04R, there was definitely horsepower gains over the stock turbo. as km043 has stated i live in a place that has 91 octane or less equivalent gas at sea level. i got bored of the power and ultimately had a choice to make, stay with the k04r and add meth injection or go with a bigger turbo and keep things simple. i though it would make more sence to run a big turbo at 60% then to try and push a small turbo for all it has(given my fuel crisis).
Old 05-11-2015, 07:03 AM
  #1442
SS4speed's Avatar
Some people have a hard time listening.
Old 05-11-2015, 10:02 AM
  #1443
KMO43's Avatar
Yes there hasn't been too many good dynos on the K04r out there but everyone who has one says they're happy with it so wouldn't that be good enough??
Old 05-11-2015, 10:09 AM
  #1444
Don't forget this is the cobalt crowd, they're mostly cheap bastards who think spending $2000 on a new ball bearing turbo is expensive, so the $600ish for the k04r is still expensive because well my car already has a k04 and I don't understand what holding boost through 7k means
Old 05-11-2015, 12:10 PM
  #1445
KMO43's Avatar
Ya I know I thought that first dyno was good enough on a very mild tune you saw him pick up 20hp+ above 5000rpm
Old 05-11-2015, 01:20 PM
  #1446
T-Man's Avatar
This car made 371/383 and picked up power everywhere on 93 octane. Broadened power band too. If the K04R is bigger, I expect at least 385-390whp on ethanol.
https://www.cobaltss.net/forums/dyno...esults-316888/
Old 05-11-2015, 02:32 PM
  #1447
KMO43's Avatar
The big gain there was on the topend and the peak came at 250rpm later on dropping to 21psi too! So with the actuator and E there will be great gains when you can hold that 24 or 25psi all the way to 7k
Old 05-11-2015, 03:22 PM
  #1448
T-Man's Avatar
Yep, that's what I liked the most and what sold me on the K04R from the original results dyno I saw. Then these K04+ results really cemented my thoughts that the K04R would be perfect for what I'm after. Power stayed strong down low and shifted/broadened the power band. I'll probably bump redline on both cars to 6800ish.
No reason to believe this turbo won't be capable of carrying at least 370ish to 6800 or so.
Old 05-24-2015, 03:27 PM
  #1449
murlin15's Avatar
I'm on E with a updated 24psi tune till I put sensors on and I love it pulls so much harder and smoother and I can actually can use second gear and get full boost till 7k!!
Old 05-26-2015, 03:09 PM
  #1450
T-Man's Avatar
Turbo was well worth the wait! Gains were HUGE throughout the PB and peak!
Here's the results thus far. Need to adjust the WG rod for more boost as I refuse to crank on the WG solenoid via HPT past a certain point. Currently sitting at 23psi, 20* of timing and just bumped mid-range timing up significantly (no new numbers). Updates to come after we get the WG adjusted properly. I'm estimating at least 380whp.
Also, ran a lightly modded V2 CTS-V auto and was able to pull 2-3 cars by 125 (No NLS) from about 40mph or so on the stock turbo tune while data logging
All graphs posted are from Virtual Dyno and were run on the exact same road.
Here's the transformation of the car. Please do remember that I use a pretty significant torque modulation strategy or "boost ramp" to try and keep the clutch and transmission happy on ALL of the graphs below.
Pump gas tune was 12* of timing and 22-23psi
E35 tune was 22* of timing but weak mid range and 22-23psi
K04R tune is 20* of timing, same weak mid range and a solid 23psi
91 oct intake, DP and tune vs E35 tune (weight is more because we were both in the car)
Untuned K04R vs Tuned K04R vs E35 Stock turbo
Tuned K04R vs 91 octane intake, DP and tune
Attached Thumbnails e35-i-dp-t-v-91-i-dp-t.jpg   k04r-e35-v-91-i-dp-t.jpg   k04r-tuned-v-k04r-untuned-v-e35-i-dp-t.jpg
Quick Reply: FTW-k04R vs ZFR In need of turbo swap!!
