FTW-k04R vs ZFR In need of turbo swap!!
#1710
Well I won't be dyno'n anytime soon
I think the seals went out. When I remove the intake there was a nice puddle of oil in the compressor housing. Started the car with MAF unplugged and oil started leaking out into the compressor housing. The blades on the wheel looked perfectly fine. So it may just need a rebuild
#1717
A local guy has mine that one was Nathan's
#1721
So you have dyno' it already? Or are you just going off an app? 390 may be possible but probably not real healthy. I put 372 down on a ko4+ on a conservative tune on e47. I don't think there is much to gain on the r over the + even though it's got a slightly bigger wheel. The compressor housing is just too small.
#1723
thats sad to see it didnt last long, that turbo was only on my car for a handful of months running 26psi before i took it off. hopefully you can get it rebuilt for cheap
#1725
Found out that my K04R has a small coolant leak from the coolant plugs nearest the exhaust manifold.
Anyone have any tips on whether the exh. manifold heat shield can be loosened and moved enough to access these plugs without having to pull the turbo? I haven't had any time to tinker with it and would just like to know what I'm getting myself into prior to digging in.
Edit - It needs to be noted that I take responsibility for this as I should have checked the plugs prior to installation.
Here's what I'm referring to -
