FTW-k04R vs ZFR In need of turbo swap!!
#1729
Found out that my K04R has a small coolant leak from the coolant plugs nearest the exhaust manifold.
Anyone have any tips on whether the exh. manifold heat shield can be loosened and moved enough to access these plugs without having to pull the turbo? I haven't had any time to tinker with it and would just like to know what I'm getting myself into prior to digging in.
Here's what I'm referring to -
#1731
You may get lucky and just be able to tighten it but they are in there super tight so it may need to come out.Also the ZFR has the plugs in different spots
#1732
Matthew @turbobay
#1734
Also, it should be noted, I take responsibility for this and my original post on this matter will be edited to reflect this. I should have checked the plugs while I was transferring things over from the stocker.
#1735
I also could be mistaken but i believe Juan had a boost leak I remeber him replacing all the clamps on his piping. Boost leaks kill turbos
#1739
Woahhh 70 pages posts... So then did a dyno run stock k04 and k04ftw was posted to see the gain?
So you guys still recomand the ftw? I have seen the core charge to go from 150 to 250 planning to keep my stockie that is well running still worth it ?
Opinions and advices are welcome
#1740
#1741
#1742
#1743
Matt has a big account that takes up most of his time but he still tries to get themnout fast
#1744
I go with max octane here bad things is it is 91 :p And i am trifecta tuned dp k&n typhoon intake and thats it. Car is pulling hard on the tune at 25 psi peak
#1745
The big difference is with the actuator upgrade to be able to hold boost. I was able to hold 28psi at 7k but i do not recommend that on 91 octane
#1746
I have a bit of a BF leak there will be a deal on the R!
#1748
