FTW-k04R vs ZFR In need of turbo swap!!
Old 11-10-2015, 11:18 AM
  #1726
Damn another k04r down
Old 11-10-2015, 11:23 AM
  #1727
T-Man's Avatar
It's extremely minute but I'm not fond of the smell of burnt coolant
Old 11-10-2015, 11:29 AM
  #1728
Lol no one is I'm sure you can fix it but that sucks man Goodluck maybe kmo can let you know since he's a pro at changing turbos now lol
Old 11-10-2015, 02:55 PM
  #1729
Jn2
Jn2's Avatar
Originally Posted by T-Man
Found out that my K04R has a small coolant leak from the coolant plugs nearest the exhaust manifold.
Anyone have any tips on whether the exh. manifold heat shield can be loosened and moved enough to access these plugs without having to pull the turbo? I haven't had any time to tinker with it and would just like to know what I'm getting myself into prior to digging in.
Here's what I'm referring to -
I can reach those on mine quite easily with the shield removed, but I'm RWD. Might not be as easy for you.
Old 11-10-2015, 02:56 PM
  #1730
Jn2
Jn2's Avatar
Originally Posted by nathan112i
thats sad to see it didnt last long, that turbo was only on my car for a handful of months running 26psi before i took it off. hopefully you can get it rebuilt for cheap
Yeah, I had it on 26psi as well. Buddy of mine contacted TurboBay for me and they offered to rebuild it for a reasonable price
Old 11-10-2015, 03:38 PM
  #1731
KMO43's Avatar
You may get lucky and just be able to tighten it but they are in there super tight so it may need to come out.Also the ZFR has the plugs in different spots
Old 11-11-2015, 09:17 AM
  #1732
TMATT4's Avatar
Yeah that is just a plug all of the k04s have them. Try tightening that all it needs. So far on the K04r that is having issues we have already talked about inspecting it. Waiting for Turbo to be sent in. I run the same Turbo on my personal car at 25lbs daily and no issues for the past several years. We stand behind our products.
Matthew @turbobay
Old 11-11-2015, 12:53 PM
  #1733
Cool nice to see the guy behind the k04r here
Old 11-11-2015, 01:33 PM
  #1734
T-Man's Avatar
Thanks for rubbing it in on both fronts - RWD and ease of access!
Originally Posted by TMATT4
Yeah that is just a plug all of the k04s have them. Try tightening that all it needs. Matthew @turbobay
I'm hoping that I can just loosen the exhaust manifold heat shield to allow enough space for me to tighten them down. Seems as though it's only the lower plug. The last thing I want to do is remove the turbo just to tighten the plugs.
Also, it should be noted, I take responsibility for this and my original post on this matter will be edited to reflect this. I should have checked the plugs while I was transferring things over from the stocker.
Old 11-11-2015, 06:43 PM
  #1735
KMO43's Avatar
Haha i called him
  #1736
Haha nice good call
Old 11-11-2015, 06:47 PM
  #1737
KMO43's Avatar
I also could be mistaken but i believe Juan had a boost leak I remeber him replacing all the clamps on his piping. Boost leaks kill turbos
Old 11-12-2015, 05:02 PM
  #1738
Jn2
Jn2's Avatar
Yeah, the cold pipe was leaking where it meets the intercooler. Ended up replacing all the clamps with T clamps to fix it.
drocker (06-14-2017)
Old 11-24-2015, 07:00 PM
  #1739
SS_2009_TC's Avatar
Woahhh 70 pages posts... So then did a dyno run stock k04 and k04ftw was posted to see the gain?
So you guys still recomand the ftw? I have seen the core charge to go from 150 to 250 planning to keep my stockie that is well running still worth it ?
Opinions and advices are welcome
Old 11-24-2015, 07:07 PM
  #1740
KMO43's Avatar
I ran mine super hard for a year and loved it. Yes i would buy it. What fuel are you planning on running?
Old 11-24-2015, 08:35 PM
  #1741
Jn2
Jn2's Avatar
Buy it, I went back to stock bc mine blew and the car feels so much slower...
Old 11-24-2015, 11:19 PM
  #1742
stealthsky's Avatar
I just installed one in my Sky and so far I like it alot. Just be prepared for a possible long wait, mine took just over three months to arrive.
Old 11-24-2015, 11:41 PM
  #1743
KMO43's Avatar
Matt has a big account that takes up most of his time but he still tries to get themnout fast
Old 11-25-2015, 09:51 AM
  #1744
SS_2009_TC's Avatar
I go with max octane here bad things is it is 91 :p And i am trifecta tuned dp k&n typhoon intake and thats it. Car is pulling hard on the tune at 25 psi peak
Old 11-25-2015, 10:51 AM
  #1745
KMO43's Avatar
The big difference is with the actuator upgrade to be able to hold boost. I was able to hold 28psi at 7k but i do not recommend that on 91 octane
Old 11-25-2015, 06:10 PM
  #1746
KMO43's Avatar
I have a bit of a BF leak there will be a deal on the R!
Old 11-26-2015, 07:08 PM
  #1747
So it's official instead of zfr 7163 I'm going to go with a k04r and run it with e47
Old 11-26-2015, 07:42 PM
  #1748
KMO43's Avatar
Nice that'll be a fun car!
Old 11-26-2015, 07:54 PM
  #1749
Heck yeah you know I will be contacting you for tuning
Old 11-26-2015, 07:55 PM
  #1750
double clutch's Avatar
Deals you say? Interesting
Quick Reply: FTW-k04R vs ZFR In need of turbo swap!!
