FTW-k04R vs ZFR In need of turbo swap!!
#1854
I've done the swap 4 time so far
#1858
The first one i did took 2 days and the 7163 took me 2 days because it's not a zfr and i had to fab up some stuff and clock the turbo
#1859
i think it took me around 8 hours to do the k04r swap, it wasn't too bad really i was just inexperienced working on the car so it was a learning curve. bring a buddy and some beer.
make sure you have
-coolant
-banjo bolt washers
-turbo gasket
-penetrating oil
-torque wrench
-oil to top up what drains out
make sure you have
-coolant
-banjo bolt washers
-turbo gasket
-penetrating oil
-torque wrench
Snail_SS (12-15-2015)
#1860
Yeah that's what I was going to be asking what other parts I needed to do the swap. Where can I get the banjo bolt washers? Any particular size I need to use?
Well the swap I'll be doing myself more than likely, maybe I'll ask a friend or let's see if Jesse wants to give me a hand lol
#1861
https://www.cobaltss.net/forums/how-...allion-287559/
Coolant Banjo Washers - 12626102 (3 are needed)
Turbo Oil Return Gasket - 12589435
Turbo Mounting Gasket - 12618586
this is a great write up and you can follow it pretty closely in the removal part, you do not need to take the exhaust manifold off as you will not be running into the issues with the turbo not fitting on correctly. the turbo and the 02 housing can and should come out and can go back in as a unit and i would suggest doing so.
#1863
