FTW-k04R vs ZFR In need of turbo swap!!
#2102
I used to rev to 7k max it pulled pretty good even with a stupid dirty air filter
#2106
The actuator is not needed for 91 therefore a waste
#2108
Mine is back home which is 7 hours away but is cheaper than here and are great guys so i dont mind going there
LNFwagonSS (02-05-2016)
#2117
403/412 on my test stretch today... Ended the run at 6300 with 371whp.
23.94 psi, 20* of timing up top, E40 blend. I don't think more boost is going to do much.
Also, FWIW the car goes from vacuum to 20lbs of boost in .64 seconds
I know, I know "But bruh, it's not a REAL dyno. It doesn't count". In due time... New job consuming me at the moment.
#2119
Ya on 91 it's hard to get a good amount of timing in there so adding more boost just isn't a smart idea. You could always buy a meth kit. On my R with 94 and meth I ran 19°
#2122
Nice i should have it pretty soon, I'm waiting on some gaskets and hptuners to arrive. Go dyno what I have atm then dyno the k04r with e47 blend. If Kmo43 is available to tune next weekend I might take everything off Friday afternoon and reinstall everything on Saturday morning.
I found a shop where I should be able to dyno but still need to ask for how much
#2123
KMO43 (02-05-2016)
#2125
Are you worried about an air lock?
