FTW-k04R vs ZFR In need of turbo swap!!
#2176
It's all in the 60' really. Last year on 17x26 Hoosier DRs, my 12.8 run was 2.1 60' with 8.4 1/8 time on that run. Best 1/8 was is 8. 2 with a 2.0 60' at local track so it has a tenth or two more. This is all with 445 trans. Keeping the control arms from moving is huge as well as a stiff rear(drag bags) This year I will be limiting front and rear suspension travel and just purchased 15x24.5 slicks and going back to 4.05 trans. Even without the R i would expect low 12s on the new setup. A 2step is a must have, then you have to set it up for avail traction and when you want it to disengage so you don't have to dump the clutch. 2nd gear burnouts are also a must with slicks and most DRs.
What rpm are you leaving at?
What drag bags are you running? I heard you had to cut the spring perches to run them and I didn't want to cut on the car to do it. Sorry for the questions. I also have drag radials but they aren't as good as yours. Thinking about the 2 step, but I can't get traction all the time coming off the line as it is now with no boost. Thinking I maybe riding clutch too long.
#2179
Why are you going away from the 4.45? Did you like it?
The 245/45/17 Hoosier DRs fit no problem with the right wheel. I was using 17x8 wheel w 40 offset. I'm hhr tho but fitment should be identical as far as the spring perch, no modding/cutting needed. I'm leaving around 33-3500rpm on the wot box slipping the clutch. Tire pressure between 14-17psi before burnout. Hope this helps...
Getting off track here... Snail! That bitch is gorgeous! Why not mount her up now?
KMO43 (02-10-2016)
#2180
445 was fun and it didn't blow up so that's good. Sooooooo many launches and low RPM 3rd gear pulls with that trans and it held and held and held together pull after pull and launch after launch but damn the gearing is just way too damn short for what I want to do with the car. Not to mention the rollout with 24.5 tires would make the gearing even shorter. And 445 tops out around 140 with normal rev limit and stock tire size.
He's planning it out so he has a couple days to do the swap it's his first time swapping a turbo. Sat is the day
#2182
I disagree mine was a gen1 and I still think mine was the most bad ass out of every setup I've seen so far
#2184
How much MAF skew is built into that? If you're skewing the MAF far enough, you've likely inflated that number quite a bit. That's 6758/Ethanol territory and I just don't see that happening with the R.
FWIW, my 400whp V-dyno run was 34.x VE flow with the factory MAF frequency table and very little MAF correction. Fueling is handled via the injector constant
#2186
Very close to the same my meth screws with my MAF flow. It was years back now. I prob posted a log in here
#2189
On pump gas with stock intercooler and stock exhaust on a really hot day I did 360/370 on my cobalt with the 7163...
of course now I dont how stock inter cooler and exhaust ahhaha.. so il have new pump gas results this summer
looking for 410 wheel on husky 94
#2190
I thought you were selling your car? If not I'd love to see your tune
#2192
I do not change the injector constant when I do meth tunes because 90% of the time you are driving without meth but since I was spraying so much it was a big difference
#2195
Look at the diff in INJ ms between the 2 no meth 5.7ms with 4.5ms!! I have actually never looked at that side by side before but knew I was getting additional fuel so I hope I can run up to E70 this year if I so choose
#2196
What are you talking about MAF doesn't do VE airflow
#2197
I'm always game for a respectful discussion I didn't think you were being a dick
#2198
Are you running stock high load cam numbers? Doesn't look like it?
E70 is going to be tough without some serious help. MORE METH!
#2199
Of course, that should be left to those running ethanol. So if you're using the MAF frequency and MAF correction to adjust things, that's where the skew comes into play.
#2200
"if you're going by MAF airflow, those numbers are practically meaningless. I can tune a car with a stock turbo that will show 65 lbs/min on MAF airflow. Does that mean it should be putting out around 650hp? No. MAF airflow is the actual sensor value AFTER it is run through the MAF calibration and compensation tables. VE airflow is basically the speed density/open loop calculations. Both of those can be skewed drastically"
Simply put, if you're altering fueling via MAF frequency (especially this one) and MAF correction, you are skewing (in a positive direction) the readings. This is why it cannot be compared car to car/ tune to tune. Every car/tune is different.
