FTW-k04R vs ZFR In need of turbo swap!!
Old 04-02-2016, 08:03 AM
  #2376
Lmao yeah are you giving Nathan a few passes already?
Old 04-02-2016, 02:30 PM
  #2377
ae_xiong's Avatar
Originally Posted by KMO43
I raced a bolted TC yesterday gave him the hit and by the end of 3rd I was 10 cars ahead. What do u want me to do?????
I want u to run more v8's! Stop picking on the bolt-on 4 bangers.
Old 04-02-2016, 04:47 PM
  #2378
KMO43's Avatar
Prob 1 or 2 not thst bad
That's the plan!
Old 04-04-2016, 06:31 PM
  #2379
T-Man's Avatar
Ran a 4.64 second 60-100 with my modded airbox/zzp intake tube - 19* timing, 23lbs of boost, .88 lambda, 81*F ambient temps. Very mild calibration but it's getting warmer and I'm erring on the side of caution
Will report back on my K&N SRI 60-100 time as soon as the MAF recalibration is complete. Hoping to be in the low 4.5 second range as I picked up quite a bit of power based on V-dyno logs, in warmer weather! Showing less VE and MAF flow too
LNFwagonSS (04-05-2016)
Old 04-06-2016, 01:06 PM
  #2380
Shane H's Avatar
Hey guys quick zfr question figured this would have the highest concentration of 6758 tuners and users. What psi are you guys running your turbos at on 93 with full bolt ons?
Old 04-06-2016, 07:09 PM
  #2381
KMO43's Avatar
26 to 28
Old 04-06-2016, 07:35 PM
  #2382
LNFwagonSS's Avatar
Looks like my R will be here tomorrow or Friday! Dyno tuning here in a few weeks with the magician, Area 47
Old 04-06-2016, 08:35 PM
  #2383
Nice i wish I could of gotten the results but my car is taking the timing and boost like a bitch. Does great and when we are almost done kr on the top end
Old 04-06-2016, 08:41 PM
  #2384
63 Nova SS's Avatar
Still waiting on mine. Said it was to ship end of last month.
Old 04-06-2016, 08:43 PM
  #2385
He's pretty busy kinda hard to get ahold of him
Old 04-07-2016, 12:51 AM
  #2386
Perks of living close to Area, I'd bet you'll end up with the highest numbers if you ask him to push it.
Old 04-07-2016, 01:06 AM
  #2387
LNFwagonSS's Avatar
Yea I'm lucky for sure. And it will be maxed out in one way or another.
Old 04-07-2016, 01:08 AM
  #2388
LNFwagonSS's Avatar
I've been waiting over 2 months but I told him I wasn't in a rush and said to take his time because I knew he had a lot going on.
Old 04-07-2016, 01:22 AM
  #2389
Shane H's Avatar
26 to 28
Thanks!
Old 04-11-2016, 02:25 PM
  #2390
LNFwagonSS's Avatar
Got my car all tore down this weekend. Pulled out the trans, IM, injectors, stock turbo, and had enough time to mount the R. That thing is sweet. I hope it performs as well as it appears.
Note... That pcv plug that bolts onto compressor housing inlet obstructs airflow slightly with the R because the inlet is machined much wider. So I went ahead and machined the plug so it mounted flush with inner wall of the compressor inlet. Sorry guys I should've taken a picture but I was trying to get it done.
Old 04-11-2016, 09:47 PM
  #2391
KMO43's Avatar
I did that too on mine
Old 04-11-2016, 10:13 PM
  #2392
LNFwagonSS's Avatar
Yea, there is plenty of extra material on that end of the plug so it just made sense.
Also got some new couplers and vac line on the way from treadstone. For the the turbo swap, i used the parts list detailed earlier in this thread except I also bought new crush gasket for both ends of 02 housing. I wish I would've gotten one more of the oil/coolant line gaskets though. I bought 3, could've used 4 since I decided to remove all the lines to check for any build up and/or flow restrictions.
Old 04-30-2016, 01:31 PM
  #2393
LNFwagonSS's Avatar
Heading to get dyno tuned today. Hopefully clutch doesn't slip. Didn't have time to break it in much. Brand new ky stg3 6 pick with stg 4 pressure plate and new flywheel.
BTW, this turbo is definitely louder.
T-Man (04-30-2016)
Old 04-30-2016, 01:33 PM
  #2394
Nice good luck I think mine might be broken....
You can hear the sound in the first 10 secs
Old 04-30-2016, 01:52 PM
  #2395
LNFwagonSS's Avatar
Damn snail, wtf man. That doesn't sound very good. Is it still making commanded boost?
Old 04-30-2016, 02:31 PM
  #2396
It is,but to me it feels slower than at first for sure
Old 04-30-2016, 03:40 PM
  #2397
T-Man's Avatar
I don't have this issue and neither does my Dad. Then again, we aren't trying to push more than 23-24lbs either....
Old 04-30-2016, 03:41 PM
  #2398
T-Man's Avatar
Good luck man. Keep us posted
Old 04-30-2016, 04:22 PM
  #2399
I'm not running alot of boost for the same reason that I've never been able to finish off the tune. Always had the first pull clean of kr then after that any pull will have kr
Old 04-30-2016, 10:09 PM
  #2400
3-UP's Avatar
So how did you make out today wagonSS
Quick Reply: FTW-k04R vs ZFR In need of turbo swap!!
