FTW-k04R vs ZFR In need of turbo swap!!
#2378
Ran a 4.64 second 60-100 with my modded airbox/zzp intake tube - 19* timing, 23lbs of boost, .88 lambda, 81*F ambient temps. Very mild calibration but it's getting warmer and I'm erring on the side of caution
Will report back on my K&N SRI 60-100 time as soon as the MAF recalibration is complete. Hoping to be in the low 4.5 second range as I picked up quite a bit of power based on V-dyno logs, in warmer weather! Showing less VE and MAF flow too
LNFwagonSS (04-05-2016)
#2380
Hey guys quick zfr question figured this would have the highest concentration of 6758 tuners and users. What psi are you guys running your turbos at on 93 with full bolt ons?
#2381
Got my car all tore down this weekend. Pulled out the trans, IM, injectors, stock turbo, and had enough time to mount the R. That thing is sweet. I hope it performs as well as it appears.
Note... That pcv plug that bolts onto compressor housing inlet obstructs airflow slightly with the R because the inlet is machined much wider. So I went ahead and machined the plug so it mounted flush with inner wall of the compressor inlet. Sorry guys I should've taken a picture but I was trying to get it done.
#2391
#2392
Yea, there is plenty of extra material on that end of the plug so it just made sense.
Also got some new couplers and vac line on the way from treadstone. For the the turbo swap, i used the parts list detailed earlier in this thread except I also bought new crush gasket for both ends of 02 housing. I wish I would've gotten one more of the oil/coolant line gaskets though. I bought 3, could've used 4 since I decided to remove all the lines to check for any build up and/or flow restrictions.
#2393
Heading to get dyno tuned today. Hopefully clutch doesn't slip. Didn't have time to break it in much. Brand new ky stg3 6 pick with stg 4 pressure plate and new flywheel.
BTW, this turbo is definitely louder.
T-Man (04-30-2016)
#2395
