Fuel pressure question
What should my fuel pressure be running at when it's warm it's in the mid to high 200 range never seen it go above 2250 at wot I'm using the torque app pro version.
It doesn't stay at 250, it bounces from 250-350 usually, sometimes 450. Idle sounds fine, just put in new hpfp and it still the same. I think urs is a little higher, cause I get 800 psi while at cruizing speeds with cruise control on
