Full Throttle Boost Issues
Just today i was getting in my car after work and was driving out of the parking lot, didnt get into the throttle or boost too much, but when i turn on to the main road to get rolling with traffic, i ran it through 1st and into 2nd.. Full throttle in second reaching about 4k RPMS it quiet literally fell on its face.. The car stopped all acceleration instantly.. Very violent. And every since i cant run up a gear past 3500RPMS without experiencing this issue, mostly when you try to go full throttle.. Does anyone have an idea of what it could be? Im think the spring in the BOV.. The car pulls fine when you avoid WOT. Drives just fine when you short shift.. You can get into about 10psi of boost before it will start to act up.. Im running GSM1.. Any ideas.. Any help would be much appreciated.
sounds like your hitting a fuel cut, possibly big boost leak and running to rich as you get higher into rpms, boost leak test it and go from there. take it to a shop and get them to run smoke through it and see if it come out anywhere.
