hks bov problems and questions!!!
Old 10-16-2009 | 02:54 PM
Gestapo007's Avatar
i have a greddy RS with hahn block off plate. just put the block off plate on, put the spring and black piece behind the block off plate like it was. all the block off plate replaces is the tan piece with the vacuum nipple on it. then take the line that was on the BPV and run it into the HKS. That gives vacuum to the HKS to suck it open when you let off the gas. if your surging, you may not have enough vacuum, in which case you T into your intake manifold vacuum source as well. so you have vacuum from the solenoid, and the intake manifold. that should solve any problems.
and if anyone is getting sick of their BOV, chick out my classified thread, i wanna trade charge pipe sections with some1 with a different BOV as mine to just keep it fresh
Old 10-16-2009 | 03:02 PM
reign1's Avatar
picking up my flange today, gunna order the block off plate. going to ship off to CIA for welding. and get an HKS. walla im done. woo
Old 10-16-2009 | 04:07 PM
Gimpster's Avatar
Wait wait, so the block off plates people sell retain the stock spring and plunger setup?
I wonder if people have all these weird issues because that plunger is being forced open during high boost situations. Without boost on the vacuum nipple pushing against the plunger I'd think it would make it even slightly weaker.
Old 10-16-2009 | 07:07 PM
peachpuff's Avatar
Its definitely possible, a simple fix would be to put a thin piece of aluminum/steel under the plate to put more pressure on the diaphragm.
Old 10-16-2009 | 07:20 PM
09turbo's Avatar
i like the way this one sounds, but that might get annoying
http://www.youtube.com/watch?v=SjTeEAyY1mo&NR=1
i just posted in here so i can follow along
Old 10-16-2009 | 07:52 PM
Sweetsandman's Avatar
They are ALL annoying ALL the time...stock and quiet FTW
Old 10-21-2009 | 02:59 PM
reign1's Avatar
thats ur opnion man.
and with HKS you can change the fin out for different sounds.
my stock intake box is way to quiet.
Old 10-21-2009 | 06:39 PM
hiltu's Avatar
still no bite on anyone running a Synapse Engineering BOV
Old 10-21-2009 | 07:54 PM
slowbalt84's Avatar
hks bov here. No problems. been running it for over a year. just gotta know what you're doing
brandon04
10-21-2015 08:04 AM
anotherslowlnf
09-29-2015 04:52 PM
Iceberg
09-29-2015 01:33 PM
Iceberg
09-28-2015 02:31 PM
Adiaz1ss
09-27-2015 12:51 AM
