How is my car running? Any tuners that can help?
Ok so I got a gauge for my car that reads wideband and timing advance and I would like to know if my car is running fine, it says on the wideband if it gets below 1.0 it's lean, and at the end of the video I am going to upload it shows it getting lean when I do a 3rd gear pull. Also idk anything about timing advancement so I would like to know if it's all normal as well? I just would like some insight on this.
Video link:
Video link:
Originally Posted by KMO43
First of all the air fuel is fine. Second I can not tell about the timing on WOT cause i can not see the rpms. Is that LTFT in the bottom right corner? What tune are you on with what mods?
Hptune for 25psi
Tr10 intercooler
Treadstone charge pipe
Zzp upgraded intake tube with modded air box and k&n filter drop in
Zzp 3" Catless downpipe
Stage 3 clutch
That's about it.
Well you want the ltft closer to 0 you're gonna wanna watch knock, timing and with rpm i can see somewhat more about the tune
This isn't another pull but I want to know if the clicking sound every so often is my timing chain tensioner? Or is that just direct injection? I know what direct injection sounds like and that random clicking every few seconds has me worried seeing all this stuff about timing chain tensioners.
Video:
Video:
Originally Posted by umrdyldo
Sounds normal to me.
Also every once in a while when I get on it there will be a squeaking noise idk where it's coming from, belt looks new and there's no loose pulleys. Idk if it's a bearing but it's never reoccurring. It only happens every once in a while and idk what it is.
Originally Posted by tomj77
The clicking on the video is normal direct injection sounds
Okay puts me at ease knowing 2 people said the same thing. I know I need a retune because I made a big jump from stock intercooler to a tr10 and an aftermarket charge pipe from treadstone. Idk just real paranoid about my car lately. Thanks btw to all 3 of you that replied. I appreciate it.
You actually don't need a retune for just those mods, but couldn't hurt to get the fuel trims in line.
My retuned are free I just have to make a 3-4hr drive to get it done. I think it's running a bit rich because there's some loud backfire that happens often, for example if I rev up to 3-3.5k and double clutch there's a gunshot noise (I am straight pipes) but this is just so loud and happens so often it makes me think there's something wrong with my car. Also my oil had a faint smell of gas to it but I ran the oil a little longer than I like to so idk if that has anything to do with it.
When was the last time you cleaned your air filter?
Give it a lean I've noticed it run richer and backfire when my filter gets dirty which it does a lot being a cold air at my flow level
I watched 10 seconds of your video. The refresh rate of that ultragauge is horrible.
I would only trust it as a rough indicator as to how things are going.
With such a slow refresh rate you won't see quick lean spikes and such.
I have had the clutch dump backfires. Mine was a fuel trim issue. Doing a couple MAF retunes fixed it. Winter gas caused a pretty significant retune for me. Especially running E25. E85 at the pump dropped a lot.
