issue with cold start
Old 10-18-2015 | 11:41 AM
tomj77's Avatar
pretty much every time I start my car when its been sitting for a while, it bogs hard, and vacuum goes to 0 and it almost stalls out, once it did, also smells like gas. after 10 seconds it runs fine. what u guys think? leaky injector flooding a cylinder? or something else
Old 10-18-2015 | 01:12 PM
cluelessk's Avatar
My car is stock but whenever it gets cold my cars idle goes wonky and usually stalls once. After that it starts fine.
Wonder if my bad secondary o2 sensor would be the issue.
Old 10-18-2015 | 04:32 PM
Sl0wbaltSS's Avatar
Do you let the fuel price before you start it?
Old 10-18-2015 | 05:24 PM
tomj77's Avatar
I tried that, first time it didn't fix it
Old 10-18-2015 | 05:25 PM
tomj77's Avatar
huh?
Old 10-18-2015 | 06:18 PM
cluelessk's Avatar
Originally Posted by tomj77
huh?
Think he meant purge.
Turn your ignition on and wait for the fuel pump to stop running. Do it twice.
Old 10-18-2015 | 06:41 PM
tomj77's Avatar
no I don't. I guess I should try that.
Old 10-19-2015 | 05:47 AM
63 Nova SS's Avatar
I've never had to wait on my fuel pump when starting it. Tom are your valves clean? Do you run a forge bpv? Is the tune ok? Don't know why you should be at 0 vacuum unless possibly your trying to build boost at idle. Could your bpv valve be sticking? Or an issue with your vacuum tank. If you tap the throttle does it go back to -20 or does it stay at 0?
Old 10-19-2015 | 09:44 AM
ForceFedDork's Avatar
please give us some details about the car?
is it tuned?
if it is tuned do you have Cat warm up turned off?
Catless downpipe?
aftermarket intake?
Here's my experience.
I have a catless downpipe, stock intake (k&n drop in), tuned it myself and turned off the cat warm up.I also had bad idle (very rarely it would even stall) for the first 10-15 seconds but ONLY on cold days on cold starts.
my solution: it was in the tune, getting the cam phasers right helped a lot, but what really fixed it was to do a good MAF tune (recalibrate the maf sensor).
Remember on cold start up the car can't run closed loop because the O2 sensors are cold and take a while to heat up. Therefore it runs on the MAF, open loop and if your MAF tune isn't basically perfect then it'll struggle.
Alternatively i could turn the cat warm up back on.
Other solutions that seem to work on the forum is cleaning the intake valves. but if ur tuned, im betting it's the MAF that needs to be dialed in.
Old 10-19-2015 | 09:53 AM
He's tuned for sure he also has a zfr I'm sure he's bolted up
Old 10-19-2015 | 12:50 PM
09CobaltSS1's Avatar
Cold start issues with the LNF generally almost always revolve around cam phasing.
Have you ever monitored your cam phasing during cold starts Tom?
Old 10-19-2015 | 02:04 PM
tomj77's Avatar
I'm fully bolted, tuned , no cat warm up, I have forge which I just greased, no vac tank and I just blasted the valves. It only does it when it's cold over night, had it in garage and did the purge thing and it was good this morning. It started doing this a few weeks ago out of the blue. I will have to log a cold start and see what's up
Old 10-19-2015 | 02:18 PM
turbocharged717's Avatar
I had this happen but I cleaned my original maf with some cleaner and it hasn't done it since. I don't know if this is your issue though but thought I would say about it anyway on the off chance. Good luck
Old 10-19-2015 | 04:01 PM
tomj77's Avatar
Didn't even try that lol usually first thing I do. I shall try
Old 10-24-2015 | 07:51 AM
63 Nova SS's Avatar
What did you find Tom ?
Old 10-24-2015 | 05:34 PM
tomj77's Avatar
Haven't done anything, accident at work , almost lost my arm, so I can't really do much at the moment. Should be good in a few weeks
Old 10-25-2015 | 06:29 AM
63 Nova SS's Avatar
Oh no, sorry to hear that, that's serious. Must have been bad, hope you mend well.
Old 10-25-2015 | 01:07 PM
tomj77's Avatar
Ya, huge circular saw plus arm = nasty
Old 10-25-2015 | 09:42 PM
63 Nova SS's Avatar
They are made for wood, not to be confused with flesh. I tried to take a chainsaw to my knee once. Fun when they get the iodine and a scrub brush.
Old 10-26-2015 | 09:00 AM
QuickSilver_SS's Avatar
My lnf would die every morning last year. I replaced my purge valve and vent valve in the tank. Its been good ever sense. Idk why they where causing it to stall. But they were... I was always getting a code for small evap leak nd then it would stall. Replaced both. Only cost like $60 and its been good ever sense.
Old 10-26-2015 | 09:50 AM
umrdyldo's Avatar
I have been through a bunch of purge valves. Horrible design. Car runs like dog crap when it goes out. Really kinda crazy. Hard starts. Backfires. Almost any evap code and I replace it immediately. I have some backups in the trunk.
Old 10-26-2015 | 07:43 PM
cluelessk's Avatar
Hmm. Not getting any evap codes. I've been filling my car it keeps tripping the pump like it's full but it's not even half way full.
Wonder if I could have the same issue.
Old 10-27-2015 | 09:07 AM
I've had that happen after I got tuned but then it fixed it self and never had a problem with the pump tripping
Old 10-27-2015 | 05:20 PM
tomj77's Avatar
They emptied a bottle of iodine into my arm, felt nothing. I think I'm so used to arm pain at this point I just can't feel anything anymore
Old 10-27-2015 | 06:13 PM
Sl0wbaltSS's Avatar
Does the car misfire and drop rpm's with catalyst warmup? or idle like **** until it's warmed up with it off?
both are normal but you can change the cold cam tables so it idles smooth when you start it.
Quick Reply: issue with cold start
