K1 crankshaft group buy
Hi guys,
I don't know if anyone of you may be interested, or if you guys even know, but I figured, let me share it, since I'm interested:
I spoke to the people at K1 Technologies regarding the crankshaft.
They told me they can make a forged 4340 crank for the LNF, rated to 1000 hp, for about $ 1400. The same is if someone wants to stroke the LNF with the 2.4 LE5 crank (same price, same material). They require a minimum of 3 cranks purchased for either LNF or LE5. Also, if we get a crank/rods combo for either LNF or LE5, the total price will be under 2k.
Since I would be interested in the next few months, I was wondering if at least a couple of you guys may be interested as well.
Thanks
Christian
Thanks
Christian
1. I would like to stroke it (and K1 sells the forged 4340 LE5 crank and rods to stroke the LNF for less than 2k).
2. (and most important) My Cobalt SS #2 (which is the one that is been currently modded by Nick at BYT) is paid in full, which means i can take it out of the country with no problem, and I'm planning on bringing it with me to Italy for the summer, we do races of 60-70 laps for the 2.0 turbo category cars, which means about 1.5 hours of constantly pushing the car, and I would like to have the most reliable engine possible. Doing that with the stock crank, It scares me a little, even because if I brake it, there is no way I can find a new crank for our car in Italy the next day.
Well, I really have 2 reasons for wanting to do it:
If you're going to break anything in 2 hours of racing it WON'T be the crank.
On the LNF turbocharged general page, I opened a thread called "stock crankshaft", and somebody there wrote that the stock LNF crank is rated 500 hp. Is it true?
**** no, why are you believing everything you read? The crank is the last part in the engine that will fail. Have you ever seen a forged crank fail in an engine?
Yes I know the stock LNF crank is forged steel, but somebody before said that it is rated to 500hp. Is it the truth? K1 told me their crank is rated to 1000 hp
ZZP however is running 500+ HP on a stock LNF crank with no problems last I heard. 500 HP sounds like a really conservative rating on a forged steel crankshaft.
That said... my opinion from seeing what fails most often on A-bodies... I'd say invest in suspension bushings, engine/trans mounts, intercooler + piping. $2k on a crank is throwing money away when there are alot of different areas that could stand to be improved.
ya i havent seen any hp rating for the stock crank but ryan at ZZP produced 600+ whp on their stock LSJ crank with no problems that i heard of.
as far as i know the LSJ and the LNF have the same crank... correct me if im wrong
I have heard that this crank will hold at least 800hp. If your going to do a crank that will hold 1000hp than you shouldn't be using k1 rods which will give before the stock crank will. In your 1.5 hour races I would be more worried about the block, I would call up bates and see what he will do for a nice set up.
LNF crankshaft is forged is forged steel, where the 2.4L is cast nodular iron.
LNF crankshaft is very STRONG and as the other forum member already mentioned, ZZP made more than 600hp w/o any issues.
K1 rods for the LNF is forged.
Unless I want to go 1000hp, I will personally not spend $1400 for an upgraded crankshaft.....since I have to worry about the stock drivetrain being able to hold higher whp/tq numbers FIRST.
My cast nodular iron crank supports 800whp (assuming there isnt a belt driven compressor to factor in), and its also a factory GM piece. I doubt it's built much stronger than the ecotec cranks, and even if so, you wont be pushing 950bhp anyway
The bes suggestion is to not stroke the motor... Dude you are taking away the beauty of a high revving 4 cylinder. Make good use of the larger turbo nick is putting on there for you by keeping that motor humming above 5,000 RPM, then change your oil after every race since you will be running some serious exhaust temps through that turbo. If you don't already have a pyrometer, I would say get one. 2K on a crank is rediculous when the LNF has a beastly lower end anyways. If you are going to do anything to the internals to increase displacement, why not just punch out the cylinders a bit.
True, but at the point he is at a stroker motor wouldn't really help on a track that much. The motor wouldn't want to rev as fast since the pistons have to travel farther. If you bore it out it would broaden the powerband. I say leave the internals stock.
it will still rev fine... the added torque will more than compensate for the slight increase in inertia
