Kmo43 2016
Old 03-09-2016 | 05:38 AM
  #51
KMO43's Avatar
Well just looked over my meth system and filled with a 82% meth mixture and found that once again my line popped out of the nozzle and the nozzle is really loose. I will be getting a plate welded to make sure that's all good and upping the nozzle from 550 to 625cc/min. So all my times I have done so far are on PUMP!! I'm gonna do a log for meth trims then do a vid and after this weekend when it's fixed maybe I'll do some drivebys and ****. IDK let me know what u wanna see!!
Old 03-09-2016 | 09:46 AM
  #52
06blackbalt's Avatar
How do you see the 60 to 100 times on hpt? Nice build
Old 03-09-2016 | 01:02 PM
  #53
no_ss's Avatar
I wanna see you do a burnout
Old 03-09-2016 | 08:02 PM
  #54
KMO43's Avatar
Do a 3rd geat pull from 50 to redline then on the scan go to 60 and 100 record the times at the bottom of the screen and do the math
K I'll do a 2nd gear rolling burnout
06blackbalt (03-09-2016)
Old 03-10-2016 | 03:24 AM
  #55
KMO43's Avatar
So I got my first kill today a Rx7 and went the wrong way so I did a quick vid in a tunnel
Old 03-10-2016 | 03:31 AM
  #56
no_ss's Avatar
That's ridiculous
Old 03-10-2016 | 03:33 AM
  #57
KMO43's Avatar
That's ridiculous
Just a taste!
Old 03-10-2016 | 08:36 AM
  #58
KMO43's Avatar
I turned down 2nd gear and will a bit more i bet still. As you can see in the vid 2nd is losing the battle badly even with my NT01s on there
Old 03-10-2016 | 11:14 AM
  #59
Lol damn that's crazy
Old 03-10-2016 | 11:17 AM
  #60
KMO43's Avatar
It's getting there. Need that meth fixed then E next month
Old 03-16-2016 | 09:24 AM
  #61
KMO43's Avatar
I fixed the boost leak because of my loose meth nozzle and I hope I fixed the meth nozzle having the hose pop out (cheap push fittings). I'm hoping to get 2 logs in tomorrow and that the meth hose won't pop off again. I have only been running 15* so if this hose stays together I wanna see how close I can get to the timing I ran last year.
On a side note I have the GoPro all ready to do a good pull vid I think I'll get to it next week since I'm going home for my birthday but I may also be hitting the dyno as well so I'm excited for that
Old 03-16-2016 | 11:07 AM
  #62
Nice man good luck
Old 03-16-2016 | 02:26 PM
  #63
tomj77's Avatar
Do u just thread the nozzle through the pipe or do u have a bung welded to the pipe? I can send u a 1/8 npt aluminum bung. I put e6000 on the threads and tighten it good. Never comes loose or leaks
Old 03-16-2016 | 06:55 PM
  #64
KMO43's Avatar
I have a plate welded and tapped but thats not the issue the cheap push connectors are. I'm gonna upgrade to AN fittings in April
Old 03-16-2016 | 09:29 PM
  #65
KMO43's Avatar
I had my schedule changed on me so I was running late but I did a quick pull and a 3rd gear pull. Meth line stayed together!! I had wheel spin at 5500rpm in 3rd I need better weather so I can run the NT01s again
Old 03-16-2016 | 10:06 PM
  #66
That's crazy man
Old 03-17-2016 | 12:48 AM
  #67
KMO43's Avatar
Did a log on my way home tonight I have to check the meth hose again but hopefully it's still good but my boost comes in at
3500 - 23.6
4000 - 27.1
4500 - 30.0
5000 - 30.6
5500 - 30.6
6000 - 30.0
6500 - 31.1
I added boost to finish my curve off and some more timing since my meth seems to be working.
Overall I am happy it's faster than last years 29psi @ 23* E25 tune and I'm at 30psi but only 14* on this last log
Old 03-17-2016 | 02:19 PM
  #68
tomj77's Avatar
Stock motor takes it like a champ eh
Old 03-17-2016 | 07:28 PM
  #69
KMO43's Avatar
It's not that much power yet
Old 03-17-2016 | 09:14 PM
  #70
tomj77's Avatar
its more than most stock 2.0 motors will take. not to mention the amount of boost they can inhale. these motors are impressive
Old 03-17-2016 | 11:18 PM
  #71
KMO43's Avatar
I'm also fully ported and stg2 cams
Old 03-17-2016 | 11:38 PM
  #72
nathan112i's Avatar
tomorrow i will see how well your ported head works, i only have about 2 hours buttoning things up before i flash it up
Old 03-18-2016 | 01:24 AM
  #73
tomj77's Avatar
how much more power did the porting and cams give u?
Old 03-19-2016 | 08:52 PM
  #74
KMO43's Avatar
Let's just say it's a highway monster!! 4th gear pulls as hard as 3rd last year
Old 03-19-2016 | 09:43 PM
  #75
nathan112i's Avatar
It runs! excited to get this thing on the road
Quick Reply: Kmo43 2016
