Kmo43 2016
#51
Well just looked over my meth system and filled with a 82% meth mixture and found that once again my line popped out of the nozzle and the nozzle is really loose. I will be getting a plate welded to make sure that's all good and upping the nozzle from 550 to 625cc/min. So all my times I have done so far are on PUMP!! I'm gonna do a log for meth trims then do a vid and after this weekend when it's fixed maybe I'll do some drivebys and ****. IDK let me know what u wanna see!!
#53
#54
Do a 3rd geat pull from 50 to redline then on the scan go to 60 and 100 record the times at the bottom of the screen and do the math
K I'll do a 2nd gear rolling burnout
06blackbalt (03-09-2016)
#61
I fixed the boost leak because of my loose meth nozzle and I hope I fixed the meth nozzle having the hose pop out (cheap push fittings). I'm hoping to get 2 logs in tomorrow and that the meth hose won't pop off again. I have only been running 15* so if this hose stays together I wanna see how close I can get to the timing I ran last year.
On a side note I have the GoPro all ready to do a good pull vid I think I'll get to it next week since I'm going home for my birthday but I may also be hitting the dyno as well so I'm excited for that
#63
Do u just thread the nozzle through the pipe or do u have a bung welded to the pipe? I can send u a 1/8 npt aluminum bung. I put e6000 on the threads and tighten it good. Never comes loose or leaks
#64
I have a plate welded and tapped but thats not the issue the cheap push connectors are. I'm gonna upgrade to AN fittings in April
#65
I had my schedule changed on me so I was running late but I did a quick pull and a 3rd gear pull. Meth line stayed together!! I had wheel spin at 5500rpm in 3rd I need better weather so I can run the NT01s again
#67
Did a log on my way home tonight I have to check the meth hose again but hopefully it's still good but my boost comes in at
3500 - 23.6
4000 - 27.1
4500 - 30.0
5000 - 30.6
5500 - 30.6
6000 - 30.0
6500 - 31.1
I added boost to finish my curve off and some more timing since my meth seems to be working.
Overall I am happy it's faster than last years 29psi @ 23* E25 tune and I'm at 30psi but only 14* on this last log
3500 - 23.6
4000 - 27.1
4500 - 30.0
5000 - 30.6
5500 - 30.6
6000 - 30.0
6500 - 31.1
#70
#71
