Lagging boost and random misfire on all 4?
Hi everyone I'm Johnthan and new to the cobalt family. Well to start things off about a month ago or so I bought a 2008 Chevy cobalt ss/tc from my relative. The car has 120k and is tuned on 23lbs of boost bone stock but that. I'm having a bit of a dilemma now with it. About a day or so I was merging into the highway and I hit about 80% throttle and after the merging it started to act weird. It would not go above vacuum and started sputtering. Today I went to check it and it is having misfires on all 4 cylinders and it lags boost a lot. It's never did this before I heard something about a gms1 but don't know what it is only that it's different maps. How would I know if I have those types of maps on it? Or what to do to the car short answer?
Tredstone (I think) charge pipes only upper bottom one hasn't been changed because of the tmap sensor. The upper map had broken but changed it. Can you test them?
Well first check that the sensors have the blue sticker on them, those are gms1. I'm not sure how to test them. Something to do with the voltage, someone else may know. But I'd check for boost leaks. Do a boost leak test. See if lower or more common, intercooler end tanks cracked. U can get that out the way and ull have a better idea what's up. If ur leaking, that's probably the issue, but usually u throw a p0101 code for that. But check anyway. Clear other codes as well and try again. Can also pull ur plugs and see how they look. The car could also possibly need it's intake valves cleaned, but first try the other stuff
To be honest man I don't even know. Last I remember he had about 80k on it when he changed them if not more. And it has 121k on it now. Like it builds boost but if I hit 15lb or more after it doesn't want to go above vacuum
Black plugs means ur rich, or got oil on them, should be light brownish. If ur boost is not working correctly, u may have an issue with ur wastegate solenoid, mine was leaking and boosted very slowly, like it took me to 6k to hit full boost. I'd take it off and check it to see if it's leaking. Probably would need to get a new one to check that though. But ya black plugs arnt good. But they could also just be carboned up, change them
jcalvin1126
02-07-2016 09:50 AM
