Leaking Fuel Lines
Old 04-13-2016 | 08:47 PM
zzech's Avatar
Leaking Fuel Lines
Good old Michigan....warm weather. Getting new Pilot Super Sports put on the LNF today. Supposed to be a good day.
Tech discovered my fuel line/evap line leaking just in front of the rear driver side wheel, at the clip where it turns up and heads to the gas tank. Quoted me 750 to replace both lines (350 labor, assuming dropping the tank, and 400 parts). In my head and experience I'd figure 3 hrs labor and maybeeee 200 parts? 450-500 total?
Told them that I was going to get a second opinion. Its not dripping, just a little fuel residue. Keeping an eye on it, going to get another look at it Friday. Heard this is fairly common?
What do you guys think is a reasonable quote? Independent shop. I'd do it myself but dropping the tank while on jackstands does not sound like a fun time....
Michigan people, good mechanic in Canton, Westland, Plymouth area? From the east side and trying to find a good local guy, haven't had good luck yet.
Old 04-14-2016 | 01:51 AM
cobaltss#01's Avatar
the lines do rot out there. as far as mechanic good luck.
Old 04-14-2016 | 10:51 AM
umrdyldo's Avatar
Contact ZZP performance they are like two hours away.
Old 04-14-2016 | 03:02 PM
JapEatr's Avatar
South Central *********
^^^good point.
Also removing the fuel tank is the easy part. reinstall on the other hand.
Old 04-14-2016 | 08:10 PM
zzech's Avatar
Found a local guy. 375. Replaced both lines from the tank up to under driver side (Where the lines run flat). Easy enough.
Old 04-14-2016 | 08:39 PM
tomj77's Avatar
Who quoted u so much? Dealer? Rip offs
low_k3y
03-20-2016 09:15 PM
edacsac
03-19-2016 12:56 PM
Tykuura
03-16-2016 02:44 PM
