LNF k frame support for swap
Old 11-04-2016 | 12:23 PM
cw383's Avatar
I'm going to be doing my swap this weekend hopefully. I would love to see what you guys used as a support when dropping the engine/trans on the k frame. My plan is to build a box support with some 4x4's and 2x8's on castors about 3' high and. lift the car off of it, I do have access to a lift. Thanks!
Old 11-04-2016 | 02:19 PM
Omiotek's Avatar
If i have a lift i used jack stands.
If i dont have a lift i use a pallet jack, 2 jacks and then i brace the motor using a pallet and 2x4s
Old 11-04-2016 | 08:22 PM
tomj77's Avatar
I put an engine dolly under with some 2x4s and lowered the car till engine sat on it then unbolted and raised the car.
Old 11-04-2016 | 10:38 PM
63 Nova SS's Avatar
Good info
Old 11-07-2016 | 12:31 PM
LNFwagonSS's Avatar
I have a pallet jack that lifts 36 inches off the ground. I got all the work up top done first then measured to see how high I needed the car to slide the assembly out. Jacked it up, disconnected everything on bottom side and slid it out.
Old 11-07-2016 | 09:03 PM
63 Nova SS's Avatar
^ nice idea
LNFwagonSS (11-08-2016)
