LNF PCV Anti-coking drain back system
Old 06-28-2014 | 04:15 PM
  #276
andrewcarr1993's Avatar
LAP easy or hard?
Old 06-30-2014 | 09:58 AM
  #277
CrystalRedSS's Avatar
Will this part stop oil from getting in the intake manifold and all over the map sensor? I keep going through map sensors and my car is running like crap.
Old 06-30-2014 | 01:41 PM
  #278
Yeah it will.
Old 06-30-2014 | 08:04 PM
  #279
Powell Race Parts's Avatar
Unless your car is trying to blow up andrew is right. Tx andrew
Old 07-01-2014 | 10:46 PM
  #280
And this comes with directions too right? I want to make sure everything is how it's supposed to be.
Old 07-01-2014 | 11:01 PM
  #281
the instructions with the kit are comprehensive; it is essential that you either have clean valves or get them cleaned. This kit does not clean valves it prevents the continued deposition of oil on the intake valves. So far we have learned quite a bit about this coking issue. While DI valve coking is not unique to the LNF engine, its clear that bisecting the main vent line and inserting a drain back seperator does an effective job in the primary source of oil in the inlet tract.
The inlet manifold pcv valve can be defective, and I have found it so in quite a few de coke jobs on LNF I have done. If the IM pcv valve is reluctant to close until high boost levels hit it, or doesnt close at all, the build up becomes severe and the car really runs badly.
Sometimes I have encountered LNF with issues that the PCV upgrade evidentally could not deal with. Generally that has been cracked piston ring lands, damaged rings, or even broken charge pipes.
If the engine health is good, its reasonable to expect the upgrade will keep your engine running well.
Old 07-04-2014 | 09:02 PM
  #282
SINISTER's Avatar
Just ordered mine!!
Old 07-04-2014 | 09:27 PM
  #283
just finished packing it lol
Old 07-04-2014 | 09:36 PM
  #284
footballplaya3k's Avatar
I just put mine on my new LDK, it'll be nice to be able to keep the valves clean.
Zo6balt (10-04-2020)
Old 07-04-2014 | 09:46 PM
  #285
SINISTER's Avatar
Yay...Unsure how this hooks up yet...but should I change my PCV valve also?
Old 07-04-2014 | 09:59 PM
  #286
I was not told to change my PCV.
Old 07-04-2014 | 10:26 PM
  #287
What I am saying, is if the valves are coked and then cleaned might as well replace the PCVvalve in the inlet manifold. Thats because over half the ones I test when I clean the valves are stuck open at varying pressures. Thats not good. I regard it as a 5 dollar maintenance item.
Old 07-04-2014 | 11:11 PM
  #288
09outlander's Avatar
To change the PCV valve the intake manifold must be removed, which you don't have to do to install the PCV upgrade.
However, if you ever get your valves cleaned, which you should, make sure to change your PCV valve while you have the manifold off.
Old 07-05-2014 | 03:39 PM
  #289
SINISTER's Avatar
Now I am confused, why does the intake manifold need to be removed on the LNF to get to the PCV? I thought it was pressed into the valve cover near the turbo?
Old 07-05-2014 | 06:37 PM
  #290
Grave's Avatar
529
http://www.crateenginedepot.com/pdfs...Fuel_Parts.pdf
Old 07-06-2014 | 02:27 AM
  #291
SINISTER's Avatar
Originally Posted by 1Panel2NV
Great picture thanks!!
So doesn't the line from the intake lead to another PCV? That is pressed in near the turbo?
Old 07-07-2014 | 08:26 PM
  #292
Sox-Fan's Avatar
Got Brakes?
The PCV is a plastic one-way valve that sits within a passage in the intake manifold up against the head. It has no hoses leading to it. You need to remove the intake manifold to get to it.
They can go bad. One of mine did. John can tell you how often that may occur.
Old 07-07-2014 | 08:33 PM
  #293
Sox-Fan's Avatar
Got Brakes?
See the hole in the very center? That's where your PCV valve is pressed in
Old 07-07-2014 | 08:37 PM
  #294
Holy **** he is alive
Old 07-07-2014 | 10:22 PM
  #295
SINISTER's Avatar
I guess its the same for the LNF right?
THANKS for the pics and information!
Old 07-08-2014 | 01:28 AM
  #296
Omiotek's Avatar
its in the same general spot some what but its not actually in the same physical location. totally different.
Old 07-08-2014 | 08:54 AM
  #297
Grave's Avatar
The picture shows an LNF manifold. Or am I missing something?
Old 07-08-2014 | 11:47 AM
  #298
sinister did not know what the manifold looks like. There appears to be a lot of confusion about the PCV system and lots of opinions about it, many of them are wrong.
FOR THE RECORD.
There are two check valves in an LNF One is the FRESH AIR INLET (FAI) it lets metered air in from the inlet tube post MAF to the rocker cover port in the middle of the back of the rocker cover. There is a 4 mm orifice in this FAI tube. There is an UPDATED tube and valve as the nipple in the stock inlet tube can break from excessive pressure.
The other is the PCV VALVE ( dirty side) located in the inlet manifold as sox fan has show, that vents blow by gasses into the inlet manfold OFF BOOST.
The rocker cover port at the passenger side (front ) of the engine is routed stock to the turbo inlet port. It vents blow by gasses to the inlet side. As oil builds up combined with the blow by gasses running through the mezanine along the rocker cover to this port, it actually can drain out directly to the turbo inlet.
It is this issue that the Powell PCV upgrade oil seperator deals with, and drains excess oil seperated back to the engine.
As the engine tilts under accelleration or in cornering this issue with oil draining into the turbo inlet gets worse, which is why Wangspeed found he can collect as much as 500 cc of oil in 20 laps on track with the car, but collects less than that over a month of street driving.
The upgrade works.
The understanding of how it works, appears to be (how can I say this politely?) VARIABLE on here. There is a delicate balance of vacuum and the PCV orifices and paths of least resistance for blow by gasses to vent. The PCV upgrade really does a good job. The latest change as of July 1 to the system makes it easier for folks to plumb without issues; the next big change will be a full time vacuum pump but thats not needed for anything other than the extreme track guys imho....any parts of the PCV system not in good order like the FAI or the IM PCV valve will give issues, as will any leaks especially at the MAP sensors for example. Hope this helps
Old 07-09-2014 | 06:04 PM
  #299
SINISTER's Avatar
Yep, just bought the car...I have never seen it flipped over... I guess the F.I. air meter threw me off... LOL
So in a perfect world changing out the FAI and PCV and then installing your system is the way to go...right?
Old 07-09-2014 | 06:06 PM
  #300
I know what the manifold on my car looks like and it doesn't look like this...that's why I asked the question...
[/QUOTE]
Post a photo of yours. That is a stock mani in that pic
