LNF PCV Anti-coking drain back system
#301
#302
no worries, had I not ordered a spare for when I clean my valves (checked with a bore scope and my IM is dirty pretty sure I have a failed PCV valve) I probably would of though similar. Just a side note for those cleaning valves, check your IM, the one I bough used had some oil build up/coking on it not significant but there was still some build up.
#303
My car is currently burning oil, blue smoke. I had a catchcan installed prior and relized how useless it was when my charge pipes still had oil in them. I did a compression test and it came up good. So I thought my turbo seals were shot. Do you guys recommend me trying the powell separator first to see if the problem persists? Who knows my seals my be good and I might just be getting a **** load of blow-by!
#304
If you had a lot of blue smoke and it was from blow by, your engine would be hurting bad
#305
it's gotten worse now that it is hot out. The plugs need to get replaced it again, however I seafoam it every oil change and it doesn't smoke much at all... Should I try this first as an alternative and if it persists go on with replacing the turbo?
#307
I'm going to clean the charge pipe, silicone hoses, and install the pcv system. Then if the problem reoccurs it's turbo swap time!
#310
Giving some thought to one of these for preventative maintenance reasons. One thing I'm curious about though:
The oil that this system catches -- where does it go? Does it flow into a catch can that needs to be emptied periodically, or does it have a way of flowing back into the engine, and if the latter, through what orifice?
#311
#313
Well v3 has a 3rd line to the intake manifold, if u don't have that it's v2. U can upgrade to v3 for cheaper than buying new, just email Powell
#315
The oil goes back in through the dipstick tube? Does this mean I lose my dipstick?
#316
#318
#320
Yeah. I didn't see any indication of where the dipstick would go so I figured I'd play the part of the idiot and ask a stupid question.
And now for my next stupid question, would my car with this installed have any chance of passing California smog visual inspection?
#322
It won't make any difference to smog tests. Actually maybe it will, no oil in intake makes for less harmful emissions so it will help you out actually
#323
#324
But in Cali, if I understand correctly, pretty much anything that modifies anything that in any way pertains to emissions and doesn't have a CARB approval sticker will flunk visual (the pop-the-hood-and-look-for-mods test), even if all the smog scanners say everything's perfect.
Kinda hoping there's some Cali people on this thread who could say "No, your understanding is incorrect because [insert long winded explanation here]."
#325
I really doubt a visual inspector will notice. But I'd wait for a Cali user to comment. You could always just disconnect the system for the visual inspection (is it an annual inspection or less frequent?)
