LNF PCV Anti-coking drain back system
Old 12-03-2012 | 04:10 PM
  #101
cubaniche's Avatar
Thats great John! Thanks for keeping at it. It is most definitelly the best and most thought out system for our platform. Not to mention that, it is actually useful, WORKS and serves a purpose.
Old 12-03-2012 | 04:28 PM
  #102
Powell Race Parts's Avatar
Originally Posted by vahdyx
Looks like I misunderstood you over the phone last night. What's the best way to turn my unit around lol.
Also thank you for sending me the new bracket. I really appreciate it.
Thats awesome you finished it up to work temporarily! The lid unscrews and you can rotate the top port ; here is a picture with it rotated ( disregard the frugly JIC connectors, I was trying to reduce cost,and they were cheaper, but looks awful)
The seperator is so light , being made of composite material, it can hang there on the hoses for a day or two. Your new bracket and a spare longer hose went out at 11.55 this am. Not bad , eh!
ugh. sprained my arm patting myself on the back
Old 12-03-2012 | 04:32 PM
  #103
Sox-Fan's Avatar
Got Brakes?
It might come down to two brackets. One for lnf version a, one for all the rest of you guys that aren't me :p
Old 12-03-2012 | 04:40 PM
  #104
for sure. maybe even three. Todd (BLRT) is working on refining the S256 ZZP version, which has its own little issues.
I would like to do a pc rocker cover exchange with the PCV upgrade, then I could do the custom stuff I talked about and eliminate one efi style OEM braided line. But that bumps the cost 140 and requires an exchange cover shipped back....
Old 12-03-2012 | 04:52 PM
  #105
padlock's Avatar
^so basically for $490 you'd have a cleaner final appearing oil separating system (due to one less line) along with a nice powdercoated VC? tempting mr. powell..... very tempting....
cant wait to see the updated bracket that was sent out. only thing I'm now concerned with is the LNF fuel trims like going wacky depending on the air filter rotation. having it rotated to give the most space as vahdyx does would likely require me change the maf calibration tables a bit in my tune to get it running as good as it is now
Old 12-03-2012 | 05:11 PM
  #106
vahdyx's Avatar
Well I was able to rotate the separator to accommodate the new bracket when it arrives, but the problem is the hoses now. If this piece was straight and the hose connection that is on the valve cover was "L" shaped I can go underneath the intake rather than around it.
Since it's straight I have to go around and the hose isn't long enough to go around at the moment.
Old 12-03-2012 | 05:12 PM
  #107
Omiotek's Avatar
i highly doubt rotating the filter will cause that much disruption.
  #108
swap it end for end that should work. let me know, I am outahere for the next couple of hours, but you can text me etc. thanks for your diligence.
Old 12-03-2012 | 05:15 PM
  #109
For sure it would look great, especially in a textured color black or otherwise. There is one less connection, ( not one less line unless you count the OEM line I eliminated in the connection ) etc. but the work that went into this system was to specifically NOT upset the OEM vacuum levels at which the PCV is designed to operate . Rotating the in/out makes not any difference...and I cannot see that the tune would be affected at all.
Old 12-03-2012 | 05:20 PM
  #110
padlock's Avatar
i was referring to air filter rotation throwing off the fuel trims. nothing to deal with your system at all, more of a K&N intake issue but nothing I cant work around
Old 12-03-2012 | 05:23 PM
  #111
Here is some background:
In operation orifice size (XXmm in this case) is chosen to keep the crankcase pressure negative by a small amount under all operating conditions.
Under light load, the turbo inlet venturi effect is just enough to cause a depression and pull air through the crankcase from the fresh clean air duct tube. The check valve becomes an “orifice” to control depression. I worry about the S256 vent return location, but Todd (BLRT) did his best to keep that vent as close to the impeller as possible, although not as close as the stock K04 turbo has in the OEM state.
Under high load where the piston blow-by becomes significant, the fresh passage is stopped with a check valve. This is to prevent back flow. The venturi effect of the turbocharger inlet is sufficient to pull in 100% of the piston blow by, plus pull the crankcase pressure 2 to 3 kPa negative as calibrated in balance with the fresh air check valve.
Crankcase pressure should be reasonably uniform. Draining the separated oil back into the crankcase in a similar manner to the turbo oil drain was required. We took care to make a return to avoid crank oil whip and place the drain back oil in a relatively undisturbed location. This was not easy, as we are only talking a few kPa delta to keep flows going in the right direction.
Old 12-03-2012 | 05:44 PM
  #112
vahdyx's Avatar
Well that seems to work out quite well.
Old 12-03-2012 | 06:53 PM
  #113
northvibe's Avatar
where do you drain?
Old 12-03-2012 | 07:28 PM
  #114
Originally Posted by northvibe
where do you drain?
You got to be kidding Parnell!! I might as well post drawings so every one can copy it more easily. I have been burned too many times. That's why I won't call out orifice dimensions; of course some folks might read the description....
Old 12-03-2012 | 07:30 PM
  #115
10-4 you da mang! Works out very well. New bracket en route, no need for the hose I sent you, but never mind I will find a new destination for it...lol...
I am gonna buy that borescope you found and try it out, son Devon gets cranky I keep borrowing his super expensive snapped on borescope tool lol
Old 12-04-2012 | 10:08 AM
  #116
Omiotek's Avatar
Again rotating your filter should not throw off fuel trims at all
Old 12-04-2012 | 10:12 AM
  #117
padlock's Avatar
while I have not rotated mine and view fuel trim "differences" (if any), there are many many threads on the K&N filter rotation and having it at a certain location so that leads me to believe differently. I have mine set at the usual 11:30 position like almost everyone says to do and my trims are about as dead nuts as they can get running LTFT +/- 3% at worst. the "egg" shaped filter changes the air flow across the MAF depending on rotation is what the argument is. But anywho, thats getting off topic.....
Old 12-04-2012 | 10:18 AM
  #118
vahdyx's Avatar
I agree my trims are affected by rotation
Old 12-04-2012 | 10:33 AM
  #119
northvibe's Avatar
hahhaha ok well maybe I'll email you :-p
It was a long day of little coffee yesterday.....
Old 12-04-2012 | 02:42 PM
  #120
Omiotek's Avatar
yeah i will argue that all day long but back on topic.
Old 12-04-2012 | 02:53 PM
  #121
CudaJoe's Avatar
my .02 cents. I agree with this guy.
Old 12-04-2012 | 03:40 PM
  #122
Here is my problem. The PCV system here I know about. The fueltrims I know nothing about. But Area 47 knows lots. So I asked. He said "different flow patterns across the mass air." Vahdyk is right,
so back on topic.
Old 12-04-2012 | 06:09 PM
  #123
ATLsilverSS's Avatar
So will this setup bolt up to the hhr ss?
Im stock turbo right now but changing to a custom turbo setup soon.
Old 12-04-2012 | 07:21 PM
  #124
Yes it will not mount on the tower, but in the front of the motor, where i install it on a stock airbox SS coupe. I will need to make different lines for it, is all.
Old 12-04-2012 | 09:16 PM
  #125
Will any other modifications need to done to work with my aftermarket turbo setup?
