LNF PCV Anti-coking drain back system
#126
I was fortunate that Todd with the ZZP S256 conversion was able to bring his car in, and was able to prep his turbo in advance. Aftermarket parts like that can drive the price up as the parts are, of course, different.
The K04 has a port that positions the pcv return very close to the impeller , which I have explained in this thread already, is designed that way to create a vacuum sufficient to allow the PCV to function properly.
#127
if its not a K04 its a whole different ball game. but I cant speak to a part that you do not identify. Anything is possible and we have installed the PCV on an S256 ZZP install, but it is not my intention to try and match up every different set up, in advance, most people have stock K04 turbo's.
You have mail...
#128
#129
So I got the new bracket from Powell and here's my problem
Basically it wasn't gonna fit without some extra work on my part.
So I loosened the intake tube where it connects to the turbo then I bent the K&N Intake stability brace back (don't know what it's really called) just enough to move my entire intake over. Pic below
After all was said and done, this is what it's doing to my filter.
So it's close, but not perfect!
A large part of me now wants to just get a Treadstone CAI and run the filter down by my fogs and not have to worry about "fit" of the PCV Separator. I don't know the details on making a switch like this, but if it "fits" better then it may be worth the extra expense.
Also by moving my intake over a hair I was able to keep my original filter location. thus making a retune not necessary (I think)
I reset my LTFTs and in a few days I'll see where they're at.
Here's my final assembly
My desire for this unit is the port touching the filter, I wish that it was facing (protruding) out towards the strut tower with a 90* angle towards the engine. That or if it was coming out straight towards the engine but closer to the strut tower rather than center of the unit. This way it wouldn't be an issue with filter. That's my uneducated theory.
#133
just from looking at this.. if the 90* angled piece was flipped (meaning the vertical side of it located closer to the firewall). this would allow the separator to move even closer to the strut via what omiotek said with oblonging the holes on the flat metal mounting bracket.. am i right?
#134
#135
at the end of the day Vahdyk install is functional and it wont hurt the filter for now. I will get a hold of Loki's K&N LNF and redo the install so its perfect, and go from there. Loki had some scheduling issues and is away a lot, so his test car was not able to be in my hands when we needed it to perfect what is now Vahdyks set up.
If I completely move the seperator to the front of the car for all installs I eliminate that problem, but create another, as it would require drilling holes. Once a decision is made that its okay to drill holes, then the sperator could be mounted to the inner fender with two holes drilled. I am not keen on drilling any holes in any car, but at the end of the day it may come to that. How do folks feel about drilling holes?
And lastly I hate a public internet free for all on a thing like this. I prefer to perfect the install before we ship. But I was unaware of different K&N filter installs, and so far have stock, Hahn and ZZP S256 installs worked out. And now working on Area47's LS2 truck installation.
Thanks for all the help, and to Vahdyk for being so patient. A new bracket is in the works. v.3?
#138
about every K&N I have seen touches the tower stud unless its removed, but I have not seen any holes in the filter from it. I wont debate the movement of the motor or the rubbing issue, but I will buy Vahdyk a new filter if it rubs through, especially in the time it takes for us to send him another mounting bracket.
#139
#142
#143
fortunately the orifice in the rocker cover will maintain the vacuum. be aware the specifics of the system insist on a small orifice other wise the vacuum will not be maintained. I am not sure that bigger is better but you have the dash 8 lines so go for it! If you open up the orifices in the cover then the whole deal will not pull enough vacuum. pics or ban lol
#144
we are in violent agreement lol. I will make it work perfectly for you, just have to make the tolerances closer for the fittings to the tower and the inner fender for the seperator itself.
#145
#146
its a question of velocity and circumference of the impeller and all sorts of things waaay beyond my competence, I will try and find out from engineering for you...
#147
Here are the pics. Got to go under the intake for the -8 hose. Btw, the fitting/opening is much closer as compare to the stocker. Measuring from the tip of impeller to where the fitting is approximately 5/8" as compare to 1 1/4" stock.
#148
excellent Todd. For Vahdyk I am thinking of moving the seperator to the front, thats the location I use for the stock air box. The trick is devising a clamping bracket so that no holes will have to be drilled on the tie bar.
I can work on that the end of the week, I am the skid pad monday and tuesday so not a lot of time to work on it .
Your install now looks pretty darn good, other than the color of fittings - I can swap out some of your black fittings for the red blue if you want. And the big thing is, it will work well thats the most important part, thanks for your diligence with your unique install.
#149
#150
If you have couple -6AN hose ends sitting around, sure. But if you have to buy them, don't worry about it. I can pick up some when I am in the US next time which is alot less. The darn -8AN 45 degree hose end cost me $34+ tax from Northern Performance. Oh well, I needed it. I have couple straights but.. BTW, let me know how much I owe you still for the actuators so I can send you a cheque.
