Lnf problems :(
Lnf problems :(
Hey guys, my 09 SS has been having problems. The car has a misfire and the rpm needle drops and goes back up when it's on neutral coming to a stop. Could it be a dirty throttle body? Or dirty maf? Btw. It's running lean and it has a brand new ldk installed. Any help will be great. Thanks
Dont listen to him.
The rpm dropping is most likely connected to a vacuum or boost leak probably from the lower charge pipe. Start there, when you installed the LDK did you use new AC Delco plugs? And then the break in period was followed?
Lnf problems :(
I bought the ldk long block from zzp. It already came with spark plugs but i have (new) spare spark plugs. However i did leave my aftermarket c.a.i. installed. Not sure if that can cause it.
