Lnf shift cables
Old 02-24-2016 | 07:13 PM
adunk25's Avatar
Lnf shift cables
Anyone know how to change the shift cables on my lnf? I have no reverse 4th or second. I got the new cables from Zzp just don't wanna do it blind any help would be appreciated
Old 02-24-2016 | 08:20 PM
tomj77's Avatar
ill be doing it soon, so ill need to know too. I know how to get them off the trans, just put a pry bar under the connection and pop it off, then the mounting bracket is like 4 bolts and it comes off trans. ull have to remove ur fuse box I believe to get to em, unless u can from under the car. as for the rest, I have yet to do it.
Old 02-25-2016 | 02:23 PM
QuickSilver_SS's Avatar
I have changed them twice on my lnf. Due to them frezzing up solid in the winter time. I am very capable at working on cars. I have small hands as well. And. All i can say is have fun. Lol.. Its not a hard job. Its just they get caught up on EVERYTHING on both the way out and back in. Its a pain in the ass. You really dont need to take out the fuse box. Or any amount of bolts. There is one nut on a stud holding the linkage away from the down pipe. Thats it. You can use your hands to remove the linkage off the tranny from both inside and outside. Its a lot easier when you have two people.
Old 02-25-2016 | 08:46 PM
tomj77's Avatar
I have my tranny out so mine should be easy. nothing much to get in the way since cradle, downpipe and bunch of other stuff is not on the car. do u have to push them threw firewall and connect them to shifter or how does that work?
Old 02-25-2016 | 11:22 PM
adunk25's Avatar
Just gonna give zzp 150$ tomorrow rather than bothering with it lol; gotta love living 5 minutes away
Old 02-27-2016 | 11:43 PM
Vankz's Avatar
Its literally a 20 minute job if that.
Old 02-28-2016 | 07:57 PM
bland1's Avatar
Had my mechanic do mine last week. Took hour 1/2 from the driver side tire. They didn't have to remove the fuse box
Old 02-28-2016 | 09:57 PM
T-Man's Avatar
Ordering mine tonight. Will install them ASAP and report back. Looks simple
Old 02-28-2016 | 11:36 PM
colodude18's Avatar
I'm having mine replaced this week at a shop as part of a much bigger job (fueling, cams, head etc).
My problem was hard shifting under high rpms (road track).
Powell advised me that the cables probably overheated and need replacing.
Old 02-29-2016 | 11:03 PM
wol-shiver's Avatar
If you don't have 2nd, 4th or reverse it is your roll pin.
Old 03-02-2016 | 09:23 PM
tomj77's Avatar
it was literally a 2 hour job for me. first realized visions put all my command start modules right above the shifter cable so I had to remove all that crap first. then dropping tools in by the shifter all the time, have to just allen wrench to do my gear cable cause of the stainless clamp. then under the car the bolt that holds heat shield above downpipe broke so I had to weld that back on. and so forth lol. oh and finding tools I misplaced took up some time to
Old 03-03-2016 | 11:57 AM
T-Man's Avatar
Hahaha, the story of my life when it comes to "simple" or "easy" jobs. Stupid stuff always seems to happen and interfere.
I feel your pain Tom
Old 03-03-2016 | 01:14 PM
tomj77's Avatar
Lol
Old 03-06-2016 | 10:49 AM
colodude18's Avatar
This. Whenever I say or think "That shouldn't take me more than an hour". 4 hours later.... lol
Old 03-06-2016 | 11:50 AM
tomj77's Avatar
pretty much, and half that time, looking for tools u just put down beside you and they magically go up and walked across the room behind the air compressor or something along those lines lol
Old 03-06-2016 | 11:57 AM
cluelessk's Avatar
Ya mine didn't go smoothly. Had no idea you just needed to pull the collar back to remove the cables. Fought it for so long felt so dumb.
OSHAWAHHRSS
12-22-2016 07:02 PM
bland1
03-12-2016 08:46 PM
Snail_SS
02-26-2016 03:01 PM
KrayzieDiablo
02-25-2016 01:07 PM
TheReaper855
Tuning
02-24-2016 07:03 PM
Quick Reply: Lnf shift cables
