May have solved 100% E85 on LNF puzzle
Old 03-18-2011 | 10:22 PM
  #351
mongorat427's Avatar
Originally Posted by VinceTrifecta
I wish I had something to give to you. Lol. The difference in tuning with E85 is you may pass MBT without knowing it. Usually, with gasoline you hit knock around MBT so it can be a useful guide to know when you're close. This might not happen with E85 due to its knock resistance.
I'm going to the dyno tomorrow to optimize the tune for E85. After that I will have something to give you.
A finished tune I hope. Cant Wait
Old 03-18-2011 | 11:11 PM
  #352
gmtech16450yz
Guest
Posts: n/a
Correct. We're at about 330* BTDC with IAB now instead of 240* BTDC which is the stock (very conservative) setting.
EDIT: Just checked the LHU cal, it calls for up to 354* for injection start point at max air mass and RPM.
Minimum on the LHU is 272*, is the 240* on the LNF the min or max?
I'm thinking maybe we need to ditch the Bosch E69 and just convert the LNF's to run on the E39 ECM. There's plenty of good tables supported already. Boost control, fuel pressure, injector timing, stoich, etc.
  #353
MS3 2 SSTC's Avatar
Can I haz an E85 tune also??
Old 03-18-2011 | 11:22 PM
  #354
VinceTrifecta's Avatar
"Minimum" on LNF is 160*, and "maximum" is 240*.
There's nothing wrong with the E69 per-se, just that nobody seems to want to support it. The same tables in the E39 more or less are in the E69 too.
And one advantage it has over all the Delphi cals I've seen is it supports and implements a factory wideband.
Old 03-18-2011 | 11:53 PM
  #355
RyRidesMotox's Avatar
In preparation for the E85 frenzy... here is a list of every E85 station in america... according to the feds... Hey the government turned out to be good for something after all...
AFDC Ethanol: E85 Fueling Station Locations
Old 03-19-2011 | 01:41 AM
  #356
gdubs's Avatar
Hey Vince.. My father works for delphi and is an engineer there. If u need any info on somethign he might be able to get it for you
Old 03-19-2011 | 12:04 PM
  #357
drewbroo's Avatar
I go to the track almost every weekend, so its not like I am missing too much (:
E85 is really going to help with the 110 degree temps here in AZ
Old 03-19-2011 | 01:47 PM
  #358
ssturbo305's Avatar
x22222222222222
everyone is gonna have an orgasm soon
Old 03-19-2011 | 04:14 PM
  #359
Iam Broke's Avatar
Looking forward to Vince's dyno findings...
Old 03-19-2011 | 04:21 PM
  #360
cubaniche's Avatar
^^ Me too.
Old 03-19-2011 | 04:24 PM
  #361
slowbalt84's Avatar
Originally Posted by ssturbo305
x22222222222222
Too late
Old 03-19-2011 | 04:55 PM
  #362
gone_in_10_sec's Avatar
E85 tune & EFR TC/Cam setup - one of us in the forum will definitely hit the 10's or 9's!!!
Old 03-19-2011 | 05:08 PM
  #363
ripped's Avatar
awaiting vinces dyno numbers
Old 03-19-2011 | 07:16 PM
  #364
Quick update in between family commitments on this sunny weekend:
248WHP baseline on my bone stock HHR SS, untuned
301WHP tuned on 92
335WHP tuned on 100% E85
I couldn't really see the torque gains because my clutch is so iffy as it is, and I had to start my runs at 4000-4500 RPM.
Full report to come later
Old 03-19-2011 | 07:26 PM
  #365
Iam Broke's Avatar
Nice gains for sure!
Old 03-19-2011 | 07:27 PM
  #366
SSPainter's Avatar
sekz
Old 03-19-2011 | 07:30 PM
  #367
T-Man's Avatar
I've found the LNF (using 91 octane...) to be knock limited and MBT was no where to be found as I was only capable of running 13* up top, at most. No crazy boost pressure either.
FWIW, I found on my own stock car (HPT+ E48) that raising timing above 23* netted me a loss in power. Could very well be different on other cars.
301WHP tuned on 92
What kind of timing did you use in order to achieve what you did with E85? When did you start to ramp it in/where was peak?
With regards to longevity of both the motor and rail/injectors, how will opening the injection window affect things?
Old 03-19-2011 | 08:11 PM
  #368
Omnigear's Avatar
What mods on the hhr vince?
Old 03-19-2011 | 08:37 PM
  #369
MS3 2 SSTC's Avatar
301WHP tuned on 92
Nice gains Vince!
Was that on a completely stock HHR??
  #370
gmtech16450yz
Guest
Posts: n/a
LNF is most definitely knock limited on 91 oct gas.
He said his HHR is bone stock, that means (or should mean) no mods.
Old 03-19-2011 | 08:42 PM
  #371
MS3 2 SSTC's Avatar
If it's bone stock then HOLY ****!!! wonder what numbers a lightly modded LNF can achieve?
Looks like I will be needing an upgraded clutch next!
Old 03-20-2011 | 12:11 AM
  #372
AndrewSS/TC's Avatar
So you had an 87hp increase by just playing with timing and tuning for e85? That's impressive.
Old 03-20-2011 | 01:38 AM
  #373
Yes, my HHR SS is bone stock. It made more power tuned on E85 than any bolt-on modded LNF I've dynoed at the local dyno.
Old 03-20-2011 | 01:44 AM
  #374
MS3 2 SSTC's Avatar
Good work Vince!! Can't wait till you release it for the 09-10 LNFs
Old 03-20-2011 | 01:46 AM
  #375
I found the best power at .88 lambda and 20* total advance at the top end. I tried 21*, that resulted in a loss. I tried .90 lambda, that resulted in a loss. I tried .86 lambda and it was almost identical as .88 so I stuck with .88.
I expect taking the approach of opening the window vs, say raising the rail pressure (all my testing was done at stock rail pressure of 2200psi) will result in less wear on the high pressure components. I've heard of one person having problems with the high pressure pump from raising the rail pressure, and others (including myself) have had unstable rail pressures resulting in periodic P0087 codes.
I also had a chance to try the injection timing stuff on another LNF that was tuned for gasoline on the dyno - advancing the injection timing had basically no effect on the power.
We can offer these tunes now for all LNFs (if we're doing the tuning). The layer isn't finished for 07, 09 and 10 yet, though.
Last edited by VinceTrifecta; 03-20-2011 at 01:46 AM. Reason: Automerged Doublepost
Quick Reply: May have solved 100% E85 on LNF puzzle
