May have solved 100% E85 on LNF puzzle
Old 03-20-2011 | 01:56 AM
  #376
MS3 2 SSTC's Avatar
Originally Posted by VinceTrifecta
We can offer these tunes now for all LNFs (if we're doing the tuning). The layer isn't finished for 07, 09 and 10 yet, though.
I'm already tuned by you Vince. I was revering to the E85 switch. Should have stated that in my previous post.
Old 03-20-2011 | 02:04 AM
  #377
BlackBeast!'s Avatar
im ready i know he's gonna be crazy busy lol
Old 03-20-2011 | 02:17 AM
  #378
RyRidesMotox's Avatar
When the layer for the 2010 is done post up. I want to put myself in line for the E85 switch.
Old 03-20-2011 | 02:59 AM
  #379
Turbo'dSS's Avatar
Daaanngg... i need a tune so bad. im running HPT right now but maybe ill switch over to Trifecta to run complete E85.
Vince when u say "if your doing the tuning" does that mean i can still go through a local trifecta dealer?
Old 03-20-2011 | 08:46 AM
  #380
HHRSSouth's Avatar
Yes, my HHR SS is bone stock. It made more power tuned on E85 than any bolt-on modded LNF I've dynoed at the local dyno.
Nice, 34 whp just by switching gas
Boo for not having E85 readily available in my area.
Great job Vince.
Old 03-20-2011 | 08:50 AM
  #381
mongorat427's Avatar
Weather looks good today. Im taking my ride out and running the gas out.
Old 03-20-2011 | 11:05 AM
  #382
FF_ace's Avatar
im an 08 in need of you layer file for 100% e85
Old 03-20-2011 | 11:12 AM
  #383
Stik09's Avatar
I found the best power at .88 lambda and 20* total advance at the top end. I tried 21*, that resulted in a loss. I tried .90 lambda, that resulted in a loss. I tried .86 lambda and it was almost identical as .88 so I stuck with .88.
I expect taking the approach of opening the window vs, say raising the rail pressure (all my testing was done at stock rail pressure of 2200psi) will result in less wear on the high pressure components. I've heard of one person having problems with the high pressure pump from raising the rail pressure, and others (including myself) have had unstable rail pressures resulting in periodic P0087 codes.
I also had a chance to try the injection timing stuff on another LNF that was tuned for gasoline on the dyno - advancing the injection timing had basically no effect on the power.
Vince, Thx for burning the midnight oil...
Since this is kind of a new product will there be an up charge for those of us that are already TF tuned? I would not blame you one bit since its a new product in a way... just courious....Either way I am surrounded by e85 stations so im in...
thx
Old 03-20-2011 | 11:17 AM
  #384
Stik09's Avatar
This is a question im sure many of you could answer.
So if the base tune is for gasoline and the activated tune is for e85, can you run the base 92gas tune with e85 in the tank and not hurt the car? I would think so it would just not take advantage of e85 without the e85 tune right?
thx
Old 03-20-2011 | 11:35 AM
  #385
Iam Broke's Avatar
No, it would run waaaaay too lean, by about 30% on E85 when tuned for gasoline.
Old 03-20-2011 | 12:19 PM
  #386
ripped's Avatar
first solstice here waiting for your e85 tune vince
Old 03-20-2011 | 12:27 PM
  #387
Stik09's Avatar
Ok, I thought I read earlier inth this thread that someone was filling up with e85 in prep for this new tune....may have misread though..
So the same would be true in reverse, if you were tuned for e85 and had to put gas in you'ed be running very fat then... right?
Old 03-20-2011 | 12:55 PM
  #388
VinceTrifecta's Avatar
Yes - you can also get our layer and put your HPT tune over the top of our stuff (when that part is ready)
Old 03-20-2011 | 12:57 PM
  #389
Right.
Old 03-20-2011 | 01:12 PM
  #390
T-Man's Avatar
Thank you for taking the time to answer my question(s). I too found a happy medium using .88 versus .89 and .90
You say you saw no difference advancing the injection timing with gasoline but how about E85? It would seem that it would be of further benefit, no?
Thanks again Vince.
Old 03-20-2011 | 01:17 PM
  #391
Thanks again Vince.
Yes, I'd say it makes a big difference. Lol. With 100% E85, and without advancing the injection timing, hitting injection window misfire even on the stock turbo is guaranteed.
Old 03-20-2011 | 01:38 PM
  #392
Turbo'dSS's Avatar
Well im down then. im an 08, and i know one of the guys out here is a trifecta dealer. lol!
Old 03-20-2011 | 01:53 PM
  #393
Here's the dyno sheet. My apologies for the missing parts of the graph, we were having ignition pick up issues on the earlier runs. I had to select a tuned run at 293HP as the 301HP run barely got picked up when displaying in RPM mode.
Also, I started my E85 runs late in the RPM band because on E85 my clutch is extremely unhappy about the extra power at low to mid RPM. I really wish I could show the torque at those lower RPMs because I'm quite sure it would be pretty phenomenal, but, well, I can only do so much with the clutch I have. Lol
The blue run is stock
The red run is tuned for gasoline
The green run is tuned for E85
Old 03-20-2011 | 01:59 PM
  #394
gdubs's Avatar
Do u expect most people with factory clutchs to run into slip while tuned on E85
Old 03-20-2011 | 02:02 PM
  #395
It's something that will have to be closely monitored. We can detune the engine in the low to mid RPM power band where clutch slip is most likely to be an issue. Even on gasoline, unless the vehicle has an upgraded clutch, we don't go full boost until around 4000-4500RPM due to potential clutch issues.
Old 03-20-2011 | 02:04 PM
  #396
drewbroo's Avatar
some people will and some people will not. Its all depends on the driver
Old 03-20-2011 | 02:06 PM
  #397
gdubs's Avatar
Now for those of us who are already trifecta tuned. Will this be another fee or just an upgrade fee?
Old 03-20-2011 | 02:07 PM
  #398
I'll add that every car seems to be different, too. In my experience the 08s have more clutch issues than the 09 and 10 cars. I've heard of some cars holding as much as 400 lb-ft torque and others slipping (like mine) at 340 lb-ft or less.
Old 03-20-2011 | 02:11 PM
  #399
gdubs's Avatar
Also; Vince I herd this stuff is extremely corrosive on a fuel system that inst built for it. Is this a myth? Would we have any issues with this?
Old 03-20-2011 | 02:16 PM
  #400
drewbroo's Avatar
From what I have read on the E85 forums, all cars made 2000 model year and up have anti corrosive fuel lines to support the various blends of detergents and additives in gasoline. (Which includes ethanol.) I Ran E85 in my Saab for a year without any issues other than having to replace the fuel filter. (Got clogged when the 60K mile fuel system was cleaned out with the E85)
Quick Reply: May have solved 100% E85 on LNF puzzle
