May have solved 100% E85 on LNF puzzle
Old 03-22-2011 | 07:14 PM
  #501
Iam Broke's Avatar
More changes headed my way, weather permitting I'll log again tomorrow.
Old 03-22-2011 | 07:15 PM
  #502
drewbroo's Avatar
Originally Posted by Iam Broke
Yea! We need more input! I sent Vince an EZFlash log of a pull today that had some issues.
Yea again!!!
I am going to send more logs tonight too
Old 03-22-2011 | 07:18 PM
  #503
Omnigear's Avatar
just wondering are you guys stating the weather condition with it?
Old 03-22-2011 | 07:19 PM
  #504
drewbroo's Avatar
its hot here in tucson, it will be cold tonight. Still no issues or codes here.
Old 03-22-2011 | 07:21 PM
  #505
09PitchBlackSS's Avatar
So is running full E85 on the LNF "safe"? Do you guys see any long term negative affects from running it?
Old 03-22-2011 | 08:09 PM
  #506
Iam Broke's Avatar
The more the merrier, glad to hear it!
Old 03-22-2011 | 08:12 PM
  #507
MS3 2 SSTC's Avatar
Can't wait to get my file! Already bought 10 gallons of E85. Once I receive my file I'll waste the remaining gas (1/4) and pour the E85
Old 03-22-2011 | 09:43 PM
  #508
Iam Broke's Avatar
Loaded tonights update on break at work, but it's raining, prob won't get a good log in on the ride home.
Old 03-22-2011 | 10:43 PM
  #509
Matt M's Avatar
Originally Posted by cubaniche
Yeah, it basically evens itself out. Stock turbo=Full E. Bigger turbo=50/50. But this is still new and all that may change, or someone may find a way to tune a bigger turbo on full E in such a way that it doesnt pop a CEL.
Even with Vince's advancements in injector timing, full E will not be practical on big turbos.(without added injectors) The mechanical fuel pump simply will not move enough fuel. In the past, we did not work on a pump upgrade because the injection window was still too short unless we could raise fuel pressure to 3500+ psi. Now that Vince has accessed the injection timing tables, it stands to reason that we need to work on a pump upgrade.
Old 03-22-2011 | 10:45 PM
  #510
Turbo'dSS's Avatar
is that a hint toward a ZZp fuel pump upgrade?? lmao!!
Old 03-22-2011 | 10:59 PM
  #511
cubaniche's Avatar
This makes sense. I just never thought anyone would even try to design a higher flowing mechanical pump for the LNF, although that would be nice
Old 03-22-2011 | 11:03 PM
  #512
Iam Broke's Avatar
I'd be all for one. Need more flow. In for a group buy.
Old 03-22-2011 | 11:28 PM
  #513
Matt M's Avatar
Actually, no. We have not worked on anything like this, but it would be a great mod.
Old 03-23-2011 | 12:43 AM
  #514
2000Firehawk's Avatar
The bigger injectors coming out on the 2012 models should take care of things...
Buick News - United States - News
Buick Regal Turbo Gets Industry-First Turbo Direct-Injected Engine with Flex-Fuel Capability
2011-02-21
Back
Print | Email | Word | Add This
PONTIAC, Mich – The 2011 Buick Regal Turbo is the first direct-injected turbocharged production car capable of running on any blend of gasoline or E85 ethanol, joining more than 5 million flex-fuel models General Motors has produced over the last 15 years.
The turbocharged Ecotec 2.0-liter inline four-cylinder engine that powers the Regal will help GM reach its goal of offering more than 50 percent of its production in flex-fuel models by the end of 2012.
Attendees at the National Ethanol Conference in Phoenix will have the opportunity to drive the Regal and the flex-fuel GMC Terrain during conference breaks today.
Compared to earlier versions of the 2.0-liter Ecotec turbo, GM powertrain engineers have significantly upgraded the new engine to accommodate both E85 and to incorporate refinements.
Since ethanol requires a richer air-fuel mixture than gasoline, flex-fuel engines need higher flow-rate injectors. However, a flex-fuel engine can potentially have any combination of gasoline or up to 85 percent ethanol in the tank, so a sensor in the fuel system measures the blend in real-time. This allows the engine management system to automatically adjust the mixture to provide improved performance and reduced emissions and fuel consumption. Stainless steel fuel lines provide extra corrosion resistance to ensure that the Regal Turbo meets GM’s stringent durability requirements.
In the past, improving power output and reducing fuel consumption and emissions were often conflicting goals. By delivering fuel directly to the combustion chamber, the high-pressure injectors can now provide a more precise mixture for optimum combustion.
Old 03-23-2011 | 01:14 AM
  #515
drewbroo's Avatar
I did some pulls tonight in my mostly stock sedan (only mod is ZZP AB Mod)
61-100 in 4.8 Seconds on vinces tune
60-100 in 5.0 Flat on another pull
Here is the evidence.
PULL number 1:
PULL number 2:
My altitude is over 3000ft here and I am only running 19.5 max advance up top. Not to shabby for a 99.9% stock setup with just E85 and a tune.
I am going to the dyno this weekend.
Old 03-23-2011 | 01:22 AM
  #516
08ssedan's Avatar
You mf'er youre faster than my bolted and e47 tuned balt
Old 03-23-2011 | 01:24 AM
  #517
Spins All Day's Avatar
There are gains to be had by going past 50% E. There is a curve, however, and the majority of the gains are in by that point. For example, you might pick up 25whp by switching from 93 to E50, but only 5whp more by going all the way to E85.
I only picked up 13 WHP from going to 93 to E42.5.
Old 03-23-2011 | 01:28 AM
  #518
drewbroo's Avatar
you should try the sauce then. You want me to put the order in now? I sent steve up with one of my tuning cables.
Old 03-23-2011 | 01:29 AM
  #519
08ssedan's Avatar
Fuggit, just do it
Old 03-23-2011 | 01:30 AM
  #520
drewbroo's Avatar
Fuggit, just do it
Will do
Old 03-23-2011 | 01:35 AM
  #521
xcross's Avatar
I just ordered the corn from Vince. I cannot wait.
Old 03-23-2011 | 01:36 AM
  #522
InfraRedline's Avatar
Get some more timing in that bish! Nice times though
Old 03-23-2011 | 01:43 AM
  #523
drewbroo's Avatar
Vince is sending me a few files to mess with with increased timing for the dyno this weekend.
Old 03-23-2011 | 01:44 AM
  #524
08ssedan's Avatar
Will do
Lets burn up my clutch
Old 03-23-2011 | 01:49 AM
  #525
drewbroo's Avatar
my clutch is fine. I now have wheelspin going into 3rd
Quick Reply: May have solved 100% E85 on LNF puzzle
