May have solved 100% E85 on LNF puzzle
Old 03-23-2011 | 01:51 AM
  #526
08ssedan's Avatar
Well im getting a new one anyways
Old 03-23-2011 | 02:06 AM
  #527
InfraRedline's Avatar
Originally Posted by drewbroo
Vince is sending me a few files to mess with with increased timing for the dyno this weekend.
Thats what I like to see
Old 03-23-2011 | 08:24 AM
  #528
Iam Broke's Avatar
I did some pulls tonight in my mostly stock sedan (only mod is ZZP AB Mod)
61-100 in 4.8 Seconds on vinces tune
60-100 in 5.0 Flat on another pull
snip...
Very nice! I still can't get enough fuel into mine. Two pulls last night with some inj window misfire, logs sent.
Raining today and I have to work 11a - 11p so I don't expect to be able to test much.
Old 03-23-2011 | 08:44 AM
  #529
Sweetsandman's Avatar
Damn, if my nearest E station wasn't across the damn city, I'd totally want this. It would just suck having to go that far out of my way everytime I was low on gas. Maybe I should get 2 tunes; ballsy, and *****-to-the-walls
Old 03-23-2011 | 08:54 AM
  #530
mongorat427's Avatar
Get 4 VP Fuel Jugs like I did
Old 03-23-2011 | 09:06 AM
  #531
Or that
Old 03-23-2011 | 09:12 AM
  #532
I needed to order some other stuff from my parts warehouse and grabbed them up cause I get a big discount on shipping . Glad I kept my jobber status with them all these years.
Old 03-23-2011 | 09:42 AM
  #533
umrdyldo's Avatar
Make sure to give the E85 a good mixing before dumping into the car. Also might want to use Stabil for ethanol in the jugs.
Old 03-23-2011 | 10:14 AM
  #534
BYT*SS*TURBO's Avatar
Drew - have you logged IDC and PW as well?
Old 03-23-2011 | 10:27 AM
  #535
New Jugs and the fuel will never be in there more than a couple weeks. I need them for the first fill up and back up when I go to the track which is 40 or 80 miles away depending on which one I go to. I dont want to be looking for E85 stations when Im out of town.
Old 03-23-2011 | 10:29 AM
  #536
Or that
Better yet their the same color as my ride.
  #537
2FST4U's Avatar
I don't have time at the moment to read all the post. Could someone help summarize what is needed to be done for the TC E85?
I know I will need a tune, but do I have to change any lines, fittings, regulator, or filters?
Or maybe any other things need changed?
Old 03-23-2011 | 10:34 AM
  #538
drewbroo's Avatar
I can if you would like. I was just trying to look at the basics. Do you have a specific config you want me to log with?
Old 03-23-2011 | 10:38 AM
  #539
What plugs is everyone running with their E85 tunes. Im running NKG 1 step cooler with 93 and thought I might need to go back to regular heat plugs.
Old 03-23-2011 | 10:47 AM
  #540
drewbroo's Avatar
stock plugs with 32K miles on them
Old 03-23-2011 | 10:48 AM
  #541
Iam Broke's Avatar
Still 1 step colder, NGK 3787's
Old 03-23-2011 | 11:05 AM
  #542
Thats whats in it now.
Old 03-23-2011 | 11:31 AM
  #543
Matt M's Avatar
I'm running stock plugs.
Old 03-23-2011 | 11:33 AM
  #544
cubaniche's Avatar
Same here. Stock plugs. New, stock plugs.
Old 03-23-2011 | 11:59 AM
  #545
2000Firehawk's Avatar
mongorat427
With the stock turbo, I think you'll find that a 2:1 Emix will work the best.
Straight E85 will cause both fuel pumps to work much harder, causing more wear,
harder starting in cooler temps, more cylinder 'wash' down, more trips to the 'pump' as you're going to use more fuel, & NO GAIN in power with straight E85.
Even Vince states that going from a 1:1 Emix to straight E85 might get you 5hp.
Go to Walmart & buy a $1.97 rain gauge, to check for Ethanol mixture.
Walmart $1.97 rain gauge on ebay
Acu-Rite Rain Gauge 5" Capacity New! Great Price! US - eBay (item 250792977745 end time Apr-21-11 15:27:21 PDT)
I tested Sheetz E85 + 3:1, 2:1, & 1:1 mixes with Sheetz E10 yesterday.
E85 = 81.33
3:1 = 64.66
2:1 = 57.22
1:1 = 44.66
Put 6cm of water in the rain gauge for each test.
Than put 6cm of whatever "E" your testing E85 , 3:1 , 2:1 , or 1:1
Rain gauge reading, {with Sheetz E85 & Emixes yesterday}, after shaking & waiting a few minutes for it to settle.
11cm = Straight Sheetz E85 = E 81.33
10cm = 3:1 E85/E10 mix = E 64.66
9.4cm = 2:1 E85/E10 mix = E 57.22
8.8CM = 1:1 E85/E10 mix = E 44.66
E85 is never really a true E85 as stated on the pump.
E10 is never really E10, all pumps state, may contain up to 10% Ethanol
That's why you should test your stations E85 when you tank up with your Emix.
Just splash a cup of E85 into an empty 1 gallon gas can when you tank up, then test at home if you need to.
If your LTFT didn't change with your new tank of Emix, no need to test, {might take a day for the mix to 'blend' in your tank}.
No need to check the E10 as it is mostly the same around E6-8, & a couple of % here doesn't matter.
Hay if you want to check what Emix is in your tank right now.
Amazon.com: Milton (MILS-445) 4-in-1 Steel-Plated Tire Valve Repair Tool: Home Improvement
Buy a 'tire-gut' removal tool, {like in the above link}, & remove the fuel 'gut' under the black-cap on your fuel line on the engine. Don't forget to relieve the fuel pressure 1st. Run a 5 foot, 3/8" fuel hose to a completely empty 'bone dry'1 gallon gas can lying on the ground. Turn your key to run & you'll hear the fuel pump run for a couple of seconds. Do this 4 times in a row & you'll have a 'cup' of gas in your gas can.
When storing any gas, forget the Sta-bil , Star-Tron stuff.
Just a tiny amount of Coleman 'white-gas' wil do the trick.
If you look at their MSDS sheets, 95% of their stuff in that 'little bottle' is just plain old 'white-gas'.
The 'white-gas' is just putting a 'sheen' on the surface to keep moisture out.
Also when running any Emix, add 1oz of 'white-gas' to a full tank ,for lubrication, as Ethanol is 'dry', & you always need a little lube...
Old 03-23-2011 | 12:11 PM
  #546
drewbroo's Avatar
Originally Posted by 2000Firehawk
mongorat427
harder starting, more cylinder 'wash' down, more trips to the 'pump' as you're going to use more fuel, & NO GAIN in power over straight E85.
I tested Sheetz E85 + 3:1, 2:1, 1:1 mix yesterday.
E85 = 81.33
3:1 = 64.66
2:1 = 57.22
1:1 = 44.66
Than put 6cm of whatever "E" your testing E85 , 3:1 , 2:1 , 1:1 or whatever.
Rain gauge reading, {with Sheetz E & mixes yesterday}, after shaking & waiting a few minutes for it to settle.
Buy a 'tire-gut' removel tool & remove the fuel 'gut' under the black-cap on your fuel line on the engine. Don't forget to relieve the fuel pressure 1st. Run a 5 foot, 3/8" fuel hose to a completely empty 'bone dry'1 gallon gas can lying on the ground. Turn your key to run & you'll hear the fuel pump run for a couple of seconds. Do this 4 times in a row & you'll have a 'cup' of gas in your gas can.
E 85 seems to be working the best for my car over the 50/50 mix. Its 60-100 time is almost as fast as my fully folted coupe on the dual layer tune and the 50/50 mix.
Old 03-23-2011 | 12:25 PM
  #547
Yea, the 50/50 = E47.5 {1:1}, is an excellent 'base', but the 2:1 mix = E60 rocks...
No special 'tune'{changing injector timing}, is needed, a 'normal' HPtuner/Trifecta ' tune', for an Ethanol mixture,{1:1 or 2:1}, is all that is needed.
Old 03-23-2011 | 12:33 PM
  #548
drewbroo's Avatar
Yea, the 50/50 Emix, {1:1}, is an excellent 'base', but the 2:1 = E60 rocks...
as in 2:1 you mean 66.6% E85? If this is true, we have E70 here in Tucson at the shell stations.
Old 03-23-2011 | 01:19 PM
  #549
1:1 or 50/50 mix = E47.5 = 1 part E85 + 1 part E10
85 + 10 = 95 divided by 2 = 47.5
2:1 = E60 = 2 parts E85 + 1 part E10
85 + 85 + 10 = 180 divided by 3 = 60
Old 03-23-2011 | 01:27 PM
  #550
drewbroo's Avatar
Gotcha. We have E 70
70+70+10=150/3 and its still E50 or 1:1
What I do not like about mixing is the chance of the fuel mixture being off. If I use the same gas station with the same gas, my STFT/LTFT's stay consistant.
Quick Reply: May have solved 100% E85 on LNF puzzle
