May have solved 100% E85 on LNF puzzle
Old 03-24-2011 | 11:10 AM
  #601
mongorat427's Avatar
My 09 is fully bolted at 340 HP so Im going to be interested to see what happens when I load it up with the E85 File
Old 03-24-2011 | 11:14 AM
  #602
BYT*SS*TURBO's Avatar
Im heading to the dyno on Sat to tune a couple cars for them, Im going to try and get my car on there with the Full E85. Just did 346/414 last time with the 1:1 E Blend.
Old 03-24-2011 | 11:25 AM
  #603
Iam Broke's Avatar
Originally Posted by Cavalierssr
The 09 that threw the P0087 was mine, with the update though I haven't had any issues so far and I've been doing a lot of pulls. My car has all the bolt ons except for the lower CP and intercooler.
Makes me think my HPFP is weak then. 57k on the odo. We'll see how BYT's does.
I could lean out the <4k area a bit more, but 2% isn't going to save me.
Old 03-24-2011 | 11:26 AM
  #604
Looking promising for a lunch Flogging. Sun is out and roads are semi dry. I already loaded everything up, so we'll see
Old 03-24-2011 | 11:27 AM
  #605
Keep up the good work!!
We need Spring to get here.
Old 03-24-2011 | 11:29 AM
  #606
My Fuel Jugs arrived yesterday so Ill head over to the Sheetz and get 15 gallons and hopefully I can tune it this weekend.
Old 03-24-2011 | 11:31 AM
  #607
Iam Broke's Avatar
In for the results!
Old 03-24-2011 | 11:36 AM
  #608
Im Just wondering about the Meth. Vince is going to tune it based on my last update with the Devils Own Meth installed. It really helped on 93 but I dont know about on E85.
Old 03-24-2011 | 11:45 AM
  #609
08ssedan's Avatar
I am bolted and running an e blend, I popped the p0087 on the dyno a few weeks ago so hopefully like the other 09 that posted up I'll be running fine on 100% e.
Old 03-24-2011 | 11:55 AM
  #610
Stamina's Avatar
My car's one of the cars that Vince was talking about earlier (the last '09 mentioned).
To switch over, I waited until I had just under a gallon of 93 in the tank and then topped off on E85, reflashed, and then drove around for 15mins or so to get the mix flowing and began logging. Fuel trims were initially negative and then LTFT drifted back to zero as the E85 mixed and began getting used.
As far as running E85, so far it really seems to take well to it. Idle and normal driving is very smooth, all random knock has disappeared, and it pulls remarkably harder. I was pleasantly surprised.
Old 03-24-2011 | 12:08 PM
  #611
MS3 2 SSTC's Avatar
Already got mine!!! Only thing is the wifey poured $30 worth of gas yesterday so I'll have to wait!!
Old 03-24-2011 | 12:32 PM
  #612
FF_ace's Avatar
what size nozzel you running? if your still having fuel issues with the 100% e85 maybe up the meth nozzel to help compensate. im running a 3gph now when i install the 5857 i will be running a 7gph to help with fuel
Old 03-24-2011 | 12:38 PM
  #613
FF_ace's Avatar
thats crazy that your fully bolted and not running into issues like iambroke but thats awesome everything is going good for you
Old 03-24-2011 | 01:08 PM
  #614
Garret's Avatar
This is getting good
Old 03-24-2011 | 01:10 PM
  #615
Off to test
Old 03-24-2011 | 01:13 PM
  #616
Stik09's Avatar
Yea, I can't wait... just placed my order...
Old 03-24-2011 | 01:46 PM
  #617
Well with the 1:1 still in the tank and reverting my MAF tables back to pre-E tune tables, the LT shifted 7.8% + after loading the new layer. So its def doing something, before I had 12-14% +.
I did a couple pulls and with reduced DAL's I am having a REAL hard time getting traction in 3rd lol.. IPW was 9-10ms max and IDC never went over 33% and that was a spike once. I have half a tank of 1:1 in there that will almost be gone by the time I get home. Should be perfect to fill tomorrow afternoon with straight E and then when I head to the dyno, I pass the E fill station again
Dyno will happen on Sat
Old 03-24-2011 | 01:59 PM
  #618
VinceTrifecta's Avatar
Nice, looking forward to seeing your results
Old 03-24-2011 | 02:04 PM
  #619
Iam Broke's Avatar
I didn't have any issues until I got north of 75% but I hope you get all the way to E85 Nick!
If you do, I'll pop for a new HPFP for mine.
Old 03-24-2011 | 02:13 PM
  #620
You may want to try to prove the issue is the HPFP before you buy a new one. I've heard of a few cases where people got a P0087 on gasoline / stock turbo that had it resolved by replacing/upgrading the "LPFP" in the tank.
How are you going to prove it? That might be tricky but it sounds like ZZP found a way to put a pressure fitting right at the HPFP inlet
Old 03-24-2011 | 02:17 PM
  #621
Iam Broke's Avatar
Yep, ZZP and I posted back & forth last year about the LPFP issues. Something else to investigate.
Old 03-24-2011 | 02:23 PM
  #622
You can get a Walbro 255 for $85 shipped and Im sure it wont take more then 2 hrs to install. Worth a shot IMO.
Old 03-24-2011 | 03:00 PM
  #623
cmiller8006's Avatar
Will it hurt to just go ahead and do a walbro?
Old 03-24-2011 | 03:05 PM
  #624
Ha Ha Waiting for someone to try it?
Old 03-24-2011 | 03:17 PM
  #625
elecblue06's Avatar
good luck nick
Quick Reply: May have solved 100% E85 on LNF puzzle
