May have solved 100% E85 on LNF puzzle
Old 03-27-2011 | 12:33 AM
  #751
Matt M's Avatar
Originally Posted by Stik09
Just updated my tune and am very pleased. No codes... sent logs to Vince for review.
I did notice in 3rd it seems to have a soft spot, very slight around 4k and then goes away. Worried that it could be clutch slipping but dont smell burnt clutch. Could be tires spin too I guess but does not seem like the tire spin. I would think that the clutch would be more likely to slip in 3rd too. second pulls super hard even with tires spinning a little.
Running BFG DR so after second gets em hot I would not think its slight tire spin but could be.
Thoughts... I know its hard to say without being there so its more of a crystal ball question...lol
When you are at peak torque, you are using the most fuel per engine cycle. The mechanical fuel pump which operates relative to engine speed falls behind until the cylinder air mass decreases enough for the pump to keep up again.
Old 03-27-2011 | 12:42 AM
  #752
raver0789's Avatar
aka less boost till 5k?
Old 03-27-2011 | 02:39 AM
  #753
xcross's Avatar
Well I am glad I am not the only noticing something going on in third gear . Seems to lag or stumble when you get on it, then will come on really strong. Not that I am complaining as the shear torque is amazing.
Old 03-27-2011 | 02:57 AM
  #754
ssturbo305's Avatar
is anyone gona dd with the 100% corn tune?
Old 03-27-2011 | 02:58 AM
  #755
08ssedan's Avatar
Quite a few people are.
Old 03-27-2011 | 03:03 AM
  #756
ssturbo305's Avatar
just gota ignore the horrible mpg and just keep filling her up lol
someone needs to hit the track with this new tune.
let's see some traps!
Old 03-27-2011 | 03:04 AM
  #757
xcross's Avatar
I will be doing the dd thing but my nearest e85 station is 30 miles from house, luckily it is right next to my work. I will be getting two new 5 gallon gas cans just in case i do lots of driving over weekends.
Old 03-27-2011 | 03:06 AM
  #758
08ssedan's Avatar
Drew posted up last night.
Old 03-27-2011 | 05:57 AM
  #759
drewbroo's Avatar
I got 27.3 MPG Hwy on my way to phoenix at mostly 75-80 MPH. And I ran consistant 111+ MPH traps. (111.94 was my best with a 13.0 ET) Only mod is tune and AB mod
Old 03-27-2011 | 07:41 AM
  #760
MS3 2 SSTC's Avatar
I'm one of those people in a DD full E85 SS. 300+ miles in and not one problem!! I've also noticed that my mpg have stayed the same, I think it might be a bit better... Well that's if I can keep my foot off the gas!!!
Old 03-27-2011 | 08:09 AM
  #761
1LowLS's Avatar
I trapped 110.Not bad for the 1st time driving a E85 LNF,or hell a LNF at all
Old 03-27-2011 | 08:20 AM
  #762
Iam Broke's Avatar
The displayed MPG on the DIC stays the same, calculate it and you will probably find it different. I think it is due to the fuel mass change in the tune. DIC read ~30% higher than actual on mine anyway.
Old 03-27-2011 | 10:45 AM
  #763
Stik09's Avatar
thx for the feed back xcross - does your boost spike higher now?
Yea, I have not been hard into 4th but 3rd it does it at little. Yesterday afternoon when it was hot it was hard to notice. Last night I was going to hit the track but chickened out. With the cold dense air it was very noticeable. I forgot my cable so could not log. Its still cold this am so will go log a run.
Vince said looked like a little IDC and a little clutch slip. Gonna see what we can do to get rid of it. My boost was pretty high to, spiking to 25 at least. Just keeping the boost at 22 may resolve it.
I saw earlier in this thread a link to some data logging software that works with the tactrix cable. Will try that too so I can see the logs.
Old 03-27-2011 | 01:28 PM
  #764
xcross's Avatar
I think Vince sell's the software and I am going to get it also. So hard to describe what it is that i am noticing, could be clutch, Vince has reviewed the logs and said the car is running really good and it is.
I have not been paying attention as to what my boost has been doing."holding on for dear life" at WOT. Will take a look later on today.
I agree with the previous post that the dic is not calculating mpg correctly as i can assure you my mpg has dropped 30%.
Old 03-27-2011 | 01:59 PM
  #765
08ssedan's Avatar
Car has been pulling good, no codes since the first night... Trying to get it logged this week.
Old 03-27-2011 | 02:00 PM
  #766
1LowLS's Avatar
Ill get up there sometime soon to log it
Old 03-27-2011 | 02:02 PM
  #767
08ssedan's Avatar
Ill meet you halfway. I can tuesday after class if you arent busy. Around 1030
Old 03-27-2011 | 03:42 PM
  #768
Boogie_69's Avatar
is the e85 tune in a selectable state that can be switched on and off like the other trifecta tune
Old 03-27-2011 | 03:43 PM
  #769
xcross's Avatar
no
Old 03-27-2011 | 03:45 PM
  #770
MS3 2 SSTC's Avatar
No it's not.
Old 03-27-2011 | 04:02 PM
  #771
jarhead's Avatar
Depends on what he means yes it still has a stock boost level with selectable tune switch to the higher boost tune. If he is working off of you're original gas tune and you have selcta tune before you have it now my car does. But no it does not have a gas to e85 switch not yet anyway
Old 03-27-2011 | 04:10 PM
  #772
MS3 2 SSTC's Avatar
Originally Posted by jarhead
Depends on what he means yes it still has a stock boost level with selectable tune switch to the higher boost tune. But no it does not have a gas to e85 switch not yet anyway
so are both select a tunes are tuned for E85? im afraid to hit the cruise control button because if i do i have the GMS1 tune and i dont want to mess up the car.
Old 03-27-2011 | 04:18 PM
  #773
jarhead's Avatar
I have the gmstage1 based tune on my gas tune also as the tune off mode. I drove 30 miles on the lower gmstage1 stock tune and the car ran fine really smooth. I asked Drewbrew about it before because I wasn't sure about that also if it mattered which mode it was in. I like to do my daily drive to work in bumper to bumper traffic in the stock mode and save the higher level tune for when I need it thinking maybe it is easier on the car. Maybe Vince will jump in on this pretty sure it works just fine on the lower boost stock setting also?
Old 03-27-2011 | 04:28 PM
  #774
MS3 2 SSTC's Avatar
I have the gmstage1 based tune on my gas tune also as the tune off mode. I drove 30 miles on the lower gmstage1 stock tune and the car ran fine really smooth. I asked Drewbrew about it before because I wasn't sure about that also. I like to do my daily drive to work in bumper to bumper traffic in the stock mode and save the higher level tune for when I need it thinking maybe it is easier on the car. Maybe Vince will jump in on this pretty sure it works just fine on the lower boost stock setting also?
I hope Vince will becable to confirm this. For now I'm not using the cruise control.
Old 03-27-2011 | 04:31 PM
  #775
drewbroo's Avatar
THey are both E85, with the tune off, its just low boost mode. Tune on its high boost mode
Quick Reply: May have solved 100% E85 on LNF puzzle
