May have solved 100% E85 on LNF puzzle
Old 04-04-2011 | 04:01 PM
  #876
SmokinSam06's Avatar
yeah, it gets like -25 around here during the winter season so thats probably the only thing i am worried about!
Old 04-04-2011 | 04:22 PM
  #877
AndrewSS/TC's Avatar
So with e85 is there any effect in regards to reliability? Also say you have to go in for warranty work, so you flash back to the stock tune; would they be able to tell e85 was ever used in the car?
Old 04-04-2011 | 04:29 PM
  #878
bobbyhill31286's Avatar
i just got the 50/50 tune on friday and.....DAMN lol. im gonna run this for a few weeks and might decide to go 100% cuz I look retarded sitting at a gas station holding a gas can adding the E then adding the 93
(closest e85 station to me is like a 1/2hr away)
Old 04-05-2011 | 02:56 PM
  #879
ssturbo305's Avatar
Same thing happens to me but when I cold start in the morning its close to 90 degrees anyone know why this might be happening
Originally Posted by mongorat427
The only minor issue I had was cold starting. For some reason I would try to start the car and it would just crank. On the second try it would start right up. So now I just crank it for 2 seconds turn it off and it starts right up. Cold only 25 degrees
Old 04-05-2011 | 03:03 PM
  #880
Stamina's Avatar
When I'm turning on the car, I'll put it in "Run" for a sec to let the pump finish priming first, and then try starting it. This seems to help.
If it still doesn't help, then do it twice before starting.
Old 04-05-2011 | 03:30 PM
  #881
ssturbo305's Avatar
So my problem is normal? Even with the weather being 90 degrees? I thought it would just have problems starting when the weather is cold. Would this problem u think go away with e47 mix?
Old 04-05-2011 | 03:36 PM
  #882
Stamina's Avatar
Well, until more people chime in, I don't know if I could say it's "normal".
I do know that several people have mentioned it though. I don't think that the mix would alleviate it either, because one of the people I know with the problem is on the mix.
Old 04-05-2011 | 03:46 PM
  #883
Iam Broke's Avatar
I'm running full E85 on Vince's layer/HPTuners tune and it starts fine even at 20*f. I think you may have another issue. Did you send a log to Vince for him to look at?
Old 04-05-2011 | 04:10 PM
  #884
Stamina's Avatar
The starting thing only seems to only be a problem when it's been sitting for a while (like maybe a day or more). It'll either crank an extra half-second, or will start as fast as normal but run weak for a split second as the RPMs rise right after startup, and then resume normal operation. If you are restarting when it hasn't been sitting for like a day, like running errands or something, then it starts just like normal.
Yup... been sending them in somewhat regularly recently. Yesterday, he sent me a new leaner rev, and I logged it last night. I actually had to do it in two parts because although it was happy earlier in the day, a cold front blew through a brought temps down to the 50s before midnight. So I went out again and logged in the colder temps, as that's where it was having trouble with the fueling keeping up.
The new rev seems as happy as a clam in hot or cold so far.
Old 04-05-2011 | 05:23 PM
  #885
phillips01's Avatar
could be fuel leak down ?possible from damaged fuel pump check valve from the E85?like to know the outcome of this one
Old 04-05-2011 | 05:34 PM
  #886
Stamina's Avatar
Possibly.
It's such a small issue that I'm not going to be chasing it unless I'm swapping the pump or something. It doesn't cause me any problems worth looking into. Maybe it'd be worth it to somebody else though.
Old 04-05-2011 | 08:41 PM
  #887
Stik09's Avatar
I have not had that issue with temps ranging from 40 to 85 deg. When I first start the car I have to let it warm up for a sec though. If I touch the gas to soon it will roll a little. I'm on my second tank full of 100% E85
Old 04-05-2011 | 09:01 PM
  #888
xcross's Avatar
my car is very hard starting on the e85. takes like 4 tries. Wonder what we have in common that some don't. Intake maybe
Old 04-05-2011 | 09:09 PM
  #889
08ssedan's Avatar
Are you having any fueling issues with your tune?
Old 04-05-2011 | 09:13 PM
  #890
jarhead's Avatar
Its not the cold I do not think has been a lot colder than that here and my car has been fine for a week and a half no problems at all actually.
Old 04-05-2011 | 09:16 PM
  #891
xcross's Avatar
not that I can tell. No codes and pulls real hard. Just will not start in the morning. I have put maybe 8 tankfuls of e85 thru so far and the starting issues are getting troublesome. I might switch back to 91 tune later this week to see what happens. I will also let the fuel pump cycle a few times in the morning prior to starting to see if this helps.
Old 04-05-2011 | 09:39 PM
  #892
08ssedan's Avatar
What is the highest you have taken it? Around 120-140 I will get a fuel cut. I thought it was my intake so I had taken it off but I am still running into problems, I'm hoping a retune for my stock AB will take care of it.
Old 04-05-2011 | 09:44 PM
  #893
xcross's Avatar
I have not been over 110 but I suspect there might be trouble. Do you have a for lack of better term a dead spot in third gear also or moment of hesitation.
Old 04-05-2011 | 10:02 PM
  #894
ssturbo305's Avatar
Let you guys know in the morning if starts good with e47 new tune
Old 04-05-2011 | 10:04 PM
  #895
08ssedan's Avatar
Towards the end of third sometimes i will get a hiccup and then itll pop the code and reduce the engine power. Its only late in 3rd or 4th.
Old 04-05-2011 | 11:52 PM
  #896
BlackBeast!'s Avatar
hahahaha your car sucks ass lol jk i think after your retune youll be fine
Old 04-06-2011 | 12:04 AM
  #897
08ssedan's Avatar
Yeah we also thought itd be fine after I put my airbox back on
Old 04-06-2011 | 12:11 AM
  #898
drewbroo's Avatar
I also said you will need a retune when you put your ab on Patience my son
Old 04-06-2011 | 12:32 AM
  #899
smthomas556's Avatar
Hey you AZ bastards. Get back to the BS thread!
Old 04-06-2011 | 07:37 AM
  #900
ssturbo305's Avatar
How weird just tried cold start e47 works perfect
Quick Reply: May have solved 100% E85 on LNF puzzle
