May have solved 100% E85 on LNF puzzle
Old 04-11-2011 | 09:21 PM
  #976
bamaboy22's Avatar
Ok I had less then 2 gallons in the tank of e85 left. Put 6.25 gallons of 93 in the car and reloaded the tune. Car spit and sputtered for 15 mins at idle. I held it at 3500rpms for 30 seconds and it seemed to be fine then. But on my way home(31 miles) running from a tornado I noticed my exhaust at points would sound like it was camed and the cat was gone. At other points it was fine. No codes at all seems to run fine. So tell me what I done wrong.
Old 04-11-2011 | 09:26 PM
  #977
bamaboy22's Avatar
Originally Posted by elecblue06
what is that noise on the top end of your car t sounds like a ringing ..?
Stared doing it when I put the intake on. Vince said it's fine
Old 04-11-2011 | 09:34 PM
  #978
BlackBeast!'s Avatar
Tea pot mod!
Old 04-11-2011 | 09:38 PM
  #979
xcross's Avatar
why did you not fill it all the way up?
Old 04-11-2011 | 09:40 PM
  #980
bamaboy22's Avatar
Anyone chime in on my problem....
Old 04-11-2011 | 09:44 PM
  #981
bamaboy22's Avatar
1.they were filling the tanks with fuel as i was fueling. 2. i was trying to beat a storm and i still lost
Old 04-11-2011 | 09:46 PM
  #982
I would just say put more in and give a little more time shouldnt be anything wrong at all
Old 04-11-2011 | 09:50 PM
  #983
xcross's Avatar
I concur. More gas more drive= fix
Old 04-11-2011 | 09:53 PM
  #984
bamaboy22's Avatar
i started with only 3gallons and then went back with the rest
  #985
bamaboy22's Avatar
see when i went to e-85 didnt have not a problem but switching back no so good
Old 04-11-2011 | 09:54 PM
  #986
08ssedan's Avatar
Got my e47 loaded today as well, car idled like **** for a few minutes and got some strange notes from the exhaust but mine did not sound like it was cammed. I drove for a while and everything seemed to be fine.
Old 04-11-2011 | 10:08 PM
  #987
deebsr6's Avatar
id recommend running the car down to as low as possible before switching maps. I know I have a 13 gallon tank with a 3 gallon reserve so when I switch I run it for around 30 miles with the light on so that should leave me with a gallon or less in the tank. Then fill it up with the other gas and if its 93 to E85 then take it easy for half a tank then refill with E85 and go at it. E85 to 93 its a tad more lenient because if anything it will just raise the octane a little bit but you still want less then 10% E85 left in there. Completely different car but im sure its the same idea.
Old 04-11-2011 | 10:22 PM
  #988
bamaboy22's Avatar
Well the light had been on for about 10 miles plus me wot all the way to the gas station so I'm sure 1gallon or less
Old 04-11-2011 | 10:25 PM
  #989
xcross's Avatar
did you wot from the gas station to your final destination after adding 6.2 gals of 93?
Old 04-11-2011 | 10:31 PM
  #990
bamaboy22's Avatar
o hell no lol. didnt go over 55 mainly because i couldnt see 2 feet infront of me cause of rain
Old 04-11-2011 | 10:57 PM
  #991
PrincessTurbo's Avatar
Originally Posted by Terminator2
VE airflow is 33-35 lbs/min on my car right now and MAF is 35-36 lbs/min at 24 psi and 88-92* temps. I cannot run more than 14* of timing though because I have 93 octane only no E-85 within 120 miles round trip from me.
Aww man that sucks bad. It's got more power on an 80 degree day running E than on 91 around 35 degrees...
Gotta get that cam driven fuel pump wrapped out. Power band is nuts now.
Old 04-11-2011 | 11:07 PM
  #992
bamaboy22's Avatar
So from what I get from so far is more gas will fix it
Old 04-11-2011 | 11:14 PM
  #993
bobbyhill31286's Avatar
I noticed a difference in the sound of my exhaust since I did this. Kinda hear a sputter/slight backfire sound from the stock exhaust. Car runs great though and Vince said my datalog is good so I'm not worried lol
Old 04-12-2011 | 12:23 PM
  #994
rlhammon's Avatar
What's a good way to drain the fuel tank? I've read on a 'Vette forum that someone rigged up a switch to run the fuel pump and they disconnected the fuel line under the hood and flip the switch... having the fuel pump do the work for them.
Not certain I really want to go this route, as I'm not certain how to do it actually. But for someone like me who is looking at swapping back and forth between 93 and E85 several times a month I need a good way to pull this off.
Still waiting to get the tune... don't have my upgraded clutch/flywheel in the car yet, well, I have the clutch mounted, don't have the tranny back in the GXP yet to be accurate.
Old 04-12-2011 | 07:22 PM
  #995
vahdyx's Avatar
Anyone having cold start issues?
Old 04-12-2011 | 07:26 PM
  #996
cubaniche's Avatar
if your talking about starting the car in cold weather then, yeah, almost everyone, including myself, have had starting issues on full E in colder climate(50 or below). Its normal.
Old 04-12-2011 | 07:38 PM
  #997
vahdyx's Avatar
Well I guess E85 is out for me. Colorado has a crap load of below 50*F days.
Old 04-12-2011 | 07:46 PM
  #998
vahdyx's Avatar
what's cammed exhaust
Old 04-12-2011 | 08:09 PM
  #999
importkiller's Avatar
look up cammed LS1, they sound like pop corn poppers, it means there is an aggressive cam profile, it makes the exhaust note unique but has nothing to do with the actual exhaust piping.
Old 04-13-2011 | 02:18 PM
  #1000
vahdyx's Avatar
I'm confused, how does different fuel change your cam profile?
Quick Reply: May have solved 100% E85 on LNF puzzle
