May have solved 100% E85 on LNF puzzle
Old 04-28-2011 | 03:24 PM
  #1051
Sweetsandman's Avatar
^^^I like to hear that
I also had a weird thought...Since Ethanol burns cleaner than regular gas to the best of my knowledge, would it be possible for one to pass an E test while being catless running full E or even part E?
Old 04-28-2011 | 03:30 PM
  #1052
Terminator2's Avatar
Maybe. E-100 would pass IMHO.
Old 04-28-2011 | 03:34 PM
  #1053
Hmmm...I'll have to experiment with this thought in October when I've gotta get my test done. That would be straight awesome if it worked
Old 04-28-2011 | 03:51 PM
  #1054
Iam Broke's Avatar
In my state, they look for the cat under the car and check the OBDII, no sniff unless it's older. Pre '99 I think.
Old 04-28-2011 | 03:56 PM
  #1055
Hmm that may be how mine is too...because the last time I went with my '02 Blazer they didn't run it they just hooked up the OBDII and told me I was good.
I'd still love them to run it just to see
Old 04-29-2011 | 12:44 PM
  #1056
RyRidesMotox's Avatar
Was that full E-85 or just E-47? I thought you filled up with just E-85? Because if that was just E-47 you were exceeding the max torque the factory injection settings can handle on E-47 which means you are making at least 410 wtrq. Airloads were very high at 326% in 3rd at 4K RPMs.
LOL haha yea that was a 50/50 mix with e85 and 91 octane. No wonder why my car threw a low rail pressure code before we went to straight hptune. I hope what you are saying is good lol this whole fuel injection system crap in new to me... I'm so used to tuning a carburetor.
Old 04-29-2011 | 01:24 PM
  #1057
Yeah your car is a freaking torque monster 330% airloads on E-47 is unheard of IMHO. You are seeing 45% IDC right now with 12.9 mS IPW at 0.883 PE lambda.
I can carb tune as well. I have a WB on my Polaris Outlaw 525 so I can tune it.
Old 04-29-2011 | 01:37 PM
  #1058
LOL torque monster... yea I know tell that to my tires and the V-8s I embarrass from time to time.
This is what I looked like when reading that-------->
Haha a wideband on a quad thats awesome, I never thought of that... I always just arm dynoed my stuff... if I couldn't feel my shoulders getting pulled out of the sockets it wasn't fast enough! haha retune for race gas!
Old 04-29-2011 | 02:01 PM
  #1059
Yep I run 12.6-13.0 A/F on the quad just like the cars I tune LOL. End thread jack.
Old 04-29-2011 | 03:20 PM
  #1060
You still have a low rail pressure issue on E-47. That last file I sent I advanced the injection timing to ~325 to 339* BTDC. I hope it helps if not you might need to back it down to 2 parts 91 octane to 1 part E-85.
[IMG] Uploaded with ImageShack.us[/IMG]
Your car makes too much low end torque for the HPFP to keep up on E-47 LOL. You really should try to mod the HPFP if you know of a diesel shop that could bore it out and put a larger piston in it.
Old 04-29-2011 | 03:23 PM
  #1061
Iam Broke's Avatar
^^^^^^ Looks like mine on E85.
Old 04-29-2011 | 03:28 PM
  #1062
That is his car on E-47. RYRO14s car did the same thing on E-47. His car (RYRIDESMOTOX) made 370 wrtq on a mustang dyno on 91 octane and 5-7* of midrange timing.
Old 04-29-2011 | 08:08 PM
  #1063
Well, got my first taste of the corn tonight. Went out to do some logs. All I have to say is *&%%$ *&%# &^@#!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I <3 corn
Old 04-29-2011 | 09:59 PM
  #1064
FF_ace's Avatar
Part of the install is done, I used a Devil's Own tap on the WWF tank lower front side behind the foglight. Mounted the nozzle in the ZZP Maf relocate block off plate in the CP just before the TB. Ran the nozzle tubing and boost tubing. The kit was missing the boost switch (stage 1) so I'm waiting on it to finish but the pump will be mounted down in the bumper space behind the driver's foglight. Boost switch will mount in there behind the headlight also. Only exposed parts will be the tubing, checkvalve and nozzle. Boost switch tubing will tee into the line from the lower CP pressure tap.
Getting some fittings tonight so I can mount the pump down in there lower than the tank.
It's progressing in stages. \threadjack. lol
welcome to the e85, methanol injection club. im running a 7gph nozzel since i bolted the 5857 turbo
Old 04-29-2011 | 10:24 PM
  #1065
xcross's Avatar
koooooooooooooooorrrrrrrrrrrrrrrrrrrrrrrrrrrrrrnnn nnnnnnnnnnnnnn
Old 04-30-2011 | 08:52 AM
  #1066
Iam Broke's Avatar
5 gpm nozzle on the stock turbo when the pressure switch arrives, everything else is ready.
I'll try and snap some pics when I pull the headlight out to finish it up for Gremlin. Prob be Mon or Tues.
Old 04-30-2011 | 10:35 AM
  #1067
LOL too much torque... damn, that sounds like a personal problem haha. I have been looking around for a diesel shop and I found one. I'l call this week and see if they can do some adjust of the HPFP. I logged the new tune. It still drops pressure but it only does it on the second pull, not before, not after lol
Old 05-02-2011 | 04:41 PM
  #1068
Stamina's Avatar
For those that may ever need to switch back and forth:
Had to go on a 5+ hour drive trip up north and back a while back, to an area that didn't have much E85 around, so I decided on switching to gas for the trip and then switching back once I got back...
Tip: After running the car down on gas or E85, fill up and drive around for 5-10mins BEFORE flashing the tune, or the car will hate you.
The first switch back to 93, I ran the tank almost empty, filled up, rolled the car back, and flashed it right then. The car wanted no part of things until it got into closed loop, and still pretty much ran funky until it was most of the way through the fuel transition in the fueling system. I secretly blame it on the car becoming an E junky.
Knowing this, when switching back to E85, I did the flash after some driving and my trims started shifting, and it was a smooth, seamless transition.
I know not everybody has fuel trim monitoring capabilities, so just give it 5-10mins of easy driving to get the juices flowing before doing the flash. I would also recommend keeping out of boost during the transition period as well, for the sake of the engine.
Anyway, just wanted to clarify any questions people may have had about the order of things during switches back and forth.
Old 05-02-2011 | 10:34 PM
  #1069
RAIDERNATION 433's Avatar
so why is it that I have to prime my car on the cold start with the E85? Is it cause the the E85 or the tune that makes is hard to start? Once I get the car started she runs like A champ.
Old 05-03-2011 | 06:31 AM
  #1070
I don't have a idle or starting issue at all. But I have read that E does respond unfavorably to chilly mornings.
Old 05-03-2011 | 09:33 AM
  #1071
Does the MAF scaling alter the MPG INSTANT readings at all? I mean I don't think it would buuut I'm seeing noticeably better gas mileage running E47.
Old 05-03-2011 | 12:41 PM
  #1072
Iam Broke's Avatar
Injector constant increase raises MPG displayed for whatever reason. No way to scale it into the BCM. I informed Vince of this during testing of the E85 layer tune.
Old 05-03-2011 | 12:59 PM
  #1073
Oh darn
Even still, I don't think I have seen a drop in gas mileage thus far. Seems pretty much the same based on fill-ups and manual calculation.
Old 05-03-2011 | 01:42 PM
  #1074
mofofernando's Avatar
a little late but subd
Old 05-03-2011 | 02:56 PM
  #1075
MS3 2 SSTC's Avatar
my mileage test is on! i got a 350 mile trip to Houston on e85. last time i made it from Edinburg, Tx to Buckeys Truck stop thats outside of Houston with 1/4 tank to spare on 93. gonna see how far i make it on e85. im taking an extra 5 gallon jug of e85 just to make sure.
Quick Reply: May have solved 100% E85 on LNF puzzle
