megan racing turbo exhaust?
lol yea RFL is really intense! I like the FL alot too, but arent those both catbacks? The megan has these measurements:
MEASUREMENTS:
- 2.5" OD piping, 4.5" tip, 2 7/8" ID @ inlet flange
alright well thanks for info anyways, i was sure you would get SOMETHING out of a catback performance wise..
MEASUREMENTS:
MEASUREMENTS:
MEASUREMENTS:
wont get any hp upgrade when its the same size as stock (2.5). even if you get a 3 inch, the stock exhaust flows pretty well, only exhaust upgrade that will show results is a catless downpipe. catback is just for sound.
where do you live? If you are worried about it, just gut the rear cat with a 2.75 piece of tubing from O'Reilly's. That is unless you get smog tested.
Seriously though, with an LNF if you aren't opening up the downpipe, you are wasting time and money, it's one of the easiest and cheapest gain.
Catless downpipe $200 for 5-10HP
or gut rear cat for $5 for 5HP
Exhaust $500 for <5HP
But i will definitely be getting a FL from turbo XS when i need exhaust
Do a high flow cat and 3"cat back. The high flow cat will give you the largest gain. mosthigh flow cats now days are good enough to where you won't loose more then 1 or 2HP over a cat less setup.
and not everything sounds good on an lnf..
