MPx Oil Catch Can
Old 07-01-2011 | 01:48 PM
Miko's Avatar
Yeah, I tried them but could not get the valve cover connector off with them so figured out the tie wrap trick.
Old 07-04-2011 | 07:02 PM
gotboost?17's Avatar
Nothin Stock
welp guys, i was running my ctach can with the lil paper filter it came with, and there was a lil build up inside the catch can, just decided to remover the filter 3 days ago and then pop the hood today and this>. i seen in another catch the liquide was white/milky colour and dont you think this is alot for a few days
Old 07-04-2011 | 11:45 PM
Miko's Avatar
Whaaat the? How long did it take to get to that level? Is your engine still getting broken in or something?
Old 07-05-2011 | 06:56 AM
Nothin Stock
nope, i emptyed it, ill pay attention now how long it takes to fill up, does this look normal?
Old 07-09-2011 | 12:47 AM
ronn's Avatar
Originally Posted by snoftall
For those who have installed the MPx Oil Catch can:
Which line is it that this catch can is replacing? The line circled in Orange, or the line circled in Blue? I'm pretty confident it is the orange line, but I want to make sure.
So is the catch can is positioned (so to speak) into where was this line (now removed) so that one hose feeds into the can from the valve cover and the other hose goes from the can to the turbo side? SEE BELOW
Somone else has another route shown here:
...anyone care to clarify?
Old 07-09-2011 | 02:40 AM
Nothin Stock
Old 07-09-2011 | 02:51 PM
ronn's Avatar
Edited:
Found this explanation:
When I swapped to the Hahn intake I noticed a fair amount of oil in the stock accordian intake elbow and residue in the charge pipes. After closer inspection I realized the oil was coming from the breather which goes from the passenger rear of the valve cover to the inlet of the compressor housing.
For those who don't know, the other breather which comes off the middle rear of the valve cover to the intake is the fresh air intake ONLY. That black dingus you snap onto your intake is the PCV valve. Its a one way check valve flowing towards the valve cover, and it appears to be a pretty good valve. I hit it with 5-10psi of shop air and it held. So no reason to futz around with it unless you want two catch can draws, which on a higher boost/hp car isn't a horrible idea.
Old 07-11-2011 | 03:21 AM
ronn's Avatar
Originally Posted by Miko
So I figured out an easy way to get the hose off! Plastic/Nylon Zip Tie Wraps or whatever you call them! Get some that are medium sized, a few mm thick, cut four, two inch long pieces (do not use the thin tapered starter section of the tie wrap), insert one piece at each locking tab to disengage it, then pull off the connector (a firm tug was required still).
The tie wrap pieces are great because they are very flexible and easy to get into the connector. Just use tie wraps that are thick enough to fully disengage the locking tabs (but not too thick that it jams trying to be inserted) and you are good to go! The hard part was finding where the locking tabs were but I guess you could cut more pieces and jam the connector full if you wanted to make sure you got them.
Here is a picture of how I got the hose off the turbo side just to demonstrate how this works great to get into tight spaces. On the turbo side the fitting completely blocks about a quarter of the connector but I was still able to fit the piece of tie wrap in to disengage the locking tab (The picture only shows one piece of plastic tie but I used four total).
I'm so happy I have my catch can in finally!
How about this? Think I'm gonna try it!
Old 07-11-2011 | 10:47 PM
Miko's Avatar
That might work but you can only disengage one of the four locking tabs at a time with that. And getting at all the tabs with the valve cover on will be almost impossible, maybe rotating the hose will help. I tried disengaging the tabs one at a time the first time (before I figured out the plastic tie trick) but only got one or two off. You'll have to pull on the hose the whole time so that the undone tabs don't re-engage while you are undoing the next one. Should work okay on the turbo side of the hose once you have that "plug" off and can work on the connector out in the open.
Old 07-11-2011 | 10:52 PM
Sweetsandman's Avatar
Jeeze...I mean I know some of these things let off more blow-by than others...but damn...good thing you installed that or you could've seen a MAP sensor failure soon enough.
Old 07-12-2011 | 01:11 AM
  #36
gone_in_10_sec's Avatar
Just wondering how much boost your running?
Old 07-12-2011 | 02:13 AM
  #37
ronn's Avatar
I actually got the tie wraps today as you suggested..I was thinking exactly that...I can apply several tabs at once to faciliate removal from the valve cover side. I'll have the bent screw driver handy just in case. Thanks for the great suggestion.
Old 07-12-2011 | 12:57 PM
  #38
vahdyx's Avatar
Nevermind got my answer
Old 07-12-2011 | 01:08 PM
  #39
07SSYellow's Avatar
Resident Post Whore/Troll
so i have an MPX catch can in my back seat ive had there for like 2 months now because i cant get the lines off to install it!! but i am going to try the zip tie trick this weekend
Old 07-12-2011 | 04:50 PM
  #40
ronn's Avatar
I think it will work fine. I just inserted one tie wrap on top and it started to come loose.
The wraps easily release the tabs inside. I'm gonna stick around 6 in there. Heads up on the bolt that holds the line on the turbo...you'll need a swivell to get in there...10mm. I got it loose in testing. I hope it pulls out easily...I know there's a seal in there so i'll prolly need to pull hard on it to get it out. Wish me luck!
Old 08-14-2011 | 06:07 PM
  #41
jpower102's Avatar
what size of tubing do you guys recommend?
Old 08-14-2011 | 06:36 PM
  #42
Nothin Stock
3/8 fuel line fits perfect
Old 08-15-2011 | 01:57 AM
  #43
vahdyx's Avatar
So is this a pain in the ass to install? Is it just plug and play?
Old 08-15-2011 | 10:34 PM
  #44
Miko's Avatar
Yeah, you have to wiggle it a lot to get the turbo plug out. It was surprisingly a big plug with an o-ring seal you can see in my pic.
Old 08-16-2011 | 12:28 PM
  #45
slowbalt84's Avatar
its so much easier doing this with the turbo out lol
Old 08-28-2011 | 10:48 PM
  #46
RED08SSTC's Avatar
Thinking about getting this, does it come with everything you need when you order it from mpx?
Old 08-28-2011 | 11:11 PM
  #47
vahdyx's Avatar
MPx said it's easy and will take around 30 minutes. Lets hope so... I just ordered it...
Old 08-28-2011 | 11:23 PM
  #48
dayhoff35's Avatar
subd
Old 08-28-2011 | 11:35 PM
  #49
RED08SSTC's Avatar
Im just trying to find out if it comes with everthing ill need to install it, like all the hoses.
Old 08-29-2011 | 01:20 AM
  #50
Toddc's Avatar
Yes, it comes with the two fittings, hoses, can, and 4 hose clamps.
